12-05-2016, 06:15 PM | #1 |
Rep 343
How much to install springs on your M2??
I just got a $480+tax quote to install my KW HAS kit on my car from the local shop that I wanted to use.
Hopefully that includes the re-indexing I was reading about over on the F80 forum. How does that seem?? I remember in my E46 days I think I payed half that to have my coils installed. |
12-05-2016, 08:09 PM | #2 | |
Serial Car Buyer
85
Rep 131
I wouldn't think it's necessary in our cars as we don't have adaptive dampening.
Current: '12 E82 1 Series M and '09 E90 M3
Past: '16 F87 M2, '09 987 Cayman, '08 B7 RS4 Avant, '08 E92 M3, '01 B5 RS4 Avant, '05 987 Boxster S, '03 E46 M3, '04 Evo 8MR, and '01 8L S3. |
12-06-2016, 12:42 AM | #3 | |
Rep 343
12-07-2016, 07:45 AM | #5 |
Doc Brown
1176
Rep 2,174
I normally do springs myself. But I have been so busy lately I decided to contact a local shop. They wanted $580 for the install of the my H&R springs and $180 to align the car. Needless to say I will find the time to install them myself, probably in the springtime.
Spinnetti95.50 |
12-07-2016, 08:46 AM | #6 |
Rep 185
its unrelated to adaptive suspension.. I read the linked post, and there looked like one guy who knew what he was talking about - The bushings in the control arm are bolted tight. Lowering the car, twists those bushings more than from the factory and will lead to their early demise, or what people think is "settling" of springs as the bushings either relax or tear... All it is is loosening the control arm bolts, bounce the car a couple times sitting on its wheels and tightening the bolts. That makes sure all the bushings are in a "neutral" position... Honestly, changing springs is simple. Sometimes can be a bit of a pain, but its not complex (need a spring compressor for the fronts at least). My current dd is a bug turbo, and if you timed me, I think I could do the rears in less than 10 minutes for both, and maybe 30min a side for the fronts. I just did it in my driveway after work this past summer. While you are in there, you can throw in some camber plates too Alignment after all that is a good idea as it will change a bit - the camber change is usually beneficial but it tends to change toe a bit too (usually toe-in) which is good to reset.
twin fed1175.50 |
12-07-2016, 09:56 AM | #7 |
Rep 176
12-26-2016, 12:42 AM | #9 |
3137
Rep 2,953
KW HAS requires removal of the rear shocks to swap the bump stops. The installation is on par with a full coil over system. Labor rates vary, but actual installation time will average out at about 3 hours.
Springs like H&R will usually run about an hour to an hour and a half. |
12-26-2016, 11:51 AM | #10 | |
Rep 3,951
01-04-2017, 04:48 PM | #11 | |
3842
Rep 54,352
Drives: F80 M3
01-05-2017, 07:44 PM | #12 |
Rep 485
So I'm guessing if $580 to install springs + $180 for alignment is a bit much, then 8 hours at $195/hr for coilover install and another $250 for alignment ($1810 total) is *slightly* off the deep end? (actual dealer quote)
01-06-2017, 01:46 AM | #13 |
Rep 1,153
Dinan quotes 9.2 hours, including alignment, for installation of its coilover kit...
