12-15-2017, 05:02 PM | #1 |
Rep 1,466
LCI Coding Changes Post Break In
I got my LCI M2 serviced yesterday at 1,250 miles, and because I was a little worried about the dealer objecting to things I'd coded, I set everything back to default the night before I took it in.
When I got the car back, all of my presets had been lost, so clearly more than just the instrument cluster had been updated. Once I got home I started the process of putting the coding that I wanted back on, but before I made any changes, i took a full read and backup of the FA, SVT and Coding data post updates. Once I had the new 'factory' backup, I compared this to a few things:
Module - Version Before - Version AfterMost of the modules that were updated only had things like Coding Date, Dealer Number, Factory Number or CAF_ID changes, which I think is basically irrelevant, but a few modules had more interesting changes. DME2 [12] had 3300 BSR-Config -> VMAX-Codierung changed from C3 to CB HU_NBT2 [63] had two new sections that weren't present before; I'm not sure what they do KOMBI2 [60] had three new sections that weren't present before; I'm not sure what they do FEM_BODY [40] had a lot of changes to things related to lighting: Section -> Sub-section: Coding Before - Coding AfterThe lighting changes surprised me, which is why I compared this to the result of what VO coding would have achieved, but indeed, the result was the same. I don't have any take away from this, but I thought it was interesting, so I'm posting it in case anyone else is...
2018 ///M2 LCI, LBB, 6MT...
12-16-2017, 03:27 PM | #3 | |
Rep 413
12-17-2017, 03:15 AM | #4 |
587
Rep 898
Does your car have the M drivers package? The CB coding is for cars with the increased speed limiter which I believe is applied via coding and FSC code on break in service.
12-17-2017, 10:22 AM | #5 | |
Rep 1,466
beppeM3+123d203.00 |
12-17-2017, 10:24 AM | #6 | |
Rep 1,466
That would be pretty cool if the limit was removed, though I don't think I'll actually ever get a chance to test it, let alone make use if it! |
12-17-2017, 11:19 AM | #7 |
Rep 1,466
I had a few minutes this morning, so sent. Let me know if you need anything else.
12-19-2017, 11:26 PM | #8 |
587
Rep 898
Can you PM me your cafd for the DME? I need to compare. Its possible I wiped my M drivers package when doing a software update. I'll dbl check the next time I throw ESYS on.
