12-18-2017, 09:26 AM | #1 |
Rep 281
homelink, UDGO, garage door opener
Has anyone had any trouble with the homelink or programing the buttons under your mirror?
I have followed the instructions, hit the learn button on my garage door about 5 times, each time resetting the codes in the car by holding down button 1 and 3 for 20 seconds. I then hold the button 1 down for 3 seconds about 2-3 times, never works. My 18 bmw had the gauge cluster stop order, anyone else having problems Just picked up car 12/14/17 |
12-18-2017, 11:17 AM | #2 |
Rep 4,203
What is in the manual works..... you sync the remote to the button first then you sync the head unit if it has a rolling code. You need to delete previous memory like the manual states
12-18-2017, 11:21 AM | #3 | |
Rep 281
Had many bmw's, this is the only one I cannot get to work |
12-18-2017, 03:02 PM | #4 |
Rep 281
UDGO FYI
FYI
Talked to SA, buyers of differrent models are having a problem with UDGO. He said he had went to several homes, all having a problem with sycing the garage door with the 3 buttons under your mirror. He said he went to 1 home, he never got it to work. Some having new Garage Door openers, I should have asked what type they were and what year cars it effects. He told me to call homelink and ask them to walk me thru the steps. Best advice so far, I thought I had every permutation but must not have. Only had the M2 for 5 days now. Hope this helps if your having problems with garage door opener. |
12-18-2017, 09:30 PM | #5 |
Rep 281
Found solution for liftmaster securty +
Finally got my UDGO to work, it was exactly as my SA described. It is a combination of both methods in the manual.
Once I cleared what was stored by holding buttons 1 & 3 in the car for 20+ seconds, then
FYI, my garage door was installed in 2004, its a Liftmaster Professional Model 976LMC Security + Hope this helps http://www.bimmerfest.com/forums/sho...d.php?t=834658 |
spellbmw58.00 |
12-19-2017, 08:37 PM | #6 |
Rep 4,203
Like I said...the manual states this if you have a rolling code type opener which most do anymore. Glad you got it to work
Now if someone could come up with a way to program our entrance gae=te to one of the other buttons that would be genius |
