11-27-2016, 11:23 AM | #1 |
Rep 75
First Problem with M2
About 1070 miles on the M2, a month old, normal drives.
Just have my first problem, the right back break light went out, wtf? See pictures, one bulb not lighting up. Anyone experienced this? |
11-27-2016, 11:39 AM | #2 |
Rep 906
WTH!!!???? This should not happen!!! Its a lemon. Demand that they buy it back!!
Sorry.
1974 R90S (SOLD)
2017 M2 AW MT (SOLD) 2020 Tesla Model 3 Performance (SOLD) 2023 M4CX - RIP - WGI Turn 9 2024 M4CX - Week 39 |
ried791.50 |
11-27-2016, 11:45 AM | #3 |
Rep 75
11-27-2016, 11:51 AM | #4 |
Dinosaur supervisor
3030
Rep 4,214
Since you ordered a car with a break light it is quite obvious it would break?!
8
waynelubin4.50 zenmaster1576.50 JTO245274.50 BMWBIASED28.50 idontkickpuppies10.00 Rock Sweden268.00 Kash63.00 BMWZ41909.50 |
11-27-2016, 12:20 PM | #5 |
Rep 709
Yeah. I would suggest going back to BMW and asking them to supply a brake light. That should work better.
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
4
11-27-2016, 12:45 PM | #6 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
time to upgrade all the lights to LEDs
11-27-2016, 01:03 PM | #8 |
Rep 7,594
Drives: '19 M2C
It's a bulb....
www.ReTuneTheDeTune.com
11-27-2016, 02:00 PM | #10 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Trade it in before anything else breaks.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
CommitConfirm474.50 waynelubin4.50 |
11-27-2016, 02:59 PM | #11 |
Rep 844
So minor problems like this should be covered by BMW or not included in the warranty?
11-27-2016, 03:33 PM | #12 |
Rep 3,295
Clearly you are over using the brakes...try downshifting instead
Mike
waynelubin4.50 twin fed1175.50 |
11-27-2016, 04:50 PM | #13 |
Rep 44
I had the same problem with my 2005 Land Rover Defender. After 8 years one of the tail light globes failed. Potentially dangerous situation.
Had to rectify it as soon as I noticed it. Sorry couldn't resist Not sure if there are multiple light globes in the housing, but should be an easy replacement by the dealer next time you are near. Cheers, Ken Last edited by Mudnut; 11-27-2016 at 04:58 PM.. |
11-27-2016, 05:36 PM | #14 |
Rep 3,295
Did a check engine light point to the bulb? or did you just notice it?
Mike
11-27-2016, 06:16 PM | #15 |
Rep 15
11-28-2016, 12:23 AM | #20 |
Rep 75
Update: I think my car is either haunted or BMW is pranking me, malfunction light alert disappeared and brake light started working properly... for a couple minutes then broke again.
11-28-2016, 12:43 AM | #21 |
Rep 44
I would still take it in and have them look at it. If it is like my old X5's tail light assembly, each globe slot was live (or negative. not sure which), and the main brake light shorted out, and burned a section of the assembly metal. Was too expensive to buy a new assembly, so ended up soldering a bit of the metal, to form a bridge across the damaged section. Worked well for the next 5 years until I traded it in on a new one.
Still should not be a problem, especially under warranty. Ken |
11-28-2016, 03:29 AM | #22 |
Rep 60
Mine did this last week too! So open the boot/trunk/rear orifice. Two little plastic flaps on the light assembly open to reveal an M6 flange nut under each flap. Remove with a 10mm AF socket. No need for a ratchet or breaker bar (!) if you have a screw driver handle attachment. Wriggle the light assembly and it will pop out of its home. Discoonect the harness and retire to somewhere cosy with your lamp assembly. Carefully pop the clips and separate the front and back housings. You will see a multitude of individual bulbs. Mine didn't look blown so I used a battery to find the recalcitrant globe. A replacement globe A$1.15 from the local service station and back together. All good. The warning light resets once you press the brake pedal.
This is not a how to just what I did and if you drop the light or scratch the paint it was a dingo. My bulbs were Hungarian. |
