M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > What happens if you install DP's but no Tune or Flash?
      01-17-2017, 12:41 PM   #23
LBBDrew
Drives: 2017 LBB M2
I would be cautious with those CEL delete cables. I've heard and read that they tend to fail after a couple months and the code reappears
      01-17-2017, 01:05 PM   #24
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
How bout one of these?
http://www.armytrix.com/CEL-Terminator.php
      01-17-2017, 01:21 PM   #25
LBBDrew
Drives: 2017 LBB M2
Originally Posted by andrewc89 View Post
Not familiar with this specific product, but I assume they all work the same way? VRSF offers a CEL delete options for $99 for their catless DP, but I've been told it is not a viable solution
      01-17-2017, 01:35 PM   #26
AndrewC1989
they don't work the same way as dp fix wires. it's a little box that you keep plugged in your ODBII port and it deletes 02 sensor/cat error codes in the same way a jb4 does. Has nothing to do with passing emissions, just keeps the CEL from coming on. seems like it would work just fine. when you go in for service you just remove it. when you get the car back you just plug it back in. there's no issue with not being able to pass emissions when you take your car in for service at bmw. not in NJ at least. dealerships don't give a shit about that, you only have to worry about passing emissions when getting your sticker at the DMV once the car is 5 years old. California may be different.
      01-25-2017, 08:09 PM   #27
'Q
You've heard wrong, I've tried and ran into no issues with numerous sport cars and supercars.
Catless DP's will make it sound louder and will make more power combined with a tune.
A 200 CEL DP will not need a tune and will have more of a 'bass' deeper sound. But, expect black smoke, because in most cases it will run rich.
With a 100 CEL, some cars will throw a CEL light ( from experience ) on the dash from time to time if the sensors are not good quality.
IF you're going with cats, go with HJS cats.
I've heard of many 200CEL cats eventually throwing codes and a light overtime.
They also cost 2-3 times as much as the catless one's and aren't as loud, so it's pretty much a no brainer to go catless and just buy a CEL delete module.
i'm not worried about passing emissions, i won't have to even go for 5 years since i just bought the car. i just want the CEL off the dash. i've already figured out multiple ways to do that so i'm good there.
my only question was about how the car will behave when cats are removed and a tune/flash is NOT added.
from what i've been told the car should act the same as before but i'm just asking hoping someone who's done this can tell me from 1st hand experience.
      01-25-2017, 10:12 PM   #28
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Care to explain why?
I heard different theories on running rich/lean out of dp on stock tune all the time.
Lemania 2320
      01-26-2017, 10:51 AM   #29
'Q
Same here, I heard different opinions but in my experience, most of the cars i had with a catless DP blew black smoke ( on 91OCT/95RON pump gas ) even when tuned. When using a better fuel grade like 93OCT/98RON, it did lower the amount of smoke at WOT.
Just to be clear, this only happens at full throttle once all the torque kicks in.
      01-26-2017, 12:29 PM   #30
NO_USER_
Drives: .
How bad would it be to show up to the dealership with a CEL due to being catless lol. Has anyone tried the VRSF CEL delete
      01-26-2017, 07:56 PM   #31
AndrewC1989
i used to service my old 335 with the intercooler, DP's and a JB4 with the dp fix wires and nobody said anything to me until i removed the wires. then they just told me the car was throwing cat codes but assumed i knew why. wasn't an issue.
      01-26-2017, 10:15 PM   #32
NO_USER_
Drives: .
Have you guys heard of the BMS Can Flap Module?? Just heard from Mike at X-PH, that can clear the CEL code! That is AWESOME! Just plug it into the OBDII! Also has many other features, like disabling ASD (assuming these all work on the M2).
      01-30-2017, 06:21 PM   #33
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
The Macht Schnell EVC module can do this and much more, while keeping the OBD2 port open.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      01-31-2017, 09:04 PM   #34
NO_USER_
Drives: .
That's sick! Is the install easy, anything crazy done with wires or does it plug in elsewhere? That'd be great to keep the OBDII port open.
