02-05-2018, 07:13 PM | #1 |
Rep 412
Stock Clutch Stop
Does anyone know the BMW part number for the stock clutch stop? was going to switch back because of reports of transmission syncro problems for those with the BMS clutch stop. dont know how accurate it is..
02-06-2018, 08:42 AM | #2 |
Rep 1,339
K9GunSlinger94.50 |
02-06-2018, 06:13 PM | #4 |
Hanapaa!
393
Rep 449
Instead of buying a new stock clutch stop, why not just remove all the extra washers on your BMS stop?
02-06-2018, 07:28 PM | #5 |
Rep 412
02-06-2018, 07:35 PM | #6 |
Rep 4,551
Drives: 2015 328d xDrive
02-06-2018, 09:42 PM | #7 |
Rep 450
I installed the BMS clutch stop right when I got the car. Shifting has always been a bit notchy but I figured it was just how the car was. Over the past few weeks it just seems really notchy and difficult from 1-2, occasional 2-3 and 3-4. I took the clutch stop down from 2 to 1 and it's so much smoother. I guess every car is different but I'd rather not risk damaging the synchros.
M2guru409.00 |
02-06-2018, 10:00 PM | #8 | |
Hanapaa!
393
Rep 449
02-07-2018, 12:20 PM | #9 | |
Rep 660
02-07-2018, 03:29 PM | #10 |
Rep 585
You guys are smarter than I am...living in warm climates. I live in MN and the additional washers were more noticeable/troublesome when the temp was below zero (really bad at -10, like almost couldn't shift into 2nd). I am down to one and, if anything, may go back to stock.
02-07-2018, 04:20 PM | #11 | |
Rep 1,339
What could affect the feeling of shift can be climate and transmission fluid types which is not really related to having clutch stops or not.. Now I am little starting get paranoid ppl mentioning about possible wear by using the stop with full washers.. Maybe I will go back and remove some.. I guess |
02-07-2018, 06:10 PM | #13 |
Rep 585
Yes it was easy, but the plastic "feathers" on the shaft seem like they wouldn't like too many times being pulled out and back in. The good thing is that gravity would hold it, too, but if it were not relatively tight, I'd get a new one.
alscks0414690.00 |
