M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Evo 3 FMIC Install/Review
      08-26-2021, 08:19 PM   #89
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Shoot man. I can't remember lol maybe I did make a spacer there.
Cars a 2018
M2OG400.00
      08-26-2021, 09:09 PM   #90
M2OG
Drives: a car
I guess the real question is WTF is this little thing even bracing?! I've got half a mind to just run without it...
      08-26-2021, 10:01 PM   #91
AWC-F87
AWC-F87's Avatar
437
Drives: 2018 BMW M2
Haha I know. What I have left in my car is ridiculous. I don't even think that flimsy brace before cutting it up was doing anything.
      08-27-2021, 09:34 AM   #92
boldy1
Drives: BMW's m2
A friend of mine runs his car competitively in the British time attack series and doesn't use the brace at all and swears it is no different
M2OG400.00
shaneguags1196.00
      01-12-2022, 11:29 AM   #93
TUDMG
TUDMG's Avatar
21
Alright guys. So I got my evo3 installed today (labor done by yours truly!)
The OPs original post pretty much sums up about 90% of what you need to know.
Here are the answers to what he's missing.
You need to remove the lower plastic pieces that are vertical on the sides of the IC tank. You also ditch the lower IC shroud completely. The vertical pieces kinda attach to that and then clip into the upper frame rail and the upper duct.
The piping- the white lettering faces the front bumper.
The vacuum line. I didn't want to just crank it around to the new angle needed to meet the Wagner pipe so I slowly heated it with a heat gun and twisted it where I wanted it. Off the car.
The IC bolts that connect to the bumper bar. Get yourselves to aluminum tube stock or a pipe, cut it at 2.25" and it's a perfect spacer between the IC and bumper bar. This will really make things rigid and solid. Sorry OP but how you have those bolts isn't doing a hole lot for support.
I wanted my IC to have like zero flex.
You HAVE to get the 235 v bar thing. And cut the shit out of your stock m2 brace to make little vertical lower braces. I used a 4" cut off wheel and flapper wheel. Made quick work of the aluminum.
Also need 3/4" long bolts to bolt the 235 back to the frame rails.
I think that's everything. Personally I though it was Pretty easy to do everything with the bumper off. Definitely make sure you have a good amount of tools and are handy with cars!
Any added lag with the Evo3?
      01-12-2022, 11:40 AM   #94
ZM2
Drives: 2017 LBB M2
I noticed that lag was less when going from the Evo2 to the Evo3. Likely due to the custom larger IC inlet/outlet and pipes with the Evo3
Wagner's pressure drop charts also show this.
shaneguags1196.00
TUDMG21.00
      01-14-2022, 08:52 AM   #95
mike@x-ph.com
mike@x-ph.com's Avatar
makes sense
https://x-ph.com/sale/
Phone number 702-494-9435
      01-16-2022, 05:06 PM   #96
shaneguags
shaneguags's Avatar
Drives: 2017 Big Turbo BMW M2
2017 BMW M2  [9.42]
running the evo 3 as well for my big turbo M2 setup and the car is running great. I had to get the brace modified to fit, other than that, no issues for the fitment
      01-16-2022, 05:09 PM   #97
shaneguags
shaneguags's Avatar
2017 BMW M2  [9.42]
I'm sure people just want it for the aesthetics, I figured it didn't do much to performance. my modified brace feels no difference either from before
      09-27-2022, 08:31 AM   #98
Alex33@Wagner-Tuning
Alex33@Wagner-Tuning's Avatar
Drives: 2011 BMW 135i 6MT
<3 <3 <3
      09-27-2022, 12:41 PM   #99
AmuroRay
AmuroRay's Avatar
2314
Drives: M235i
Chassis ridgity doesn’t actually make the car ‘quicker’ I remember searching and reading anything I could find about it - nada. The benefit was allowing ‘sharper’ response because whatever portion of the body being braced was less likely to flex and bend with suspension- basically changing the geometry ever so slightly.
On a NA/B Miata I can see this being something tangible, on a modern fixed roof coupe, not really.
shaneguags1196.00
      09-27-2022, 07:29 PM   #100
shaneguags
shaneguags's Avatar
2017 BMW M2  [9.42]
interesting, may look into one in the future
      09-30-2022, 10:38 AM   #101
AmuroRay
AmuroRay's Avatar
2314
Drives: M235i
Do you mind sharing any Evo 3 logs?
Mods: Yes.
      09-30-2022, 04:15 PM   #102
shaneguags
shaneguags's Avatar
2017 BMW M2  [9.42]
currently away from the car since I had to evacuate Tampa but I can try to get some. how do I share on Bimmerpost. I've sent logs to my tuner and I'm assuming I just share a link of a 4th gear WOT.
      04-11-2024, 03:38 PM   #103
Frank_M2
V-brace
I am mouthing this Evo 3 on my M2 2018 and quite strait forward. And I ended up tonight that this original v-brace didn’t fit at all. Reading this thread and have to by this v-brace part number 51647245789. Is this the only i have to order to get it fit?
      04-11-2024, 06:51 PM   #104
AmuroRay
AmuroRay's Avatar
2314
Drives: M235i
I thought it came with one? And yes, that should be all you need, but get the bolts.
Alternatively, you can cut your stock one.
Mods: Yes.
      04-27-2024, 07:27 AM   #105
feri130
Drives: M2 LCi
Talked to my mechanic this morning, and should have my car tomorrow. I threw all the PITA jobs at him (Evo3 mount/fit, turbo inlet, BOV), along with HPFP, oil, plugs, air filter, etc, so they're taking their time.
They were able to cut up the stock radiator brace and reuse it, similar to what is done with the Dinan and other FMIC's, so I hope to have some pics and info on that for you guys.
They were also able to get the Evo3 to fit with my larger CSF DCT cooler that extends down a couple inches lower than the OEM DCT cooler, so that's good news.
Lastly, the foam that's on the bumper that sits between the bumper cover is not used with the Wagner setup b/c of the cutouts in the new crash bumper for additional air flow. Not a biggie, but if someone taps your bumper when they're parallel parking there is a greater risk of cracking the bumper, vs just marking it up. Just an FYI to watch where you park.
Also going to go ahead and get my tune started with Cary Jordan, so lots more to come later this week!
Please share your infos how to fit evo3 with upgraded dct cooler, i have the do88 dct cooler and cannot fit with evo3, i have to put back the stock one. Or is the csf dct cooler smaller by a little making it possible to fit?
      04-27-2024, 07:59 AM   #106
ZM2
Drives: 2017 LBB M2
I had the CSF DCT cooler. I don’t know the size diff bn it and the do88, but it touched the Evo3, so we made some standoffs bn the two.
I’m now running the stock DCT cooler bc I’m using the M2 CSR DCT pan, which works great on track.
      04-27-2024, 01:33 PM   #107
feri130
Drives: M2 LCi
That some standoffs is what i am curious about. Anyways thank you for the infos, i appreciate it! I might try your final setup, another pan and stock dct cooler, till then only stock dct cooler.
      04-29-2024, 02:02 PM   #108
AmuroRay
AmuroRay's Avatar
2314
Drives: M235i
Are you still able to return it?
https://shopwebbys.com/checkouts/cn/...?_ga=undefined
Mods: Yes.
