M2 Technical Topics > Track / Autocross / Dragstrip > M2 Track Setup?
      10-03-2016, 08:04 PM   #1
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
M2 Track Setup?
Hello, looking for wheels size and offset ideas. Please post your track wheels setup with offset here. Thanks.
Daily: G12 750 MSPORT Weekend Car: E90 M3
      10-04-2016, 09:30 PM   #2
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Still running stock at the track but am also interested in what others are running. Thinking about a square et 35 19x9.5 with a 5 mm spacer in front. I did a test fitment with 265/30s and this will work.
JNoSol1383.00
      11-14-2016, 07:26 AM   #3
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
18x9.5 with a 15mm spacer up front and using 275/35 RE71R. All I can say is
JNoSol1383.00
      11-14-2016, 10:13 PM   #4
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
What is the front wheel offset?
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      11-15-2016, 07:23 AM   #5
MilehighM3
MilehighM3's Avatar
2009 E90 M3  [6.50]
Sorry I left that out! All 4 wheels are ET35 Rays ZE40.
      11-15-2016, 09:48 PM   #6
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
Thanks, but now I am a little puzzled with the spacer size. You really meant 15mm, not 5mm?
Sorry for all the questions.
      11-16-2016, 09:04 AM   #7
David@ActiveAutowerke
15mm is likely correct.
We're running 18x10 et35 with 275/35/18 and using a 12mm spacer up front to clear the strut.
      11-16-2016, 04:31 PM   #8
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
I was thinking that if the wheel is 9.5 inch (i.e 12mm narrower), one can use a slightly smaller spacer while keeping same distance strut side. However, this would mean the wheel would be slightly in from the fender.
I am a little averse to tracking with larger spacers, as I had a mishap once, (which could have been a fluke) So trying to limit my spacers to 5mm.
Thanks
      11-16-2016, 10:06 PM   #9
MilehighM3
MilehighM3's Avatar
2009 E90 M3  [6.50]
No I meant 15mm. The car has Clubsports installed and needs the inner clearance. The wheels sit perfectly flush at -1.5 camber up front. The spacers are not ideal, but it's what's necessary on this car to keep a square setup and the ability to rotate the tires. Custom wheels can fix that, but the ability to rotate is nice. I just make sure to check the torque on the wheel studs when the wheels are off and the lug nuts before each session.
      11-17-2016, 06:47 AM   #10
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
Aaah! That explains it! Thanks
      11-19-2016, 11:33 PM   #11
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Does the tire stick out past the fender with this setup? I bolted a 18x10 ET25 with 285/30/18 Hoosier to my M2 and it stuck out a lot.
      11-21-2016, 07:34 AM   #12
The Hoosier will be a bit beefier than our street tire, but no it sits inside of the fender with -2.5* camber.
      11-21-2016, 08:38 AM   #13
CosmosMpower
2051
Ah ok the camber must be the difference also the hoosier was a 285. I may try and stuff some 275's on my 18x10 ET25 EC7's once I can get -3 camber.
The rear has more clearance issues than the front on the M2, correct?
      11-21-2016, 08:56 AM   #14
No, the rear could probably fit a 295 or even a 305 if you built a wheel to extend inside another inch or so.
We chose to run an et35 (which limits us to a 275 in the rear) so that we could cut all 4 wheels with the same offset and simply run a spacer up front to make it work which would allow us to rotate front and rear wheels without any issues. If you cut a staggered set you could get away with a 275/295 stagger with an 10.5-11" rear wheel.
      11-24-2016, 05:07 PM   #15
CosmosMpower
2051
What rear wheel offset would you use if you went 10-11 inch rear wheel, +25?
How big of a spacer do you use on the front with the +35 wheel? I may be wrong but it did not seem like I had a lot of strut clearance at full lock with a 18x10 +25 EC7. The tire was a 285. I'm on stock alignment
      11-28-2016, 07:21 AM   #16
We run a 12mm on the front (effective ET of +23mm) which would give us about 2mm more clearance than your +25mm.
I haven't measured the inside clearance on the rear exactly but if I ran a 10.5 or 11 the offset would have to be higher, closer to +47 or so with the 11" wheel.
Tags
bmw m2 track wheel, bmw m2 wheel, offset track, signature wheel
