08-30-2022, 09:09 AM | #1 |
The Seeker
13938
Rep 3,343
///MPerformance carbon fiber shift knob - worth $250?
Considering the ///MPerformance carbon fiber shift knob (I have an extra blue-stitched boot that I'd install with it), but want to hear your thoughts. Did anyone buy this carbon fiber knob and not like it better than the factory knob? Was it worth the $250 cost to you?
08-30-2022, 10:05 AM | #2 |
Rep 838
From memory, the factory knob feels better and fits better in the hand. It also sits higher, is heavier, and weighted towards the top. Personally I thought it was very good for daily use. However I feel that it also contributes to some of the rubberiness of the stock shifter.
The MP shifter is the opposite of the factory knob. Sits lower, weighs less (but has more centered mass), and doesn't fit as well in the hand if you're a palm shifter. However it does have a more direct feel to it and the lighter weight allows for slightly quicker shifts. Plus it matches the interior a lot more! Keep in mind I also have the AutoSolutions SSK so my input may be biased. I did swap the knobs for a few miles prior to installing the kit but it's been some time since I drove them back to back. To answer your questions: I prefer the hand feel of the factory knob but I like the looks and the slightly more directness of the MP one more. Is it *worth* $250? No, buy it used for less. It's not a game changing mod and if I'm being honest, it's primarily aesthetic. |
///MPhatic13937.50 TUDMG21.00 |
08-30-2022, 01:40 PM | #3 |
846
Rep 1,962
I paid about 20% of that, noting that I was going to have to swap the gaiter.
Used, obviously. I like it, but it isn't as 'comfy' and you do have to be more positive with your shifts as it's shorter and not as heavy. HTH |
///MPhatic13937.50 |
08-30-2022, 02:38 PM | #4 | |
The Seeker
13938
Rep 3,343
What I wonder is, since lighter knobs and shorter throws necessarily increase shift effort, why companies these days continue to make lighter knobs. Maybe because all the newer transmissions are so easy to row? It certainly wasn't the case in the past, you'd get a heavier knob or wish you had kept the OEM. |
08-31-2022, 05:44 PM | #5 |
Rep 122
Thanks for this post. I have the m performance shifter and I got it mainly bc it looks nicer. After using it for a bit (maybe 3k) miles or so I'm not sure I like the feel of it. May put the OEM on this weekend again and compare.
08-31-2022, 06:44 PM | #6 |
Rep 264
I didn't care for the feel either, both in shape and quality (felt light and dare I say cheap)… looks good though.
08-31-2022, 06:48 PM | #7 | ||
Rep 264
08-31-2022, 08:00 PM | #8 |
The Seeker
13938
Rep 3,343
08-31-2022, 08:12 PM | #9 | |
Rep 1,969
But I was coming from 8 years of daily driving the similar shaped M Performance knob in my 135i below (with BMW factory SSK, why doesn't BMW offer them anymore)? I probably would have adjusted to the factory knob, but just got so used to the small one, I preferred it. I also later added the AutoSolutions SSK, which is without a doubt one of the biggest bang for the buck mods. Even my wife loved the shifting action (she had to drive my car once). |
///MPhatic13937.50 chris7197353.00 |
09-06-2022, 06:31 PM | #10 |
The Seeker
13938
Rep 3,343
Just wanted to add a bit of information to this thread for those that will find it in future searches.
The ///M Performance shift is... - shorter than the stock knob by 9mm (70mm vs 79) - side-to-side diameter is 6mm less (41mm vs 47mm) - front-to-back diameter is 14mm less (41mm vs 55mm) - 6 grams lighter than stock (7.1g vs 7.7g) A curiosity is the fact that the stock shift boot is 1.5g vs the one that comes with the MP knob's 1.6g (there is one additional tab on the white stitched boot). I haven't driven the car with it yet because it's gluing, but I'll post my impressions after that. I'll also add some notes later about swapping the boot. |
09-06-2022, 07:43 PM | #11 |
The Seeker
13938
Rep 3,343
OK, so just a quick note about this job.
