M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 18" 275 fitment on stock suspension M2
      01-04-2017, 08:00 AM   #1
cme
cme's Avatar
229
Drives: 22 M3 xD Comp
Hi. I have a 2013 E92 M3 and run a set of Apex 19x9.5 ET:22 square setup with 275/35 Bridgestone RE-71R tires for the track. I ran a comparison on one of the wheel/tire sites and seems like both fr and rr will stick out 0.9" more than stock. Seems like an acceptable amount.
Anyone else try this setup? I would love to be able to swap track rims/tires between cars.
Thanks.
Chet
72 2002tii | 90 E30 M3
13 E92 M3 | 16 F87 M2
20 F87 M2 CS
22 G80 M3 xD Comp
      01-06-2017, 03:19 PM   #2
2M
2M's Avatar
Drives: Mineral Grey M2
Thanks.
Chet
Just try em on . If you were at a store buying shoes, wouldn't you just put em on and see if they fit lol ?
      01-06-2017, 08:33 PM   #3
M3 Adjuster
Albania
7906
@CosmosMpower may be able to help -
Agree that you should just take an afternoon and swap wheels. That's about a 1 beer job.
      01-10-2017, 09:34 AM   #4
IND-Distribution
IND-Distribution's Avatar
9586
Drives: G82 M4 / G87 M2
9.5 with a +22 offset will work for the front of the car, but is too aggressive for the rear by a substantial amount. You'll need a higher offset to get a good 9.5" wide wheel with 275 width tire on the rear.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      01-10-2017, 01:48 PM   #5
cme
cme's Avatar
229
Thanks for the heads-up. Can i use spacers out back with the set that I have. I think 15mm should do the trick??
I know I can try them on but I run winter tires for my M3 on the same rims. Just trying to get ahead of the game if I need to make major changes or get new rims.
Chet
20 F87 M2 CS
22 G80 M3 xD Comp
      01-10-2017, 03:15 PM   #6
Gimmethecash
Gimmethecash's Avatar
150
Drives: F90 M5 Comp
A spacer will effectively lower your offset, not raise it. It's already sticking out too far, and a spacer will make it poke farther.
      01-10-2017, 03:22 PM   #7
cme
cme's Avatar
229
Ahh sorry thanks.
20 F87 M2 CS
22 G80 M3 xD Comp