Thanks!
      02-01-2017, 06:41 AM   #35
auf Deutsch
auf Deutsch's Avatar
2017 BMW M2  [0.00]
I'm going with a Fabspeed 200-cell with HJS cat(s). To everyone's knowledge, this unit has yet to throw any CEL....just clean, smooth power throughout the powerband with an aggressive tone. At $1200, it's not cheap but why skimp on such an important bolt-on modification? Their in-house dyno showed a 32 whp increase over stock at 5500 rpm (coupled with their muffler bypass exhaust) without any tune.
retired: 2014 435xi|MPPK|335 bhp|3/5 stars
Appreciate 4
      02-01-2017, 09:21 AM   #36
AndrewC1989
I know that it's a quality item but for that price you could buy a catless downpipe and a jb4 which would give you valve control, create more hp and make more noise
      02-01-2017, 10:45 AM   #37
auf Deutsch
2017 BMW M2  [0.00]
JB4 is a great product and a catless DP is a HP maker.
That being said, I want warranty coverage, especially with ECU tunes. Granted, the sport tuner isn't warrantied but it's only temporarily on here for another month or so. As for the DP, I want a legal component. A catless not only fails emissions, it draws attention to my service dept. and the random asshole cop who could issue me a citation. I have enough headaches in my life. I want to be as worry-free as possible as it pertains to my car while safely maximizing power and sound.
AndrewC198910931.00
No Boost4021.00
      02-01-2017, 11:00 AM   #38
AndrewC1989
It really is a good middle ground, no doubt about it. I'm just worried I won't get the sound I want and i'll end up spending all that money with not a lot to show for it. Deff is going to take a little more research and thinking before I decide. I'm not too far away from fabspeed so maybe I can make an appointment with them and get to hear both options in person.
      02-01-2017, 12:21 PM   #39
AlexCirci
AlexCirci's Avatar
497
Drives: LBB M2
Installed VRSF catless dp last night. The sound is amazing. Videos do not do it justice. I installed the Fabspeed o2 spacer so we will see if that prevents CEL but I think its doubtful. I will post updates.
If you are hesitant on catless dp, dont be. Do it. You will not regret it the sound is intoxicating
F87 M2 - LBB - 6MT - Exec Package
insta - @LBB_M2
      02-01-2017, 12:25 PM   #40
mike@x-ph.com
mike@x-ph.com's Avatar
+1
https://x-ph.com/sale/
Phone number 702-494-9435
AlexCirci496.50
      02-01-2017, 12:39 PM   #41
AndrewC1989
well if you go catless you pretty much have to tune/piggyback (it's highly recommended) where as a sport cat doesn't require that so that's why i was leaning towards the more expensive and less fun option lol. No CEL or fear of losing warranty coverage. but jb4 + catless would sound good and give more power. ugh. decisions decisions...
      02-01-2017, 12:57 PM   #42
AndrewC1989
boy does that sound good for something that doesnt trigger a CEL
Alright i think i've made my choice after a whole lot of back and forth. Order placed at fabspeed for a 200cell HJS Cat
they're backordered atm but i will post an update after install and give my thoughts later this month
      02-01-2017, 01:38 PM   #43
AlexCirci
AlexCirci's Avatar
497
Drives: LBB M2
Yeah my plan is to tune eventually but running catless without tune is perfectly fine like others have said here. I live in NC and emissions is every 3 years now so I'm not too worried.
I'm sure whatever you get you will be satisfied. Catless has a little more deeper tone to it with more cracks and burbles but peace of mind of no CEL with the sportcat is nice as well.
insta - @LBB_M2
AndrewC198910931.00
      02-02-2017, 07:59 AM   #44
blackholescion
Drives: MG M2
It's not every 3 years. New cars made within the last 3 years are exempt because they rarely fail emissions and it was a waste of everyone's time. After that, you still have to do annual.
https://deq.nc.gov/about/divisions/a...on-information
