12-10-2017, 06:47 AM | #1 |
Rep 1,718
For those of you with MPE
Those in NA who have the MPE and the accompanying Bluetooth remote (button to actuate the flaps to "track" mode)...
Has anyone found a good way to integrate this button into the car in a good (clean, factory-esque) way? I find it annoying to have this thing rolling around in a cup holder or the door storage pockets. Looking for an innovative solution. |
12-10-2017, 08:53 AM | #4 |
Rep 4,203
12-10-2017, 09:07 AM | #5 | |
Rep 258
AndrewC198910931.00 |
12-10-2017, 10:39 AM | #6 |
Rep 4,515
If you wanted to keep the 12v socket - why not mount mpe BT remote in one of the F2x/F3x optional storage add-ons that fit into cup holder ie as per right hand side in the below:-
12-10-2017, 03:56 PM | #8 |
587
Rep 898
I've been looking into reverse engineering the bluetooth controller signals and seeing if theres a way to build an app to activate this.
12-10-2017, 04:38 PM | #9 |
Rep 169
The Macht Schnell EVC Module integrates it to the turn signal, it also removes the check engine light for catless DP.
https://ind-distribution.com/product?sku=40.00.100 Last edited by BSMF87; 12-10-2017 at 05:05 PM.. |
12-11-2017, 08:30 AM | #10 |
Rep 1,718
I noticed in the video for the Macht Schnell EVC Module that each time you press the BC button, it is also changing the data shown in the cluster display (the factory purpose for this button). I like to have my fuel/100km info displayed at all times. Seems like if I am having to press this button to also actuate the exhaust flap and this is simply open or closed, it would be difficult/annoying to determine the correct number of button presses so that the exhaust flap will be open AND the desired data is displayed on the cluster. Otherwise it's an interesting solution.
As for the cigarette lighter mod, I would not like to lose the charge port functionality. However, this did give me an idea...I'm wondering if anyone has tried using the "blanks" under the headlight switch? I believe in Europe these buttons are used for the rear fog lights and presumably the front fogs in a regular 2 series. Seems that provided there is enough room behind the button to house the blue tooth control unit, it would simply require a hole to be dremmeled out matching the size of the control unit. One additional question...I assume the MPE control unit uses batteries? Has anyone had to replace theirs yet? If so, what type of battery and is it easy to replace? |
12-11-2017, 10:17 AM | #12 |
Rep 2,924
I just wish I could leave the valves open permanently.
Otherwise, I have it placed in the cupholder: fits perfectly.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
12-11-2017, 12:08 PM | #13 |
Rep 752
Get the BMS CAN Flap Module it’s awesome, you can just leave it open all the time or close it OR leave it in stock mode right from the BC button. It also has other features like disabling ASD! I love it. Connects to the OBD and you can hide it behind the plastic trim. Or you can unplug the valves and it’ll stay open always.
12-11-2017, 01:13 PM | #14 | |
Rep 1,718
I knew this combo was going to be loud...but sweet baby Jesus it is loud. |
12-11-2017, 01:26 PM | #15 | |
Driver
391
Rep 650
12-12-2017, 12:44 AM | #17 | |
587
Rep 898
That said, I'm working on reverse engineering this soon enough. If I can't decode the BLE services, then I'll invest a few $ to get a BLE sniffer to get this project going. Project here: http://f87.bimmerpost.com/forums/sho...php?p=22527558
NO_USER_537.50 |
12-12-2017, 04:34 PM | #18 |
Rep 4,551
Drives: 2015 328d xDrive
You can.
http://bimmerlink.com/ Lets you control the valves through your phone. Will stay open/shut/auto. I use it with my Remus exhaust (2 valves). Works perfectly. |
NYC Bimmer259.50 |
12-12-2017, 06:37 PM | #20 |
Rep 155
You could open the flaps, then unplug both of them. I'd assume they wont close with no power or signals?
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
12-13-2017, 12:04 AM | #21 |
587
Rep 898
Correct, but its LOUD. I should have a proof of concept within a few weeks
12-13-2017, 12:17 AM | #22 |
Rep 4,551
horsepower_and_hounds1836.00 NYC Bimmer259.50 |
