11-08-2016, 04:44 AM | #46 | |
Rep 346
Cruise control set for 120, speed zero, RPM 700. Sure it's not perfect, but in lighting like that, the gauges on my 328i and my B180 become sub-optimal so did the gauges on the RS3 I test drove. Expecting the dials to become back-lit in bright sunlight is unrealistic. Again, I'm not saying its perfect, or that this is acceptable all the time (because it clearly doesn't happen all the time) but if I was going to complain about safety, I'd start with side impact protection being so poor that BMW had to move the seats inboard and cant them outwards to gain extra room for deformation. |
11-08-2016, 07:14 AM | #47 | |
Rep 486
Also, this isn't in bright sunlight. In bright sunlight, you can see the gauges. This is overcast or driving through wooded areas in the shade. The contrast is bad. Period. You can try to justify it all you want, but at a quick split second glace at 50 MPH, by the time your brain registers what's actually going on with your speed, you've traveled 150 feet or more. If it takes longer than a glance to ascertain your speed, that's not good. In real life, it does take longer than a glace (phone cameras add light and make it look brighter than it actually is). Add more time if you're wearing sunglasses. We can all be armchair/keyboard warriors about this but until you experience it, it's a lot better in pics and a whole lot easier to see than it looks. |
Chuck W.356.00 |
11-08-2016, 09:00 AM | #48 | |
Rep 346
Go to 10mins 51s In BMW's defence, it's more to keep up with more demanding side impact safety requirements without having to reengineer a chassis that probably won't be in production for too much longer (otherwise they'd just have reengineered the chassis, duh. |
blackholescion272.50 |
11-08-2016, 09:46 AM | #49 |
Rep 3,714
11-08-2016, 11:00 AM | #50 |
Rep 372
Mine is. In the right environment I cannot see the gauges at all. It happens a couple of time a week...
'01 M Roadster, '24 BSM M2
Nine Lives602.00 |
11-08-2016, 12:11 PM | #51 |
Rep 39
I'm in the camp that is hoping BMW can do something to improve this situation.
After a week of daily driving my 2017 M2 (in southern California sunshine), my only daily gripes are the dim instrument display and the iDrive intro/warning message. I'll plan to code out the warning message eventually. Wish I could do the same for the instrument panel situation. |
11-08-2016, 12:23 PM | #52 |
Rep 3,949
Same on my 17. They are all the same.
11-08-2016, 01:03 PM | #53 | |
Rep 886
The difference of guessing what speed you're travelling at and being able to read what speed.... |
11-08-2016, 01:24 PM | #54 | |
Rep 13,093
That's why I plan to install the 'P3 gauge' later this week inside my M2. Problem solved: real speed properly visible as much as I like. Expensive work-around to remedy this BMW fail ? True, but I wanted to get this sorted out + OBC showing other data (preferably navigation with Speed Limit Info) than the small digital OBC speedometer. BMW, get your act together. The poor readability of the M2 instrument panel in overcast lighting conditions is a damn nuisance and a shame for a premium car.
///M is art ↔ Artemis
11-09-2016, 11:46 AM | #57 |
Rep 486
This is still a problem. The car dims the gauge cluster regardless of the lights being on based on ambient light. You can have the lights on and the gauge cluster will have the lights off during the day.
11-10-2016, 12:47 AM | #58 |
Rep 417
Well, that's not the case with my car. I turned the lights on and the dials on the instrument cluster lit up.
F82 M4 | 6-speed manual | PP performance Stage 2 tune | Re-valved Bilstein B16s | VRSF midpipe | OEM CS front splitter | OEM GTS hood | OEM M-performance rear diffuser| Evolve tuning catless downpipes | 310rwkw (415rwhp)
ilovewagons425.50 |
11-10-2016, 04:03 AM | #59 |
Rep 77
Drives: 2020 BMW M2C
the pictures of this issue are alarming. I don't understand the thought process with a company that doesn't understand the basic requirements of being able to read the gauge(s) at all times. The font color for the fuel gauge is bright white, but the speedo / tach appear gray in comparison.
11-10-2016, 12:41 PM | #60 |
Rep 23
Interesting, perhaps it's because you're in Australia and the cars may be setup differently for that market. I can state with certainty after spending way too much time both by myself and with a BMW Genius, that there is no light switch position what will illuminate the instrument and panel lights except in the evening/night.
11-11-2016, 03:01 PM | #61 | |
Rep 3,714
11-11-2016, 03:44 PM | #62 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
I was noticing today that it is pretty dim. Sunglasses make it worse. It hasn't been a huge problem but definitely an oversight by BMW.
11-11-2016, 04:28 PM | #64 |
Rep 1,298
11-11-2016, 05:17 PM | #65 |
Rep 3,402
I also use the digital speed display. Wish BMW made it larger. Personally I can't wait for these analog gauges to be a thing of the past. A analog speedometer is pretty much useless and totally imprecise, the tach is the only display that benefits from that layout. I like what Ferrari, McLaren and Audi are doing.
atxsk8r1568.50 |
11-11-2016, 09:01 PM | #66 | |
Rep 13,093
And for the digital part of the instrument cluster: BMW, please note that there is *definitely* a good and proper reason why the competition permanently shows a digital speedometer in big digits in its high performance cars. Don't bury the digital speedometer with small digits in a scroll-through OBC (reducing the use of other OBC info that we prefer) - maybe keep that layout for the 'regular' 2er. Evidently, high performance cars are a 'liability' to exceed speed limits in a few moments by just a strong push on the throttle + observing speed limits in everyday life is important if you want to stay out of trouble. So, yeah, a properly readable speedometer *is* important in a high performance car that's supposed to be used outside the race-track too.
