06-01-2022, 08:32 AM | #45 | |
Rep 4,160
Well, yeah, that’s exactly the point. You want the car to be pushed to the maximum perimeters for the new drivability and performance. This is what happens when a tune is loaded on the dyno - the car will actually reset some (not all) adaptations and will continue to adapt at WOT (about over 3 runs) you can do this manually and drive the car hard to learn the most aggressive profile. I would not recommend doing anything abnormal (letting off during WOT, or the like) as the car will ‘learn’ that behavior and mimic it on subsequent runs, and you’ll have to do it over. As for the TS install, I’ve never seen an issue. Like I said, it works for me, and I believe Pure was quoted saying it was better than their GFB+ but I’ve never seen proof. I just think it’s preference. |
///M TOWN17692.00 |
06-07-2022, 10:42 AM | #46 | |
Rep 345
06-07-2022, 11:39 AM | #48 | |
17692
Rep 8,486
https://www.turbosmart.com/product/k...vr2-dual-port/
M2RAW121.00 |
06-07-2022, 11:41 AM | #49 | ||
Rep 345
///M TOWN17692.00 |
06-07-2022, 11:54 AM | #50 | |||
17692
Rep 8,486
Plumb back unit like I am running https://www.turbosmart.com/product/k...vr2-dual-port/
M2RAW121.00 |
06-07-2022, 12:17 PM | #51 | |
Rep 4,160
https://x-ph.com/turbosmart-bov-komp...55-m2-x4-m40i/ (I think Mike may have coupons, so try those)
Mods: Yes.
M2RAW121.00 |
06-07-2022, 03:13 PM | #54 |
Rep 307
Bend Calibration will not tune N55 M2s without HPFP. I was in touch with them a few weeks ago and they confirmed as such.
I asked them what HPFP they recommended and they came back with either Dorch stage 2 or Nostrum and call it a day. Kind of a bummer cuz I really like Ecutek, and am pretty much FBO minus HPFP and tune. |
///M TOWN17692.00 |
06-19-2022, 03:36 AM | #56 | |
Rep 7,438
If it is sticking then you will hear alot of compressor surge, and the logs will show that boost is being retained for a long time even after letting off the gas. If it is leaking then WGDC will be alot higher than normal while boost is having a hard time hitting targets. If it is really bad you will not hit boost targets at all and WGDC will be maxed. Fuel trims should be pretty negative because there is not enough air in the engine vs. what is expected by fuelling tables. These are some general signs.
Altra265.50 Sundinisagod107.00 |
06-19-2022, 06:52 AM | #57 | |
Rep 20
10-22-2022, 11:19 PM | #58 | |
Rep 248
2 weeks ago installed Turbo BOV DV, Inlet, CSF IC, CP, BP, DP, all together. flashed couple maps and tested, logs looks fine. no knocks. Then I swapped stock spark plugs to NGK 0.022'' gapped last week. flashed and tested again, knocks happened both low/high rpm, timing is messy WOT. after that I flashed back to stock tune. knocks and timing issue still happening. Now I kept stock tune and drive like a nanny to work, and keep RPM below 3k all the time, low % throttle Don't know where to start. Is resetting adaptations and reflash gonna help? everything seemed to started after changing new spark plugs. thanks |
10-22-2022, 11:28 PM | #59 | |
Rep 7,438
10-22-2022, 11:33 PM | #60 | |
Rep 248
maybe post some logs can help: Custom Stage 2 ACN91Octane NGK 0.022'' https://www.bootmod3.net/log?id=6353...729b66bdb6d229 https://www.bootmod3.net/log?id=6353...0b43b1b5059a35 https://www.bootmod3.net/log?id=6353...90c684c311d7d2 https://www.bootmod3.net/log?id=6353...0b43b1b5059a3e Stage 1 OTS ACN91 NGK 0.022'' https://www.bootmod3.net/log?id=6352...729b66bdb6cfd0 Stock Tune NGK 0.022'' https://www.bootmod3.net/log?id=6353...729b66bdb6d23f https://www.bootmod3.net/log?id=6353...90c684c311d7e6 https://www.bootmod3.net/log?id=6353...0b43ae5b70358a https://www.bootmod3.net/log?id=6353...90c6816a81a29a https://www.bootmod3.net/log?id=6353...0b43ae5b70358f Stage 1 OTS ACN91 Octane Stock Spark Plugs https://www.bootmod3.net/log?id=6345...0b43afee4ba68f Stage 2 OTS ACN91 Octane Stock Spark Plugs https://www.bootmod3.net/log?id=6342...90c6e0a56a1257 |
10-23-2022, 03:01 AM | #63 | |
Grandmaster
775
Rep 803
Heres what MY car looks like on the stock tune HPFP requested vs actual Heres what YOUR car looks like I am not an expert i just know enough to be dangerous.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
10-24-2022, 12:53 AM | #64 | |
Rep 248
HPFP seems fine. both stage1 ots or stage2 ots tune I know there is still a missing fuel pressure target, and they are short 3rd gear pulls but it's not horrible. Thank you for sharing anyway. ^_^ |
10-24-2022, 07:49 AM | #65 | |
Rep 4,160
One - it could be the car adapting from map switching, which would cause the knock I saw in the "custom stage 2 ACN" but it's also the spark plugs. Please go back to the stock plugs with the stock gap, or widen the gap on these plugs to .03 and try again.
Mods: Yes.
10-24-2022, 07:51 AM | #66 | |
Rep 4,160
Mods: Yes.
