10-09-2017, 10:41 PM | #23 |
Rep 4,253
Good PSA to use a cloth like the "Absorber" to dry your car. Simply lay on, pull off. Never swirl, never scrape, none of that. Ultimately you may want to get educated on washing your car. The two bucket method works great if you keep things strict. If you like the wand wash you can do that too, you just need to be very thorough and again, pat your car down, don't wipe.
Definitely go to a bodyshop here. Might cost you but you'll be happy in the end.
///M Power
10-09-2017, 10:42 PM | #24 |
Rep 365
On December 31, 2017, if you look back and this is the biggest mistake you made all year.... it was a great year.
I agree with the ones that said to hand it off to a professional detailer. They can work wonders. Keep us posted and let us know how it comes out.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
hoyasaxa691.00 |
10-10-2017, 01:52 AM | #25 | |
Living the aloha
240
Rep 449
Pretty sure the Absorber is a sure fire way to get swirls in your clear coat. I’d stay far away from that. Definitely bring it to a pro and don’t try to do anything yourself. Two wrongs do not make a right, |
Dackelone10527.50 |
10-10-2017, 05:58 AM | #26 |
Rep 656
Those OP pictures! I can only imagine the horror. There is nothing wrong with drying the car with a microfiber towel, just use a clean one? Feel like there is nothing else to be gained from this thread except some beautiful “after” pictures when this episode is over, and I’m confident that will be the case |
Lieutenant Biscuits103.50 |
10-10-2017, 06:52 AM | #28 | |
Rep 29
Best of luck with the repairs |
10-10-2017, 07:59 AM | #29 |
Rep 104
I would also advise against trying anything on your own. Take it to a professional detailer.
Hopefully, it will be sorted and you will be left with some clear coat. |
10-10-2017, 08:31 AM | #30 | |
Rep 7,594
Drives: '19 M2C
I bet all of this comes out. Deep breath my friend!
www.ReTuneTheDeTune.com
10-10-2017, 08:43 AM | #31 | |
Rep 137
10-10-2017, 09:01 AM | #33 |
Rep 3,003
Not sure what type of squeegee he used but the problem may not have been the squeegee as much as the dirt on the car. I have used this in the past w/o one problem on a very wet car... https://originalwaterblade.com/us/
"Absorber" towel wouldn't have help in this case. The problem is the dirt was not floating above the surface, e.g. soap or water. |
10-10-2017, 09:11 AM | #34 |
Rep 146
Drives: '76 2002 / '17 F87 M2
Sorry to hear about that lx93! Notice you're in MA. Any idea where you are going to take it? I'm looking to have mine detailed before hibernation, so hit me up if you know where you're going/need some suggestions.
On another more positive note, congrats on the car and doing both Euro delivery and PCD! And your color choice is perfect #LBBalldayeveryday
2017 M2 - LBB, 6MT, Exec, ED (April 2017), PCD (July 2017)
Instagram - @LongBeachBlueM2 My M2 European Delivery Adventure - April 2017 / Part II - Performance Center Re-Delivery - July 2017 |
M2Nebula547.50 |
10-10-2017, 10:05 AM | #36 |
Rep 105
Unfortunately not as BMW cleverly make sure the orange peel is under the lacquer
A good pro detailer will have all that out in an hour or so with a Rupes, get it glossed over with something that has plenty of fillers and you will be good to go. Before you do anything else though, pick up that squeegee, walk over to the bin and toss it in, do it now in fact! |
10-10-2017, 10:57 AM | #37 |
Rep 61
I did something similar on a black Porsche 25 years ago. Made me absolutely sick but body shop made it new again with wet sanding.
Lesson learned. Have had multiple black and dark colored cars since then- master blaster or the like is the only way I have found to avoid even tiny swirl marks. I dont touch my cars with microfiber towels until the car is dry, inside the garage and with a spray detailer in hand- and then only very light pressure with a new microfiber towel. I now xpel and ceramic coat new cars and use foam canon, masterblaster, spray detailer and light pressure with new microfiber towels and have not had a swirl mark in years. Don't beat yourself up. |
10-10-2017, 12:51 PM | #38 | |
Rep 6,634
I use a slightly damp microfiber towel. A dry one seems to risk some minor scratching of the clear coat. |
10-10-2017, 01:02 PM | #39 |
Cars, beer, hiking
367
Rep 259
That is painful to look at!
Like everyone else said, that should all come out, and will probably look better than it did before. Trust me you won?t want to do it yourself. Will take a ton of time and a good amount of skill to fix. |
10-10-2017, 01:32 PM | #40 |
Rep 97
Damn it. I feel so so bad for you man. But nothing is lost just yet. Take it a professional and they'll take care of it. Mine came with a huge scratch on one of the panels (from the dealership, yep they suck that much). Went to a detailer and he fixed it. Now it is in PPF and all is good.
I couldn't sleep when I scratched my rim but its just like when you get a new iPhone and it drops on the floor for the first time. If the car is being driven its okay to have battle scars. Don't stress too much, I did stress at first as well but in the end everything can be fixed |
D CHOI581.00 |
10-10-2017, 01:42 PM | #41 | ||
Rep 4,253
If your car is free of grit aka properly washed, and you keep your towels separated and clean, there is NOTHING wrong with using the absorber in a lay down, lift off manner. Whereas that california water blade that seems so popular around here will absolutely punish you if there is grit attached to the blade surface. To use the blade you will need to use a two bucket method wash and be meticulous. Most people don't do this. So no I totally disagree. From experience. Quote:
I actually challenge anyone who's religiously used the water blade immediately after a conventional wand wash to put an LED light up to their car and see what all that scraping has done to the outermost layer of clearcoat.
///M Power
10-10-2017, 02:10 PM | #42 |
Rep 1,718
Agree with most of the respondents here. Take it to a qualified shop and have them "do what they do"...might cost a bit more than trying to DIY, but likely results will be worth it.
Good luck. |
10-10-2017, 03:42 PM | #43 |
Rep 150
Yeah I don't stand close with it it's actually mini master blaster I use not as strong
10-10-2017, 03:45 PM | #44 | |
Rep 13,090
Those things can happen. We all make mistakes. It sucks and makes us feel frustrated about it, but do know that in skilled hands it can be remedied. And afterwards all will be A-Okay again. Good luck !
///M is art ↔ Artemis
