BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos > Recommend a power washer & jump starter
      01-17-2017, 08:20 PM   #1
Never_Enough
Drives: Satan's Chariot 2.0
Smile Recommend a power washer & jump starter
I've been meaning to get a power washer for a while, but keep forgetting about it. It'll be used for washing cars, washing house, etc.
Also, after the alternator going out in the Miata, it's time to stop procrastinating on getting a jump starter to carry around. Thankfully, I wasn't far from my destination & my friend came & jumped me. I've seen a ton of them online for under $50 so what is good & reliable?
      01-18-2017, 05:11 PM   #2
Never_Enough
No one huh?
      01-18-2017, 06:13 PM   #3
to_riffic
to_riffic's Avatar
Drives: rwd
I have one of these portable jump starters. Really multi-functional.
https://www.amazon.com/dp/B015TKUPIC...s_ad_dp_asin_1
As for washer. I didn't heavily invest into one, but got this one for $60 a while back as a deal, and it has been great so far power washing the cars.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
~loud noises~
      01-19-2017, 03:04 PM   #4
bb1857
bb1857's Avatar
868
Drives: 2020 X3MC
2007 BMW 335 E92  [0.00]
2015 BMW 428GC  [0.00]
2014 BMW 535i  [0.00]
I have a gas pressure washer for the house and cleaning the deck, sidewalk, etc around the house and bought an electric Ryobi for washing the cars with a foam cannon. The gas washer is way to cumbersome and loud to drag out for cars and most electric ones don't have the oomph needed for house stuff unless you spend over $1000 and then I'm not even sure.
As for the jump starter, I have one of those little lithium ones as well and it works great plus it can charge phones and has a flashlight for emergencies.
      01-19-2017, 05:53 PM   #5
Never_Enough
Which jump starter do you have?
      01-19-2017, 06:27 PM   #6
bb1857
bb1857's Avatar
868
Drives: 2020 X3MC
I have this one....used to keep it in my sons Jeep and it worked really well when we went off roading
https://www.walmart.com/ip/PowerAll-...liath/51232584
      01-19-2017, 07:58 PM   #7
Never_Enough
I'm keeping this buy under $50.
      01-20-2017, 10:02 AM   #8
Never_Enough
Anyone using the Harbor Freight jump starter?
      01-20-2017, 11:24 AM   #9
n55x3
Drives: n55 BMWs
Under $50 is gonna be tricky. You want to buy the most peak amps you can find.
I bought several of these last year as gifts and kept one for myself. 800 Peak amps.
I've used it on our Land Cruiser and it worked just fine.
Regarding the power washer, it all depends on what you need. i've gone through 2 junky electric ones (probably ~ $80 each, lasted 1 year max) and finally ponied up for a gas unit. Couldn't be happier. I'd just look for one with a Honda motor for piece of mind. Lots of different pump designs though so you have to pay attention to that as well.
      01-20-2017, 11:37 AM   #10
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
As for the pressure washer, one small tip. The "pressure rating" is pretty much meaningless, what really matters is the GPM rating. High pressure and low GPM and you are using the equivalent of a waterpic.
      01-30-2017, 07:38 PM   #11
Never_Enough
Looking at these washers at Home Depot
http://www.homedepot.com/p/Sun-Joe-P...3000/204202850
http://www.homedepot.com/p/Ryobi-170...4122/203800590
http://www.homedepot.com/p/Briggs-St...0600/300423908
http://www.homedepot.com/p/Briggs-St...0654/300382834
http://www.homedepot.com/p/Campbell-...0100/207085884
http://www.homedepot.com/p/Sun-Joe-P...1500/300349610
http://www.homedepot.com/p/Campbell-...0100/207085885
http://www.homedepot.com/p/AR-Blue-C...R527/204072257
      01-31-2017, 11:16 PM   #12
Amused
Drives: 17' F32 440i M-Sport AW
Go with a gas pressure washer. Electric ones just don't push the GPM for washing cars, houses, decks etc....
You generally want one that is 2.5gpm+.
I have a Generac 5993 and it works great for washing cars, the driveway, deck and other things that you want a lot of water flow.
      01-24-2018, 02:39 AM   #13
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
Is it true that anything over 2500 psi is bad for paint? Most gas pressure washers push 3,000+ psi correct. Is this true? Sorry for dumb questions, new guy just learning vehicle maintenance as I am in market for my first pressure washer.
      01-24-2018, 06:56 AM   #14
JerryW235
JerryW235's Avatar
Drives: 2021 X7 40i; 2021 X3 M40i
A high PSI can strip off paint, damage wood and concrete, if not used properly. However, the good thing about a higher powered gas pressure washer is that since they have a pressure adjustment valve, you can dial down the pressure. The other positive is that although you probably could wash a house or driveway with an electric, it will take a longer time to do so than with a higher powered gas one. As with many other powered tools and toys, there's no substitute for cubic inches, horsepower, torque, PSI, etc. If you can, borrow or rent an electric washer, and a gas washer and do a side by side comparison, and see what best fits your need.
"Horsepower is a terrible thing to waste."
      01-24-2018, 07:11 AM   #15
JerryW235
JerryW235's Avatar
Out of these, I'd go with the first on, it's got the highest PSI rating, and the highest GPM rating. The GPM or how much water volume it pushes is just as important as the pressure, You need as much water volume as possible to not only wash the dirt off with soap or cleaner, but also rinse everything off afterwards. If they can be believed, the reviews for it at Home Depot and Amazon are pretty good.
      01-25-2018, 07:25 PM   #16
Ian1973
Drives: 15 M3
I personally have had this one since like 2010. Just simple maintenance and running perfect. Starts on the first pull still.
https://www.northerntool.com/shop/to...4735_200594735
      01-25-2018, 07:29 PM   #17
Clark_Kent
Clark_Kent's Avatar
2228
Drives: Retired
Kranzle 1122TST. It's pricey; however, it's well crafted and offers great performance.
