M2 Technical Topics > Suspension | Brakes | Chassis > EDC retrofit?
      07-03-2022, 09:08 PM   #1
chris719
Drives: '08 M Roadster
EDC retrofit?
Since the CS has EDC dampers, is there a way to retrofit the control to an M2C? It seems like it should be doable. I've seen the DSC Sport and Tractive systems, but I mean the OEM setup. Searched on the F80 forum and came up mostly empty.
      07-14-2022, 10:54 PM   #2
scottttt
Drives: f87 M2c
2018 Porsche 911 GT3  [2.50]
2010 Porsche 911 Turbo  [10.00]
1987 Porsche Carrera  [10.00]
2019 BMW M2  [10.00]
2011.5 BMW M3  [10.00]
2006 BMW M3  [10.00]
I am looking into doing this as well, since I have a totaled CS handy. Havent had a chance to tear it apart yet.
chris7197334.00
      07-14-2022, 11:01 PM   #3
chris719
Cool. I could be wrong but I was thinking it's basically retrofitting the springs and dampers, running the wires from the accelerometers to wherever they plug in, and the hard part would be coding and making it happy. Surprised no one else has looked into it.
      07-15-2022, 01:40 AM   #4
M Fifty
844
Drives: M2 & 330CI
The springs appear to be the same, so no need to change them.
chris7197334.00
      07-15-2022, 02:46 AM   #5
aroundelway
Drives: M2 CS
The springs are indeed the same. It is surprising to me that just a shock change can make such a difference but the CS does ride much better than the comp so it would seem like an easy and worthwhile upgrade.
      07-15-2022, 11:50 AM   #6
M Fifty
844
Drives: M2 & 330CI
Front sway bar is different too.
But yes, you have to wonder what might have been possible with a bit more work on the damping from the start.
      07-15-2022, 12:19 PM   #7
scottttt
Drives: f87 M2c
2019 BMW M2  [10.00]
2006 BMW M3  [10.00]
I am pretty certain the sway bars are the same. The CS racing has a different sway bar.
chris7197334.00
      07-15-2022, 03:27 PM   #8
M Fifty
844
Drives: M2 & 330CI
The CS apparently has the same front sway bar as the M3 and M4 Coupe based on the part numbers?
The sway bar on the CS Racing is - as Farkle's video points out - much, much stiffer.
      03-16-2023, 07:47 PM   #9
scottttt
Drives: f87 M2c
2019 BMW M2  [10.00]
2006 BMW M3  [10.00]
The cs has the same front sway bar as a m4 vert
chris7197334.00
