M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > JB4 for M2?
      03-12-2017, 08:37 PM   #45
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Originally Posted by FSociety View Post
Originally Posted by ashburyn54 View Post
Little firmware testing. Making steps, no more throttle closures, very smooth.
Stock boost it looks? What gear was this on ?
This is my map4 (datalogging only) on ewg9 (havent upgraded to ewg11 yet)
I did some back to back pulls. Had about E30-35 mix here.
EcoPro & Comfort pull in the first one
then DSC off
then Sport+
That's was a stock boost map. 3Rd gear but it's smoother in 4th as I have traction issues in the cold. My map 1 logs are the same! Amazing the change. My HPFP levels are actually much higher. To the point I may be able to get away with e30 on map 2. Before I couldn't. I don't understand how it's so much better but it is.
Heres a map 1 log compared to a map 4 log before the changes. keep in mind it was really cold so ECU psi is lower than usual to meet stock load/boost level.
The throttle closure log is before EWG 11. Good throttle log is map 1 on EWG 11 test 3. The map 1 LOG was still learning. AVG IGN learned to .8-1.1 on 93oct
      03-12-2017, 11:35 PM   #46
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Looks much better the before and after, can you run map2 or 5 now?
Have a friend who just got bunch of errors with new firmware after doing some testing with new fw he believes PI cut out and got these errors.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      03-16-2017, 02:37 PM   #47
jyrbba
Drives: BMW 335 -07
Just uploaded FW11 myself, I still have throttle closure issues like you had. I have to check i actually have FW11 on..
Also can you show your JB4 settings, anything changed or something?
--Jyri
      03-16-2017, 04:01 PM   #48
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
--Jyri
Hey there. Do you have the optional EWG wires?
      03-16-2017, 04:03 PM   #49
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
--Jyri
When I installed the EWG wires and updated to EWG11 firmware I saw the change. I also set FUA to 40 for duty Cycle purposes by request. Every car is different so make sure to log and post or send your logs in for analysis.
      03-16-2017, 04:55 PM   #50
jyrbba
Drives: BMW 335 -07
Yeah I've got EWG wires, Terry also suggested to change FUA to 30, I guess it's 60 now. I gotta check it out tomorrow if it makes a difference.
Here is a log from yesterday:
http://www.datazap.me/u/larii/bmw-m2-jb4?log=0&data=1-4
--Jyri
      03-16-2017, 05:03 PM   #51
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
--Jyri
Log doesn't look bad at all but yes I see the throttle. At least it's leaning towards full as it learns. Try FUA at 40-60 as terry or whoever said. Man the m2's stock boost targets are so aggressive for ever map 1 at 4psi over. Log in map4 and see what happens. Your IGN looks good though. So no worries there
      03-16-2017, 06:32 PM   #52
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
ashburyn54 you got your map4 on datazap?
I want to see your Boost + ECU_PSI + DME_BT to see how it looks
Yea agree log map4!
IG: @bmwF9XG80
      03-31-2017, 01:29 PM   #53
riske
13
Drives: M2 & 435d xdrive convertible
I need some help. What map is safe to run on v power (99oct)with eventuri, VRSF DP, Intercooler?
I keep getting Drivetrain errors and CEL without any idea or codes showing on JB4!? Except Catless DP recognised.
I'm running map4 safety
      03-31-2017, 01:51 PM   #54
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Could be MAF sensor due to the Eventuri
Are you clearing the codes with the JB4?
Map 1 was recommended for stock M2
      03-31-2017, 02:29 PM   #55
riske
13
There's no codes to clear on the JB4. Just updated the firmware so that could help.
The Drivetrain error clears upon restart of the car.
