11-29-2016, 09:18 PM | #1 |
Rep 51
Acceleration Lag
Maybe I'm crazy or just not used to "modern" cars.
Had my M2 for almost 2 months just went in for the 1200 mile service today. Keep it in Comfort mode most of the time (highway commute). It feels as though acceleration is a bit laggy. Sometimes with a slight hesitation. Normal? Am I doing something wrong? Thanks. |
11-29-2016, 09:26 PM | #2 | |
Rep 39
In comfort the ecu doesn't give you everything at once to make the ride more "comfortable" and not jerky. |
11-29-2016, 11:57 PM | #3 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
FBO-PS1 and stuff
11-30-2016, 12:10 AM | #4 |
Rep 290
also, in many parts of the country, the streets and tires are cold (< 45 F)
that means traction control is going to pull throttle until you finally get grip, which could be as high as 50+ mph. even in Sport+ traction control is enabled (but allows a tiny bit of wheel spin) not sure if that's what's happening in your case, but it's worth mentioning since it's nearly winter |
11-30-2016, 02:47 AM | #5 |
Rep 2,577
I do noticed a lag, which is different, or should I call it not-responding-at-all to be more precise, that happens occasionally. That is when you lift throttle, hold it for some 2~3 seconds and slightly push again. It looks like computer thinks you'll be cruising when you lift and not pushing it immediately, therefore it does not respond to that slight input.
I am close to break in service miles, but it still happens occasionally, even in sport mode. You will have to give more gas in that situation to wake it up. It probably comes down to driving style and it can be just me that's experiencing it. Not a problem at all, just reporting my findings.
Lemania 2320
11-30-2016, 05:36 AM | #6 | |
Rep 1,644
11-30-2016, 05:43 AM | #7 | |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
11-30-2016, 06:50 AM | #8 |
Rep 287
Ditch comfort mode... cannot stand the desensitised throttle input.
Sport mode and above keeps me happy. |
M3 Adjuster7904.50 |
11-30-2016, 07:08 AM | #9 | ||
Rep 2,577
Have 328 and had A45 AMG. Both are much less responsive than m2, which is maybe why I felt "normal" when experiencing the same kind of "lag".
Lemania 2320
11-30-2016, 07:11 AM | #10 | ||
Rep 2,577
Mine is a DCT and I wasn't completely off gas when I "lift and hold". Overall, I think m2 n55 is the most responsive and quick spooling engine in the market.
Lemania 2320
11-30-2016, 08:13 AM | #11 |
Rep 176
I must admit the M2's engine feels incredibly linear in it's delivery and spookily N/A like. It's just a progressive wave of torque. Supremely good power delivery to be honest.
11-30-2016, 08:18 AM | #12 | |
Rep 571
When you lift your foot off the accelerator you close the T body and this leaves air in the intake pipe that can go back against the turbo if it is not sent somewhere - bov steps in to get rid or recerculate. if you are very quick it could be in a state of no air in intercooler or pipes so it now has a void, turbo spools to fill the void and you have a little lag... At least that is how I have always understood it |
SeanWRT3179.00 |
11-30-2016, 10:07 AM | #13 | ||
Dejan
1753
Rep 4,197
There's also no BOV, only a diverter valve and a waste gate. But yes in relative terms the recirculating air and the lag of the turbo regardless of it being a twin power variable vain it'll still lag. S55 made use of the twin turbos and has much better response time and virtually no noticeable lag.
FBO-PS1 and stuff
11-30-2016, 12:25 PM | #14 |
Rep 41
11-30-2016, 12:35 PM | #15 |
Rep 576
Welcome to turbo lag. Modern cars hide it really well but get up and go from stop is apparent regardless if computer applying full throttle to get turbos going.
No lag is what u want, go for big V8 American muscle. |
11-30-2016, 02:15 PM | #16 | |
Rep 41
@Dejan_: Even S55 has a noticable turbo lag and in addition even more "all or nothing" characteristics than N55 or B58 Last edited by mmmpassion; 11-30-2016 at 02:23 PM.. |
11-30-2016, 02:38 PM | #17 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I only have a few hundred miles on mine but I haven't experienced any turbo lag in sports+ mode. I'm not an overly aggressive driver so I assumed I would spend most of my time in comfort mode but I can't stand the throttle response in comfort mode. The throttle response in sports+, which is great, should be the throttle response in all the driving modes. Use the the various driving modes to dick around with traction control, steering, suspension, etc but leave the throttle alone. I don't care what kind of mood I'm in if I punch the gas I want the damn thing to go. It feels so dead to me in comfort mode.
SoCalRob281.00 |
11-30-2016, 04:34 PM | #18 |
Rep 51
Thanks everyone, sounds like I'm not the only one, and comfort mode being the main culprit. Will give sport+ a try.
After the 1200 mile service the response may have improved a bit or its all in my head. Curious, does anyone switch driving modes while driving or usually set it once and forget it? |
11-30-2016, 05:57 PM | #20 | |
Rep 1,298
Only time i would ever switch modes is when i get on the highway and going to be cruising at the same speed for a while, i put it in comfort. |
11-30-2016, 09:16 PM | #21 |
Rep 176
That actually surprised me when I test drove an M3. Noticeably more lag than the M2's N55. But damn that thing loved to rev; seemed to breathe much easier in general.
11-30-2016, 09:31 PM | #22 | |
Dejan
1753
Rep 4,197
The design of the s55 low inertia variable vane and those impellers never stop spinning. It's optimized by impulse charging and flow enhanced manifolds. This is all directly from BMW archives. I've had 2 N55 cars for the last 5 years, I recently drove and M4 and the difference in response in favor of the s55 was night and day. You sure you had that M3 in sport/sport+?
FBO-PS1 and stuff
