12-26-2019, 04:57 PM | #45 |
Rep 391
Drives: F87 M2C
That's pretty good clearance around the caliper for being a 19" or at least looks that way from the pictures. Maybe just too dark to see.
Also, if the tire is the part hitting the fender liner, does the width of the wheel even matter that much?
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
12-26-2019, 06:16 PM | #46 |
Rep 198
The closer the tire is to the fender when the wheels are straight, the closer it is to the fender liner at full lock. So yeah, width and offset matters.
12-30-2019, 01:38 AM | #47 | ||
Rep 2,808
I don't think what you say makes sense, if you try and visualize it. A 19" wheel is a 19" wheel... Can we agree at least the diameter would not be different? And either one -- regardless of width -- has the exact same tire on it and therefore the exact same overall diameter. Tell me how the width can make any difference? It's not the wheel that's hitting the fender... |
12-30-2019, 03:46 PM | #48 | |
Rep 900
2019 M2 HS 10000km and counting
12-30-2019, 04:18 PM | #49 |
Rep 198
I have 255/35R19 PA4s on the front and I have no rub. Stock suspension. Stock wheels.
12-30-2019, 04:43 PM | #50 | |
Remove Before Flight
6825
Rep 1,611
I'm wiped out, so maybe I missed a memo. R. |
12-30-2019, 08:13 PM | #51 |
Rep 900
01-04-2020, 04:12 PM | #52 | |
Rep 3
Drives: M2C 2020; X3 M40i 2018
Flow one wheels
thanks |
01-04-2020, 04:34 PM | #53 | |
Rep 3
Flow one
Yesterday, this note came with the Tire rack delivery of the 10 inch Flow one F2s: Note: Reuse O.E. lug hardware. Aggressive fitment. May require fender modification for proper clearance. |
01-04-2020, 07:58 PM | #54 | |
Rep 4
01-05-2020, 08:42 PM | #55 |
Rep 438
I ordered my comp with the 437m wheels and will eventually buy summer wheels.
Keep the factory wheels for winters , mounting sotto zero 3s on them- 235/35 255/35 Little thin, but still safe on those size wheels . Thinner is better in winter too if you get into deeper snow situations . Last edited by ROBM2C; 01-06-2020 at 09:41 AM.. |
01-06-2020, 02:24 AM | #56 | |
Rep 1,477
06-29-2020, 09:19 PM | #59 |
Rep 44
Drives: 2020 M2C
Thread revival. I just got my M2C and I'm wondering if any F80/F82 winter wheels fit on this? Thanks
06-29-2020, 09:29 PM | #60 |
756
Rep 2,149
06-29-2020, 10:52 PM | #61 |
Rep 44
Drives: 2020 M2C
Yea I have the Silver brakes and doesn't look like 18" will fit. I actually didn't know 18" wheels fit on M3/M4, I thought they had the same brakes
09-11-2020, 03:44 PM | #62 |
Rep 42
Hey guys, I’m new here since I sold the F80, and now have an M2C. I have a set of OEM wheels remaining from my F80, 19x9 and 19x10.
Anyone here runs 235/40-19 and 255/40-19 on their M2C for winter ? Theses are tires I had on my F80.....if yes, any rubbing ? Thanks in advance ! |
10-19-2020, 07:32 AM | #63 | |
Rep 166
10-19-2020, 10:02 AM | #64 | ||
Rep 4,516
As per my comment above - if using 40 profile on 19" wheel you'll need more than a heat gun, a stick and cold water spray....
Current '22 X3M LCI.. |
10-19-2020, 02:13 PM | #65 | |
Rep 166
10-29-2020, 01:39 PM | #66 |
Rep 339
Drives: 2020 M2, 6MT
I've read through a couple threads and have seen conflicting info, so hoping to clarify. I'm looking to mount Michelin PA4s on the stock 788m wheels.
1) Can I do a square setup with 245/35? Or will that be a stretch for the rears? Or 2) will I be ok running a staggered setup, 245/35 and 265/35? I thought I read someone's post where this rubbed due to a different profile than the PSS Thanks! |
