12-08-2017, 08:02 AM | #1 |
Rep 294
Where is everyone buying their spacers from?
Looking for 10mm spacers on all 4corners when the car arrives.
Haven’t really found a website to do all my ordering from for the M2. Thanks. |
12-08-2017, 09:21 AM | #2 |
9586
Rep 10,877
We offer Macht Schnell which is very popular.
Here we did 10mm in front and rear. Car is lowered on KW HAS kit.
jessetaylor1171.00 norberts84.50 |
12-08-2017, 09:36 AM | #4 |
9586
Rep 10,877
The Macht Schnell spacer kit comes with all new extended black wheel bolts.
12-08-2017, 11:04 AM | #6 |
9586
Rep 10,877
Yes, alignment should be done after installing any suspension. No rubbing on the setup listed above.
12-12-2017, 02:01 AM | #10 |
Rep 155
Ezaccessory.com is a high quality and affordable option. Been through 3 sets and they were just as good as my other name brand spacers.
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
12-15-2017, 02:08 PM | #11 |
Rep 752
I purchased BMS ones from Burger Motorsports directly, perfect fitment and no vibration with their spacers. Great quality too! Although you can’t go wrong with the Macht Schnell ones from IND!!
12-15-2017, 05:03 PM | #12 |
Rep 960
When spacers are not hubcentric (with a lip, i believe there’s a lip in the center bore are after 12mm, maybe 15mm)...you can tighten the lugs in a star pattern to eliminate vibration. Then again. You should probably be tightening it in star pattern anyways.
12-15-2017, 08:32 PM | #13 |
Rep 650
12-15-2017, 08:45 PM | #15 |
Rep 752
12-27-2017, 06:22 AM | #19 |
Rep 156
Yep, same here, excellent build quality, perfect fit and NO vibrations at speed!
F87 M2 | DCT '17
E46 M3 |SMG '06 E46 M3 | SMG '03 E30 320iS | '90 E28 M535i | '84 |
12-27-2017, 01:35 PM | #20 |
Rep 752
