M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Hub alignment?
      09-23-2021, 09:29 PM   #1
sevenmarc
sevenmarc's Avatar
Drives: 2017 LBB f87 M2
Hub alignment?
I need to get an alignment soon. Most independent shops are quoting me around $100, and the dealership wants $269. My SA (great guy) shared that BMW does a wheel hub alignment for cars with electric steering instead of a wheel alignment in order to get the most precise alignment possible.
Can anyone shed more light on this? Is it worth nearly 3x the price if I can't find an Indy shop that can do the same for a more reasonable price?
      09-24-2021, 03:54 AM   #2
M Fifty
844
Drives: M2 & 330CI
If it's a BMW dealership, they will be doing a full 4-wheel alignment, including the rear camber. And it will use the BMW KDS (made by Hunter) system - which can be seen in operation on YouTube - but appears to mount to the wheels.
BMW hourly workshop rates are always going to be higher than an independent, as they have to pay for all those front of house staff (such as your SA) somehow.
HTH
      09-24-2021, 06:53 AM   #3
sevenmarc
sevenmarc's Avatar
HTH
Thank you for those details! Does this system provide significant benefits compared to what you'd find at an Indy?
      09-24-2021, 07:43 AM   #4
Megator
Megator's Avatar
518
Drives: M2 Competition
HTH
At the end of the day the machine doesn't matter so much, the operator makes the difference.
It's very very hard to be accurate to .0X degrees as the alignment will change ever so slightly as you tighten up the bolts. Also there is a bunch of squishy rubber in the suspension. Jack/Lower the car up 3 times in the same spot and the alignment specs will change ever so slightly, just because of how the car "lands" and loads the suspension/tires.
Do you even need an alignment? Unless you have hit something, changed the suspension, are tracking, or have uneven tire wear I would leave it alone. The setup does not need to be perfect as it's constantly changing (also changes as the suspension compresses).
I would do it at BMW or the best alignment place near you. Don't take it to the cheapest mofo out there as you can easily screw up the lower rear suspension arms. The shoulders the the camber bolts sit on are super soft, and if you don't undo them right will get damaged (lock the bolt, twist the nut).
      09-24-2021, 07:47 AM   #5
sevenmarc
sevenmarc's Avatar
Thank you for your feedback! I'll probably go with the independent shop then.. they're a reputable place. Definitely not a jiffy lube or someplace like that.
