09-15-2023, 10:31 AM | #1 |
The Seeker
13904
Rep 3,334
Did you guys see the 455/530 on an OG with just an IC and FP?
These are incredible numbers! But I'm also interested as to why he told me that the torque would be limited without the fuel pump. I have not heard that before on stock turbo.
09-15-2023, 10:32 AM | #2 |
The Seeker
13904
Rep 3,334
09-15-2023, 10:47 AM | #3 |
Grandmaster
775
Rep 803
over 20psi on stock turbo is that ok? BM3 stage 1 targets just 16psi on my car. Maybe fuel limited and the turbo has more in it or something? Idk what im talking about.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
09-15-2023, 11:13 AM | #5 | |
Grandmaster
775
Rep 803
Said the car dynoed at 410hp on stock tune so thats like a 10% increase...
09-15-2023, 12:09 PM | #6 | |
The Seeker
13904
Rep 3,334
If it's true that BM3 makes more power, then why are they saying it needs a FP with just an intercooler? |
09-15-2023, 12:38 PM | #7 |
Grandmaster
775
Rep 803
I've seen alot of ppl on stage 2 here on the forums having HPFP not meeting demand especially at higher revs, so i can believe that its needed for anything beyond a light stage 1 tune.
///MPhatic13904.00 |
09-15-2023, 01:11 PM | #8 |
Rep 4,160
As stated above, it's BHP (calculated engine power) and not wheel power. It would probably be closer to 400whp if I had to guess, which is what a good tune and fuel pump will give you.
You can just reverse their numbers to find the calculated wheel power: M2 wheel power 340-350WHP (divided by) / 370-375 (Est Engine power) = 5-10% So your numbers would look like: Stock Stage 1 -375whp Stage 1+ - 367whp Stage 2 - 381whp Stage 2+ - 405whp
Mods: Yes.
09-15-2023, 01:31 PM | #9 | |
The Seeker
13904
Rep 3,334
09-15-2023, 04:58 PM | #10 |
Rep 309
Some of us on stage 2+ see HPFP readings drop below requested. Especially during cooler temps. When I spoke to my tuners, they stated our cars should have came with the Dorche Stage 1 pump or an equivalent to reach full limits of stock turbo. You only need a pump if you see the reading not reaching demands. Do logs occasionally and check. Again, its typically us running stage2+ with a dash of Ethanol.
09-15-2023, 07:19 PM | #11 | |
The Seeker
13904
Rep 3,334
09-18-2023, 05:25 AM | #12 |
Rep 1,389
Well I emailed MHD for more info on their advertised HPFP stage 2+ maps for 98 RON only for them to say will only make a slight difference in torque.
They need to get their advertising straight. I was dead set on getting Dorch stage 1 and using their OTS map to get 445-450hp at the crank. Now I'm looking at infinity designs air intake instead, cheaper and can fit myself lol. |
09-18-2023, 12:16 PM | #13 | |
Rep 309
Mr_M//123.50 |
09-18-2023, 12:35 PM | #14 |
Rep 565
Agreed. HPFP and a custom tune is the way. Running blind by not reviewing data logs is not. Intakes for these cars are stupid imo, but many disagree.
I’m BM3 OTS S291 running 93 from Shell and I still see uneven timing (CSF IC). I’m remedying this with a custom tune from Bend Calibration (and a Pure500 for good measure). They require a HPFP to support N55 cars for whatever that’s worth. This is the real set it and forget it option, but it ain’t cheap and without effort. Last edited by ThreeStripes; 09-18-2023 at 12:43 PM.. |
09-18-2023, 12:35 PM | #15 |
Rep 866
Drives: OG M2
Lol my HPFP wasn't having it with even a stage 1 tune (albeit this was on garbage California 91). Not surprised he had to upgrade
09-18-2023, 06:21 PM | #16 | |
The Seeker
13904
Rep 3,334
It's not like we're hearing about BM3 S293 + 93 octane cars blowing engines, so most are going to forego any extra expense. |
09-18-2023, 06:34 PM | #17 |
Rep 565
If the measure of success is simply not blowing the motor up, then that’s certainly an approach.
I don’t think it’s wise, and would point out that not blown up doesn’t equal in good order. |
09-18-2023, 07:50 PM | #18 |
The Seeker
13904
Rep 3,334
09-18-2023, 10:12 PM | #19 |
Rep 3,699
BM3 Stg 2 OTS maps are the best bang for the buck out there. 400whp (460-470bhp) on 93, no HPFP needed unless your stock HPFP is failing.
Stg 2+ 93 that requires an HPFP might only net you 10whp more bc the stock turbo is octane limited at that power level. Same for custom tunes, they don’t make sense unless you’re running an Emix—the person that was originally referenced for this thread wasted their money. Stg 2 93 - 400whp Stg 2+ 93, HPFP - 410whp Stg 2+ 93, HPFP, PS2 - 445whp, lots of low end lag Stg 2+ E30/Multimap, HPFP, E40-50 - 445whp peak, no lag, power drop in upper RPMs Stg 2+ E30/MM, HPFP, E50, Stg 1.5 turbo - 470whp to redline, no lag Stg 2+ E30/MM, HPFP, E50, PS2 - 500whp, some lag on the bottom end Add a Flexfuel sensor to the mix and the Stg 1.5 turbo setup that ThreeStripes is aiming for is the sweet spot for our cars. Last edited by ZM2; 09-18-2023 at 10:17 PM.. |
///MPhatic13904.00 Mr_M//123.50 |
09-19-2023, 04:13 AM | #20 | |
Rep 1,389
Wait what?! BM3 stage 2 93/98 is over 430bhp?! When did this happen. Is it really that much more aggressive than MHD 2+? So HPFP IS still worth it albeit with a custom tune? What worries me is doing high speed runs with TC off to get the data! OTS don't have to worry! |
09-19-2023, 04:57 AM | #21 | |
Rep 3,699
