04-01-2018, 07:20 PM | #1 |
LA transplant
56
Rep 92
Going to first track day - do I need racing brake pads and/or fluid?
Heading to my first track day in a month or so.
I’ll be driving in the novice group with an instructor. My car has the dinan P2 package installed. Do you recommend I install after market brake pads and/or fluid? If so, any recommendations on the pads and where to buy them? Thanks!
2018 M2 | MG | Dinan P2 Package | full XPEL Stealth wrap | DCT | Exec pkg. | Black kidney and side grills | Stainless steel pedals | LED door sills | LED door projectors
04-01-2018, 08:57 PM | #2 |
Former P-Car Owner
272
Rep 237
Nope, not for your first track day. Go out and have fun. Once you start learning to push the car, then you'll start getting into different pads and fluids
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped |
emdeuce196.50 |
04-02-2018, 09:19 AM | #3 | |
Rep 254
04-03-2018, 12:01 PM | #4 | |
LA transplant
56
Rep 92
I guess I have two questions: 1. Is there any downside to installing the Pagids for my first track day? It seems like there COULD be a downside to NOT installing them. 2. Do I also need to change out my brake fluid (to castrol srf), or is that something I don't need to worry about yet? Thanks!
04-03-2018, 02:08 PM | #5 |
Rep 152
I'm kinda in the same boat as OP, will do my first trackday the 27th of april with the M2.
I have done 4-5 trackdays in my old car which was a M3 e46. I ran OEM pads with upgraded brake fluid, it ATE(hehe) the pads like nothing. Will the M2 pads get destroyed as much? Almost the same weight and power. |
04-03-2018, 07:09 PM | #6 |
Rep 339
In the same position with my first track day in about 2 months from now and was contemplating the same thing myself. Many say being my first track day I probably won't be going too hard and the stock pads/fluid should be fine. On the other hand I rather have the car prepped where there is zero chance I need to worry about braking when I'm out there.
instagram: @ sf87_m2
04-03-2018, 09:44 PM | #7 |
Rep 1,368
Guess spring as sprung for track events?
I switched to Pagid RS29s and SRF for my first event (in this car, far from first event ever) but it was also an open lapping event with unlimited track time. Had to fill the car up twice Damn why is Speed District going on a Friday? Too hard to get out of work on this short notice...any weekend day where people from SoCal are going? |
04-03-2018, 10:50 PM | #8 | |
LA transplant
56
Rep 92
Speed District is hosting events on May 25th and 26th (weekend days) at Buttonwillow. Speed Ventures is hosting on May 5th-6th at Auto Club Speedway in Fontana, Willow Springs on May 12-13, and Bimmerfest in Fontana on May 26-27. I'm definitely going to go to one of those.
04-04-2018, 07:03 AM | #9 | |
Rep 650
04-04-2018, 08:40 AM | #10 | |
Rep 254
1. There's no downside imo other than the God forsaken screeching that accompany all race pads. I try to switch out my pads the night I get back 2. If you're changing out your pads, I'd say you might as well switch out the fluid as it's pretty cheap. |
04-04-2018, 09:21 AM | #11 | |
Rep 52
I'd probably go ahead and do it if you plan on doing this regularly... I use Ferodo DS1.11 pads which I buy from KNSBrakes.com. They have other popular choices there as well and are good folk. Have Fun! |
04-04-2018, 09:24 AM | #12 | |
Rep 98
I run SS lines, DOT4 fluid and RS29 pads on 18" FL-5s and 265 RE-71s square. Super easy to change out the pads yourself and have a good shop flush/change fluid every 3 weekends. |
04-04-2018, 04:09 PM | #13 | |
LA transplant
56
Rep 92
I ordered the RS29's and Castrol SRF (that's the right fluid, right?) This is a total rookie question, but what exactly are SS lines, and where do I buy them? Thanks!
04-04-2018, 04:17 PM | #14 |
Rep 350
I'm an intermediate driver, I did get RS29s for my first proper track days but skipped SS lines and fluid change. I had also done several laps of the Nurburgring on stock but that was pretty gentle.
Stainless Steel brake lines replace the stock rubber ones, they shouldn't have as much flex and be tougher. I believe HPAutoshop, a vendor on this board, sell some and I'm sure you should be able to find them pretty easily with other vendors too. |
04-04-2018, 04:48 PM | #15 | |
LA transplant
56
Rep 92
So, after a track day, it's recommended to switch out the track pads for the stock pads, but it's OK to keep the Castrol SRF blake fluid and and the SS lines on, is that correct?
04-04-2018, 09:17 PM | #17 |
Rep 98
04-05-2018, 03:00 PM | #19 | |
Rep 664
We swap the OEM's out at the start of the track day. Takes about 30 mins to do brakes and track wheels.
04-06-2018, 12:59 PM | #20 |
Rep 1,368
04-06-2018, 07:15 PM | #21 |
Rep 664
My buddy and I both track our M2's. It's compulsory 6x5Gal gas canisters ( 3 each) in the back of the cars each track morning.
04-09-2018, 11:46 AM | #22 | |
383
Rep 731
