M2 Technical Topics > Cosmetic Modifications > Carbonio front plate mount? Anyone have this?
      02-16-2018, 01:42 AM   #67
cornercase
Drives: LCI M2
Does anyone have longer term thoughts on their Carbonio front plate mount?
      02-16-2018, 02:34 AM   #68
just blaze
Drives: 2018 M2 Alpine White
Love it. Had it for about 2 months now. Easy on and off and great build quality.
instagram: @ sf87_m2
      02-16-2018, 09:14 AM   #69
GreyF87
HawaiiM2
GreyF87's Avatar
31
Drives: 2017 M2, 05 G35
I like it.....no problems so far.
      05-18-2018, 01:08 PM   #70
BMW604
Drives: 2018 BMW M2
Does anyone have any issues with the plate hitting the bumper? The screw poke through quite a bit that the rubber bumpers included would be too short to prevent any contact.
      05-18-2018, 01:21 PM   #71
alscks0414
alscks0414's Avatar
690
Drives: MY18 X3 M40i, MY18 M3 ZCP
Hmm I had mine on for more than 6 months and mine does now show any screw pokes. I have M Performance licence plate frame covering the plate. You may want to find a screw that is little shorter than one you have at any local hardware shop. (mine is Ontario plate)
Anyways, Never had any chance of plate hitting bumper at all.
      05-18-2018, 04:07 PM   #72
sclui56
Drives: E86, IS-F, G42, G87
Fenix, make sure your neighbor with the grey car (hitch + carrier) doesn't back into you and you should be good.
Seriously, your option is to buy shorter screws (hard to find) or add a plate frame to prevent the screws from protruding, but the backing nuts could still hit when pushed hard.
      05-18-2018, 04:40 PM   #73
BMW604
Drives: 2018 BMW M2
I will try to find shorter screws, I don't want to put a frame around it but that would take up the excess length. In the meantime, I used some double sided tape to add some length to the rubber bumpers and placed it just below the screw. As long as no one gives bumps it, it looks like it should be OK.
      05-18-2018, 06:28 PM   #74
bobert
Drives: manual shift cars
Apparently they changed the design shortly after I got mine in late Nov - my Carbonio bracket only has two screws at the bottom holding the plate on. I put the two rubber-like 'bead' things close to the top of my plate towards the middle - if the plate gets pushed up against my bumper, those two 'beads' touch it gently, and I don't have screw-backs threatening it.
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone)
      05-19-2018, 11:51 AM   #75
sclui56
Or you could try using a trimmed down screw protector, I didn't like the adhesive bumpers so got some of the nylon protector, too bad they are in yellow for that size.
BMW60410.00
      05-19-2018, 04:24 PM   #76
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
You might laugh at this, but do you try to just use a black Jiffy marker on them? A couple of coats might be good to go. It's worked for me before on similar projects. Worst case, it fades after a while. Or just Plasti Dip them.
      05-20-2018, 03:24 PM   #77
sclui56
Just tooo lazy when there are solutions, was @ Lowe's for something else and picked up these, friction-fitted to the nut:
      05-20-2018, 10:14 PM   #78
BMW604
Drives: 2018 BMW M2
They look pretty good, if only they were black. I was at Home Depot yesterday and found some white ones but will continue to search.
      06-26-2018, 02:29 AM   #79
Lotus99
Lotus99's Avatar
628
Is the license plate mounted on the Carbonio mount in its upper position as high as it goes? It looks sort of odd to me, halfway covering the grill, halfway over the bumper...
And the lower position looks odd too, with the plate halfway over the bottom of the lip... is that as high as it goes too? I'd be worried it'll scrape all the time that low.
Which position did most of you with the Carbonio mount go with?
I'm leaning towards the Sto N Sho from a looks perspective, even though it might require a drill hole.
      06-26-2018, 02:42 AM   #80
just blaze
There are photos in this thread of how pretty much everyone runs their carbonio mount
      07-15-2018, 12:15 AM   #81
300f87
300f87's Avatar
51
These M6 x 8mm (with 1.0mm pitch) screws were the shortest ones I could find:
https://www.ebay.com/itm/6mm-M6-x-1-...53.m2749.l2649
For each screw, I am using two M6 nylon washers that are 1.5mm thick, between (1) the screw and the plate and (2) the plate and the Carbonio mount:
https://www.ebay.com/itm/U-S-Seller-...53.m2749.l2649
This way, there are no excess lengths at all. I then added silicon bumpers behind the top screws, so that there is no hard contact with the bumper.
So much work for for a damn license plate mount
      11-12-2018, 02:22 PM   #82
obazavil
Drives: M2C, SO, 6MT
Thanks for sharing! do you have the ebay link for the silicon bumpers you used?
      11-12-2018, 02:57 PM   #83
BimmerAgent
Drives: 2018 M2, 1998 M3
Weather Strip or plastic tubing
I cut a small piece of weather stripping that is sticky on one side and foam on the other. That way, if and when the air pushes the plate against the bumper, it hits the foam. I also cut a short piece of clear vinyl tubing, sliced it down the middle, and placed it over the plate for extra buffering. Works well.
      11-12-2018, 05:43 PM   #84
A4W
A4W's Avatar
Drives: 2018 F80
2018 BMW M3  [10.00]
I just got mine last week and installed it. Fantastic!
Carbonio now include two self-adhesive rubber bumpers to affix on the mount to protect the bumper.
      08-03-2019, 09:15 AM   #85
snipersix
snipersix's Avatar
228
Drives: Retired 2017 F87 M2
2017 BMW M2  [0.00]
after mounting the carbonio on the grills and with the plates 3Med on it. How do you remove the mount say for photoshoot purposes? do u unscrew from the side? or loosen the screw and unhook the mount from the grills?
Retired: |2008 328i Sedan|Montego Blue|
      08-09-2019, 10:46 PM   #86
jkoral
Drives: 2017 M2 LBB 6MT
There is a knurled screw that tightens the plate bracket to the rear bracket behind the grill. Unscrew it completely and remove bracket (which just hangs).
Trickiest part for me was dropping the bracket behind the grill. You have to hold it when screwing/unscrewing it, or it's easy to fall off behind the grill (after which you need tiny fingers to fish it out).
I like the fact that when you remove the front plate, there is no bracket left behind.
Really like this mount, have never loved tow hook mounts due to the offset nature.
      06-25-2021, 04:36 PM   #87
MovingChicane
Been there and back...
MovingChicane's Avatar
Drives: Four inc. a '21 M2C
I'm late to the thread, but can someone comment on the order the bolt, washer, nut go through the two frame pieces?
From outside to inside, is it Bolt, washer, frame piece 1, spider washer, and then frame piece 2?
I took mine apart and now don't recall how it was put together...duh.
      06-26-2021, 09:41 AM   #88
HazChem
HazChem's Avatar
Drives: 2019 BSM M2C
I would think the spider washer goes first so that it binds the bolt when you tighten it. The regular washer goes between frames pieces.
