05-17-2018, 03:20 PM | #1 |
Rep 780
Floor Jack Size
Bought a 3 ton jack. Thing weighs 70lbs and I have to store it in the basement. As the car weights 3500lbs can I get away with a 1.5 ton jack (3000 lbs)? Thinking you never lift more than half the weight of the car.
I guess even a 2 ton is better but those 1 1/2 tons are super light!
05-17-2018, 06:46 PM | #2 | |
Rep 1,124
05-17-2018, 09:14 PM | #3 | |
Rep 780
rich8566608.50 |
05-17-2018, 10:18 PM | #4 |
Rep 45
The only jack from Harbor Freight that has a long enough reach to jack the M2 from the center jackpoint in the front is this model :
https://www.harborfreight.com/2-ton-...ump-68050.html All the other jacks do not have enough reach. With this jack it’s easy to put jack stands under the jacking points. Last edited by Ktmdriver; 05-17-2018 at 10:25 PM.. |
rich8566608.50 |
05-17-2018, 10:49 PM | #5 | |||||
7906
Rep 11,785
Go ahead and pick up both! The little HF jack is great for picking up one side of the car to change wheels and tires. Position it an angle and use the rear jack point and you should be able to lift the side to change two tires. It's small enough to fit in a track box that goes in your trunk and great to use at the track. If you plan to do work in the garage then the center jack point at the front is the way to lift the car at the front and use a hockey puck/guibo under then diff (mind the fins - use the main unit not them ! ) to lift the rear axle. |
rich8566608.50 |
05-18-2018, 07:46 PM | #6 | |
Rep 1,124
05-18-2018, 08:32 PM | #7 |
Rep 780
I've not done any major work on the car yet. On my MINI I could put jack stands under the front points by jacking up the back high enough to slide the stand under that side then doe the other. You guys don't think that idea will work with the M2?
That second jack recco is really heavy at 93 lbs. Honestly the whole idea is to get something light as I don't have a garage....any other thoughts?
05-18-2018, 08:57 PM | #8 | |
7906
Rep 11,785
if you are going to put it on jack stands.. I HIGHLY recommend you do it by starting from the front or the rear. You can do everything you want with the small jack... it will reach to the rear fine. In lieu of using the super low jack on the front.. you can use ramps (which I detest) or alternatively, use two 2 X 6 boards and drive the front tires up onto them.. set the parking brake.. and that should get the front of the car in the air enough so you can have room to use the small jack to lift the front. |
05-18-2018, 09:39 PM | #9 | |
Rep 780
So you are saying the car has 6 jack points? Were at the front and rear points.
05-19-2018, 07:52 AM | #10 | ||
7906
Rep 11,785
A video will be easier than 10,000 words. Here is an excellent video that details what I've posted. BMW puts a center jack point on the front of the car. The rear differential is used at the back of the car. ( see my prior comments - the differential is an excellent place to jack from but be careful to go beyond the rear fins and jack from the main part of the diff -not any part of the cooling fins ) The video is of an F30 but shows the same points that will be on an M2 or most any BMW made in the 2010s. |
randyt224.50 |
05-19-2018, 07:54 AM | #11 | |
Rep 960
05-19-2018, 04:55 PM | #12 | ||||||
Rep 1,124
05-19-2018, 06:55 PM | #13 |
Rep 780
This is great info guys. Thanks so much. Went to HF today! Great to see that the forum has people that love to work on there cars!
Thanks.
05-19-2018, 08:04 PM | #14 | |
Rep 1,608
Boostm3
05-19-2018, 08:22 PM | #15 |
Rep 3,968
Don't forget to pick up one of these if you are just going to be changing your tires...
https://www.ecstuning.com/b-ecs-part...iABEgJIIfD_BwE
05-19-2018, 11:10 PM | #16 | |
Rep 1,083
randyt224.50 M3 Adjuster7905.50 |
05-20-2018, 12:05 AM | #17 |
Rep 1,083
05-20-2018, 06:12 AM | #18 |
Rep 780
Buffalo. (Close in an M2)....On sale for $59. They are have a sale in a month and they are going down to $49. Looks decent for the price.
M3 Adjuster7905.50 voyagergab633.00 |
05-20-2018, 07:26 AM | #19 |
BMW Newb
582
Rep 903
Have you tried out the jack yet...will it reach the center rear jack point at the differential?
05-20-2018, 09:38 AM | #20 |
Rep 780
Have not but will report back.
05-20-2018, 09:55 AM | #21 | |
Rep 780
I would highly recommend these. I have had a set for years (fit the MINI too) They are high quality any only $40 for 4! https://www.ebay.com/itm/BMW-JACK-PA...-/191703163217
05-20-2018, 09:38 PM | #22 |
Rep 121
this is what i got
https://www.northerntool.com/shop/to...4333_200514333 |
