01-16-2017, 09:50 AM | #1 |
Doc Brown
1176
Rep 2,174
JB+ vs. Dinan Sport Tuner
So has anyone tried both for comparison? I have the JB+ now and think that it makes pretty good power. But I was thinking about swapping it out for the Dinan piece. Just trying to see if it is actually worth it.
01-16-2017, 12:29 PM | #2 |
Rep 80
I've been following the Dinan Sport Tuner threads also. I believe they both max out at +4psi. I have a JB+ for the record. They work exactly the same way by modifying the air sensor reading to trick turbo into making higher boost. DME takes just a split second to catch up and add required fuel. The only benefit of the Dinan I'm aware of is the Bluetooth logging and switching capabilities. Most of us just crank the JB+ up to max anyway and never mess with it again. So far, with a DP and IC, the car pulls very well. Under full throttle, the tires never hook up until halfway through 3rd gear. Very amusing I would've bought the Dinan if it was available a few months back. 100$ extra over the JB+ is nothing. If anybody else has more/better info please add on.
SeanWRT3179.00 |
01-16-2017, 01:43 PM | #3 |
Doc Brown
1176
Rep 2,174
My understanding was basically the same as yours. Yeah, I have mine cranked up all the way too. I will probably just stick with JB+ for now (unless anyone wants to buy mine, lol). I don't really care about the bluetooth and data logging ability. I have the Dinan resonator delete installed and was thinking about getting the Dinan Intake and Fabspeed HFC. Both for added power and sound.
01-16-2017, 03:01 PM | #4 |
Rep 3,888
01-16-2017, 03:26 PM | #6 |
Doc Brown
1176
Rep 2,174
I mean that I definitely noticed a difference over not having it installed. I would say that bang for the buck you are not going to find more power cheaper.
01-16-2017, 03:27 PM | #7 |
Doc Brown
1176
Rep 2,174
If you open up the unit there is a little dial with a + and - and if you turn it all the way to the + that is a 4psi boost.
01-16-2017, 07:03 PM | #8 |
24082
Rep 190,597
Both unit are almost identical and will make same power ... They add boost and both max out at +4 psi
Only difference is that Dinan has Bluetooth feature and that will cost you an extra $100
01-17-2017, 09:28 AM | #10 |
Rep 2,577
Mike nailed it.
Dinan sport tuner and jb+ trick only the boost and flow mass and relies on DME adapting the rest. That's why they have only 2 wires and take 30 secs to install.
Lemania 2320
mike@x-ph.com24082.00 |
01-17-2017, 11:30 AM | #12 |
11
Rep 70
I opened mine up and it says Min on the left and Max on the right, I turned it to the last "-" above max. Before I changed it, it was at the square right before the dash so I assumed it did something. Or could it be that the DME/ECU adjusted over time to compensate for the extra boost and that removing it for a few hours had "reset" it?
01-17-2017, 01:14 PM | #13 | |
Doc Brown
1176
Rep 2,174
01-17-2017, 01:20 PM | #15 |
24082
Rep 190,597
No both are very safe even for completely stock cars
10-24-2017, 09:54 PM | #16 |
Rep 719
Can you explain why? Even Dinan mentions in their webpage that this setup is bad for the car and not very effective
10-25-2017, 07:36 AM | #17 |
Amateur Tattoo Artist
809
Rep 700
10-25-2017, 08:16 AM | #18 | |
Rep 3,888
Some turbo car manufacturers ECU's don't aim for consistency and will give you max power for conditions. In some cases, considerably more on cold days. However, BMW's DME is programmed for consistent power output. So on cold days, if more dense air is detected, turbo is told not to work as hard. At lower elevations, turbo is told not to work as hard. Meanwhile, there is usually untapped, available margin for safely raising boost under those conditions. JB+ and Dinan Sport tuner effectively give you that margin back, albeit under all conditions. They are marketed as boost controllers for some reason, but that is somewhat misleading, because they only indirectly cause boost to raise. Why can this be unsafe? Because the car may not adapt fast enough on the more extreme tuner-device settings if low MAF signal and air is hot or gas is lower octane. In general, you want cooler air if you're raising boost like on the order of 30deg F per 1PSI, or increase octane which lowers combustion temps. 1PSI per 2AKI. Terry ran an instrumented, stock M2 on 91oct on his dyno and got timing pull up top. To me this means don't add a tune the car without first flowing more air, or lowering temps or using higher octane, as car has effectively used up its safety margin. Last edited by zenmaster; 10-25-2017 at 08:21 AM.. |
ZM22810.50 subliminalaudio313.50 |
10-25-2017, 08:58 AM | #19 | |
Rep 3,695
10-31-2017, 12:44 PM | #21 |
Rep 51
I run the JB+ in my M2 with DP and intake. With some RON 98 (93 to you guys), it pulls noticeably stronger, even pulled a guy with a DP and JB4 on map 1 but with RON 95. Only issue I've had is that I loose that really nice bang in second gear if floor it and pull off below 4800 rev/min...? Anybody else get that ?
10-31-2017, 12:56 PM | #22 |
Rep 209
Is the slightly delay of the DME to adjust the fuel and timing noticeable while driving? I am interesting in getting a cheaper option like one of these to couple with a FMIC that would be easy to take out if I wanted to change it later on.
I have a DCT full dinan exhaust and drop in filter. |