It's STUPID easy. Looking at the numbered photo below, what you have is 1 tab that locks the back (labeled 3), and 2 tabs (labeled 1 & 2) in the front that were once taller than they are now, but were melted down to hold them in place. All you're doing is taking a hobby knife and cutting the top melted parts off of those tabs in the direction of the arrows (you can see what it looks like with the tops cut off in the last pic). Once the top melted parts are off, hold the knob upside down with the boot over your hand tightly to put a bit of pressure on it, then take a small screwdriver and release the rear tab, then just wiggle the 2 front tabs out. It's really easy. If they won't come out, just cut around the edges a bit more with your hobby knife. The rear tab, labeled 3, holds everything in place while you super glue the 2 front ones back on. Last edited by ///MPhatic; 09-06-2022 at 07:49 PM.. |
09-07-2022, 11:13 AM | #12 |
The Seeker
13938
Rep 3,343
OK, so just got back from a drive and my initial impressions on the ///M Performance carbon fiber shift knob arent as favorable as I had hoped.
Pros: - It definitely looks better IMO. - The shifts feel more precise, slight rubbery feeling is all but gone. Cons: - It's expensive. - It feels very small, too small compared to the stock steering wheel. I cant even imagine having it paired with the super thick CS wheel. - The shift effort is increased, but not by much. - The knob just feels less friendly. The harder top edges are definitely felt during the shift action, and so are the materials. Resting my hand on it, even for a few moments is no longer an option because of the feel. Hard to explain why I still like it, but I do. I think I'll keep it for a few weeks just to see if I get used to it. My goal is to figure out that if it were a no-cost option, would I keep it? We'll see. |
chris7197353.00 danvansan8128.50 |
09-07-2022, 12:27 PM | #13 |
Rep 838
My biggest complaints about this knob are that it could use more weight and size, I think many others agree also. I also think that it's precisely because of the weight and size that makes it good. The shift action is more focused on the lever than the knob so you get a little more feel of the shift vs a heavier knob that would mute it. If that makes sense?
I know you're on the fence regarding a SSK but I think, for the cost (vs this knob), the mod is leagues above what incremental improvements the knob offers by itself. |
chris7197353.00 |
09-07-2022, 12:36 PM | #14 | |
The Seeker
13938
Rep 3,343
I have long considered the SSK and CDV delete, but I'm worried about increasing the effort even further. |
chris7197353.00 |
09-07-2022, 12:36 PM | #15 |
Rep 7,310
Could it be loaded with mass if it’s hollow past the attachment point? Never seen it upside down straight on.
09-07-2022, 12:38 PM | #16 | |
Rep 7,310
09-07-2022, 12:43 PM | #17 |
The Seeker
13938
Rep 3,343
This is a fantastic question. I have some pictures that show a channel, but I'll go take some measurements real quick to see what could be done. It'd be great (IMO) to fill that channel with lead.
09-07-2022, 12:52 PM | #18 |
Rep 838
The CDV is a good mod, that's more of a shift "timing" mod than a shift effort mod, recommended for sure! Regarding the SSK, I have to admit there's definitely no way around increased shift effort, however, if it's within the realm of tolerance, it may actually make the shift more enjoyable.
I consider myself sensitive these types of "feel" mods and was also very concerned about increased shift effort. I get the sense that you're also sensitive to them (even moreso than me). The increase was definitely noticeable and initially I thought it was too much, that I made a mistake, but after it wore in a bit it started to feel more natural. I did get the added benefit of the slightly notchy, mechanical feel but none of the stiff, clunkiness I was worried about. That being said, getting into reverse is DEFINITELY noticeable even after almost a year of driving. Anyway, if you're ever in my neck of the woods, I'd be happy to let you in the driver's seat to get a feel for my shift setup! |
chris7197353.00 ///MPhatic13937.50 |
09-07-2022, 12:55 PM | #19 |
The Seeker
13938
Rep 3,343
There is a channel inside the knob that's 12mm deep by 1.25mm wide that *appears* as if it could be filled with something heavy, but upon closer inspection it's plastic, made to have some give to it, and has several sections, so adding material doesn't look like it'd work (especially if it were a molten material).
chris7197353.00 |
09-07-2022, 01:22 PM | #20 |
Rep 1,610
It definitely completes the interior but for some reason I felt it was kinda of cheesy looking after having it for a few months. But you can't be lazy with your shifts, definitely requires a bit more effort compared to stock and less ergonomic but I did like that was flat up top.
09-07-2022, 03:21 PM | #21 | |
The Seeker
13938
Rep 3,343
09-07-2022, 04:37 PM | #22 | |
3028
Rep 13,775
~loud noises~
