11-11-2017, 01:32 PM | #1 |
Rep 3,695
Rear Toe/Trailing Arm Links
Hey guys.
I'm curious to get your input on any rear links you've tried. I installed the Fall Line rear toe links and I can't say there was noticeable change. Plus, there are faint clicking noises when going over bumps. Enough so that I'm thinking of going back to OEM. My shop has checked and everything is tight. So, have you found any links that have a noticeable impact and are silent? I know Dinan is quite proud of theirs, but not sure if it's worth the cost. |
11-13-2017, 01:41 PM | #3 |
Rep 3,695
Supposedly the OEM arms and rubber bushings will allow toe change and rear end squirm under hard acceleration. I was already having the rear alignment set, and the fall line links are pretty cheap, so I had the guys pop them in there.
Even if they are helping, the added noise bothers me so they’re coming out. I’ll go back to OEM, unless someone can definitively say a different vendor’s links helped improve rear end stability. |
11-13-2017, 03:20 PM | #4 | |
Rep 1,367
11-13-2017, 03:35 PM | #5 | |
Rep 3,695
Anyone tried Dinan’s or a different brand? |
11-13-2017, 04:46 PM | #6 |
Rep 1,367
Pretty sure that multiple people here have shown more consistent rear tire wear when using the rear toe arms...
11-13-2017, 05:12 PM | #7 |
Rep 3,695
11-13-2017, 08:13 PM | #8 |
Rep 1,367
