04-11-2018, 03:06 PM | #1 |
Rep 6,934
Drives: 2018 M2 AW DCT
Shout out to Techic PnP
I just bought and installed the Technic PnP ASD delete harness. I just wanted to thank them for making an easy plug and play solution to permanently remove the fake engine noise.
I can’t believe how much quieter the M2 is in Sport. Last edited by DanG; 04-11-2018 at 04:06 PM.. |
04-17-2018, 06:03 PM | #2 |
Rep 754
Drives: 2022 M3 Competition
I went to their site to look for install instructions. Are they included?
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
04-17-2018, 06:13 PM | #3 | |
Rep 6,934
They have updated the cable so it now has the correct connectors so installation is easier than the thread states. |
HTTP 4102141.50 |
04-17-2018, 06:20 PM | #4 |
Rep 6,934
Here is the link for the ASD delete harness: https://technicpnp.com/product/asd-bypass-harness/
HTTP 4102141.50 |
04-17-2018, 11:15 PM | #5 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
You've also altered the EQ curve and possibly volume level of your radio.
04-17-2018, 11:36 PM | #6 |
Rep 6,934
04-18-2018, 06:29 PM | #7 |
Rep 754
I ordered this today. Thanks again for the info.
DanG10644.50 |
04-18-2018, 06:32 PM | #8 |
Rep 6,934
You are welcome. Installation took a little over a half hour. You will love how your M2 sounds after the install.
If you don’t want to install it by yourself, take your BMW to a good stereo installer. In my area it would be Car Toys. They replace the amps all the time so they know how to access the amp and ASD amp. |
HTTP 4102141.50 |
04-18-2018, 06:54 PM | #9 | |
Rep 4,551
Drives: 2015 328d xDrive
There are older version of this harness that weren't 100% plug and play. Maybe those had issues or maybe there were some defective one's sent out? All I know is that mine works fine. |
NYC Bimmer259.50 DanG10644.50 |
04-19-2018, 11:41 AM | #10 | |
I INDIC8
612
Rep 1,286
The ASD box is also performing EQ and tweaking the volume level of the sound that comes out of the radio, before passing it to the actual amp. By bypassing it with a harness, you've altered the EQ in the car. This is why I don't like the idea of the harness, unless you're going to completely redo all of the audio (amp included).
04-19-2018, 12:46 PM | #11 | |
Rep 6,934
HTTP 4102141.50 |
04-19-2018, 06:53 PM | #12 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
The LCI seems very different from the instructions. Instead of having to remove hooks and the lining you just lift out a cover that reveals everything under it.
However I can’t locate where the ASD harness plugs into. Can another LCI owner post a couple of pictures to show the location please? Thank you! |
04-19-2018, 08:43 PM | #13 | |
Rep 6,934
04-20-2018, 12:06 AM | #14 |
Public Last Class
97
Rep 244
Okay. So it’s behind the side covering. Thank you.
04-20-2018, 08:25 AM | #15 |
Rep 6,934
04-21-2018, 01:49 PM | #16 |
Rep 6,934
04-21-2018, 05:38 PM | #18 |
Rep 6,934
04-21-2018, 05:44 PM | #19 |
Public Last Class
97
Rep 244
The only tricky part was removing that back plastic part. What makes it hard is there’s nothing to grab to pull it straight up and the rubber seal is in the way. I should have taken a picture of what it looks like under the plastic so others can see what they’re trying to do. What I would tell them is
1- be sure to pull the pins all the way out - remove them. 2- start at the top edge of the plastic (left or right) and get fingers underneath while moving the rubber seal under it. Then do the same to the other side. Keep lifting up from both sides. It’s not connected but held on by pressure. There are two clamps of plastic if you will squeezed over a raised metal area of the lip. I also expanded the plastic gently at the top to open the clamps up more. Good luck! |
DanG10644.50 |
04-29-2018, 10:28 AM | #20 |
Rep 754
Wow! I just did this and I can't put into words how much better things sound. Nice and quiet in the cabin and I don't have to listen to the radio all the way up.
To help my brothers and sisters out, I wanted to share my experience.
Hope this helps. Great, inexpensive mod that makes a world of difference.
05-14-2018, 05:14 PM | #22 |
Rep 6,934
