M2 Technical Topics > Track / Autocross / Dragstrip > Going to first track day - do I need racing brake pads and/or fluid?
      04-09-2018, 02:27 PM   #23
Mike0105
Drives: 2018 BMW M2
Are you guys swapping the RS29's out before and after each track day? How are they on the stock rotors in terms of wear?
Mike
      04-09-2018, 03:08 PM   #24
lax01
Drives: 2017 M2
Mike
I still haven't pulled mine out from the last track day but I don't daily drive my car and I was thinking I might go back to the track soon
Now that I have removed most of the trackpad bedding...they are starting to get loud when cold and on the street
      04-09-2018, 07:46 PM   #25
Twt
Twt's Avatar
634
Drives: 2017 M2
Originally Posted by Xtianh View Post
Got it, makes sense. I was spacing on what "SS" stood for.
So, after a track day, it's recommended to switch out the track pads for the stock pads, but it's OK to keep the Castrol SRF blake fluid and and the SS lines on, is that correct?
The SRF stays in always....just bleed periodically. I leave my track pads on even on the street since it's not my DD....a bit noisy. Switching to OE pads after track is quick and easy though.
      04-17-2018, 05:08 PM   #26
Zurich58
Drives: 2018 M2 promise
2018 BMW M2  [0.00]
i'm getting ready for my first track day in a completely stock M2 including OEM wheels and MPSS rubber. Any advice on starting tire pressures (20 min sessions)? What about for AutoX?
      04-17-2018, 07:44 PM   #27
dvas
dvas's Avatar
518
Start around 30 in the morning to avoid any TPMS issues. After the first session, adjust and manage pressures to 36 hot.
      04-18-2018, 06:26 PM   #28
Zurich58
2018 BMW M2  [0.00]
thanks, much appreciated!
      04-29-2018, 05:21 AM   #29
Isty
Sweden
102
Drives: M3 E46 - V40 T5 - M2 aug deliv
So ran the car completley stock this friday, brakes worked brilliantly! I totally underestimated them and I was left braking way to early every time almost.
M2 OEM brakes work very well on track, sure after 10-15min they lose a bit, but not much at all. Cool down lap, repeat, have fun!
      04-29-2018, 09:08 PM   #30
GVN*2FLY
Drives: ‘16 GT4|‘22 X3MC
Originally Posted by chief1richard View Post
Is you suspension all stock running those wheels and tires? No camber?
I’ve got M Perf Coilovers w/ GC camber plates and alignment is set to -2.5 up front and -2 in rear.
