12-05-2016, 10:37 PM | #1 |
Rep 36
Anyone interested in Apex EC-7 rims for their M2?
Was liking the looks of the Apex EC-7 Race wheels for the M2 but the sizes that are available are all 18" with the 19" out of stock, perhaps never to return. After a round at the willtheyfit.com website I figure that the 19x9 et22 and 19x9.5 et33 will work for the stock Michelin Sport Cup II tires. The 19x9.5 et33s are now unobtanium and perhaps if there were sufficient interest expressed, Apex would order another run, or perhaps make a custom set of 19s matching the factory sizes and offsets of 19x9 et27 and 19x10 et40.
If a bunch of us are interested, we may be able to seek a group buy at a better price. Maybe this year there will be rims under the tree. |
12-05-2016, 10:58 PM | #2 | |
7906
Rep 11,785
The tire selection is usually better with 18s and of course a set of tires is quite a bit cheaper. An 18" wheel is also lighter than a 19" wheel. Those are three reasons why I can imagine that the 19" wheel has gone away, perhaps indeed never to return. Is there a reason that you prefer 19" track wheels over 18"? |
boostm3683.00 |
12-06-2016, 01:55 PM | #3 |
Rep 36
19s are the stock size
I am guessing the engineers at BMW had a good reason to choose the 19s and that they engineered the car to work best with the wheels they spec'd. The stock tires are already good tires for a track, so why not follow the stock guidelines when getting an aftermarket wheel? You can easily move the Michelin's to the 19" wheels but would have to buy new tires for an 18" set.
The 18's have less rotational mass but must turn more to cover the same distance than the 19s. Other than the convenience of finding 18" wheels more easily than 19s, is there a performance basis to choose the 18s over 19s? |
12-06-2016, 02:13 PM | #4 | |
Rep 629
12-06-2016, 02:43 PM | #5 | |||
7906
Rep 11,785
My additional question was going to be... If you are going to put 19 " track tires on the car then why not just put 19s on the stock wheels or get a second set of stock wheels. If you are that confident in the factory setup and feel it is optimal.. .. then just slap some R tires on your stock wheel or pick up a second set of stockers HOWEVER.. did the factory design this as a STREET car or a TRACK car? The unequivocal answer is that the vehicle is ultimately designed and setup for primarily STREET driving... With respect to your comments above.. - Correct - this is a performance advantage! Quote:
Is there a performance DIS-Advantage here ? I am not aware of what would be negatively affected here.. So.. indeed.. there are performance advantages with 18s Less unsprung weight for the tire less unsprung weight for the wheel (all things being equal) There are also practical advantages for 18s.. you can buy a square setup and rotate - which saves money the tire price for an 18 is less than a 19 - (all things being equal) there are more tire options available in the 18" size than 19" there are more wheel options available in the 18" size than 19" So... with all the advantages FOR 18s ,.. both practical and performance wise... why go with 19s unless vanity is the issue - not that there is anything wrong with that... but if that's the case then just state so. At some point... one must make a decision between performance, value, and looks... I checked out the wheel options you mentioned above.. the 1M has 19 x 9 front and 19 x 10 rear and I presume the M2 is the same. Why would you order track wheels in the same sizes and widths as OEM and pay the expense of new wheels for the track unless it's for style? If you are going to stick with 19s or stock size wheels and tires for the track... Personally... I would just get some Bridgestone RE-71Rs in a size as big as you can go on the stock wheels and be done with it.. Last edited by M3 Adjuster; 12-06-2016 at 03:00 PM.. |
WaMi61.50 |
12-06-2016, 04:41 PM | #7 |
Rep 185
One more benefit of smaller diameter wheels - Less rotational inertia (rim closer to the hub) on the smaller diameter wheels meaning fractionally better accel, braking and ability for the tire to follow high frequency bumps (the last bit being the unsprung mass benefit too).... That said, if sized "properly" the tires will rotate the same for a given distance.. I say "properly" because on one of my race cars I undersized the diameter of the tire to get more favorable gear ratio (punch harder out of the corners sacrificing a bit of top speed) for the typical tracks I'm running.
Also, the "BMW had a good reason to choose the 19s and that they engineered the car blah, blah, blah" is a pet peeve arguement as it is full of incorrect assumptions. Big wheels are nothing more than fashion once big enough to clear the brakes (and they do look sweet!). As M3 Adjuster mentioned they designed it for the street, but also a host of other constraints mostly cost. They aren't gods and I've not met a generic design that meets all my requirements... but for every change, you introduce a new set of constraints and compromises, so if you don't know what you are doing it probably is best to not change anything and trust BMW, but I know what I want and need better than BMW does and if they were building it for me instead of the masses they would change it like I do lol. All that said, I plan to do a square 18" setup unless the traction control logic is too screwed up by doing so. |
M3 Adjuster7905.50 WaMi61.50 |
12-07-2016, 01:20 PM | #8 |
Resident Engineer
135
Rep 748
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
12-07-2016, 01:21 PM | #9 |
Rep 1,681
We missed our chance but I didn't get my car until Nov. The last group buy ended in October
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
12-07-2016, 03:08 PM | #10 |
Rep 182
12-07-2016, 03:36 PM | #11 |
Rep 1,681
I just can't stand how boring they look. No life to them...
Current: ///M2C
12-07-2016, 04:12 PM | #12 |
Rep 182
I agree. But I figure it is only going to be on three to four months max. The other option is just to get winter tires for the stock rim. Its not a bad option if you have no intention of driving in snow often of which I don't. I work from home mostly, and am getting the tires mainly for cold weather rather than driving in actual snow.
M3 Adjuster7905.50 |
