M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Oil Filter PN Question
      11-15-2017, 09:58 AM   #1
mokrunka
Drives: 2017 BMW M2, 2011 BMW 335i
So I was going to buy a filter for my '17 M2 to do an oil change, and I noticed that the PN was different than for my '11 335, which sort of caught me off guard. I guess I had expected them to be the same.
'11 335: 11427566327
'17 M2: 11427854445
Even more interesting is that the filter shows to be the same for the F80 M3 and the F82/F83 M4 as it is for the F87.
Checking my receipt from break-in service, this is the correct filter number. Just thought it was interesting.
      11-15-2017, 06:44 PM   #2
horsepower_and_hounds
Drives: BMW
'17 M2: 11427854445
is it the same as the M235?
      11-15-2017, 11:24 PM   #3
mokrunka
No, the M235 uses the first part number I listed, from the E90.
Seems like the second one is M specific for some reason.
      11-30-2017, 02:07 AM   #4
cookiesowns
cookiesowns's Avatar
587
There’s a post on the forum about it. Visually they look the same. But no idea if any different. I went with the M part # as it’s only a few $ more expensive. Better to be safe than sorry... plus what if dealer sees that a non M oil filter was out in and you have engine concerns ?
      12-15-2017, 12:18 AM   #5
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
I would guess that the M-specific part has its bypass valve set to a different pressure, potentially lower. Idea being that you'd rather contaminate the engine with some grit than completely oil-starve it...
      12-15-2017, 07:03 AM   #6
123Britt
Drives: 15 M235i AT
HU816X fits both M235i & M2
      12-15-2017, 09:36 AM   #7
M2Nebula
M2Nebula's Avatar
548
Drives: M2, X1, TSX WGN
It's a paper element filter not a canister type. BMW has never used a canister type as far as I know.
ZPrime611.50
      12-17-2017, 03:59 AM   #8
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Bah, I forgot that the German stuff has the standalone paper thing that goes into the (usually plastic and easy to damage) canister. My TT and R32 both had the same... I blame mental overload from work.
Number of pleats the same? Maybe higher temperature glue in use?
I just find it very hard to believe they'd go to the trouble of making two different part numbers solely to overcharge ///M owners.
M2Nebula547.50
      12-17-2017, 08:24 PM   #9
M2Nebula
M2Nebula's Avatar
548
No worries, all my synapses firing together nowadays is becoming a rare treat.
Not sure if I like the newer system better or not? A decent amount of old oil is left sitting there in the housing when you pull out the used element. I usually just soak it up with a couple disposable blue shop rags. Plus you need to be careful not making a mess when getting rid of it. The older system was inverted 180 degrees with a metal outer canister and was a bit harder to deal with initially, but the residual old oil was collected in the canister and easier to dispose of.
      12-21-2017, 10:00 PM   #10
M2Nebula
M2Nebula's Avatar
548
Not sure the difference in design between part numbers here.
I do remember Toyota stating that their filters had something like 20% more pleats per volume than most other filters because of origami techniques.
      12-28-2017, 04:33 PM   #11
cookiesowns
587
No idea if the pleats are different. I guess there’s one way to test by weighing it. Someone want to send me a new filter ? :P. I have some super accurate scales.
That said the only notable difference I saw was that it’s made in Germany and has the ///M logo compared to a Mann OEM replacement
