11-07-2017, 03:14 PM | #1 |
Rep 1,608
Third gear 3k rpm resonance
Any new M2 owners experience a nasty resonance coming from the passengeer side rear at 3k rpms as you accelerate from 2500 rpms to 3500 rpms in third gear?
I managed to pin it down to the REAR passenger side seatback latch leading to the trunk.. When its latched, its noisy at 3k rpms in third gear; when its Unlatched, even resting against the latch, no such annoyance. Its weird because normally, you would think that when the latch is under tension, ie closed, it would be buttoned down and when its unlatched, thats when youd expect to hear anything loose in the assembly. But Ive got the opposite.. Ill have the dealer take care of it in 350 miles when I bring it in for the 1200 break-in service. I hate resonances! So annoying, and chasing them down can be a real pain.. I always used to get them in my sport bike fairings when I used to ride.. Usually a shim made out of foam or rubber would quiet it. But this rear latch has me puzzled.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 11-08-2017 at 09:26 AM.. |
11-07-2017, 03:42 PM | #2 |
Rep 121
Congratulation! You found the "3k rpm buzzing" Easter egg BMW installed fresh from the factory.
Just kidding. Yes, I discovered it the 1st day when I took delivery. Mine actually turned out to be the triangle shaped metal loop in the trunk floor. I flipped it standing up and the buzzing is gone. The other day I was shopping and a box pinned it down again and the buzz came back. Glad you found your source. |
11-07-2017, 04:04 PM | #3 | |
Rep 13,090
I noticed a metallic buzzing/humming right from day one around 2.8k rpm. Initially I thought that it was related to the MPE. It's somewhere in the back of the interior. Checked several times (rear seat belts, seat belt buckles, rear seat armrest, rear seat cup holders, rear seat trunk locks, rear seat headrests, speakers, rear panel, airco blower behind the front seats, etc.) but never managed to locate it. Please post a picture of 'your' exact location.
///M is art ↔ Artemis
11-07-2017, 04:14 PM | #4 | |
Rep 1,608
Please let me know if you need a picture beyond this description. I cant say for sure its the metal latch that is buzzing, however I CAN say for sure when the rear passenger seat is closed in its normal position, it buzzes, and when its not in its closed, normal position, it doesnt. Strange but true. BTW, I tried messing with the rear seat belt mechanism as that was one of my first suspects, but its definitely not that. Let me know if this jibes with what's buzzing in yours.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 11-07-2017 at 07:04 PM.. |
11-08-2017, 01:30 AM | #7 | |
Rep 175
11-08-2017, 09:29 AM | #8 |
Rep 1,608
Im guessing that's the issue; there must be some tiny 'slack' between the U shaped metal buckle and the latch mechanism creating a resonance/buzzing when closed. So, what kind of 'wrap' could be used? Im thinking tape would be scraped away by the jaws in the latch mechanism, as whatever 'slack' is present is probably tiny, and it could gum up the latch mechanism.. I still want to present this to the dealer in 400 miles for my inspection srvc, so Im just looking for a temporary 'fix' to keep from going crazy til then. I was just going to leave the rear seat back down, but Ill get even more noise in the cabin.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 11-08-2017 at 09:34 AM.. |
11-08-2017, 10:42 AM | #9 |
Rep 507
My resonance was coming from the child seat latch system above the headrest. I simply put some felt tape on the underside on the plastic lid and the noise stopped.
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
11-08-2017, 02:45 PM | #10 | |
Rep 1,608
I think in time the foam I used will compress and the buzzing will resume so Ill be looking for a more permanent solution, or just make this the Dealer's problem instead.. Thanks for ferreting out the real instigator!
Boostm3
11-08-2017, 05:41 PM | #11 | ||
Rep 2,577
Lemania 2320
11-08-2017, 08:56 PM | #12 |
Rep 477
Drives: M2CS
I pinned it down to rear window shelf. Very noisy over bumps. My car is getting its 1200 mile service and asked the service adviser to take a look at it.
If you tap the right side speaker cover you'll see what I'm talking to about. |
11-09-2017, 08:54 AM | #13 |
Rep 1,608
You cant miss it.. Its behind the head rest in the rear deck. You can see it clearly if you look down from the outside rear window or crawl onto the rear seat and look in that spot. Theres one behind each head rest right next to the rear speakers.
Boostm3
11-09-2017, 10:45 AM | #14 | |
Rep 2,948
It's been well over a year and I could never figure out where it came from, like others I thought it was the seat latch. A little bit of felt this morning and no buzzing on the drive to work. |
11-09-2017, 11:31 AM | #16 |
Rep 549
Drives: The Bus
I never hear this as I'm only in 3k rpm on my way to the redline. #flatout
M2TT1.50 Spartan King79.50 |
11-09-2017, 11:46 AM | #17 |
Rep 1,608
It doesn't happen when cruising at 3k. With mine you have to be in third and accelerate fairly hard THROUGH 3K.
11-09-2017, 02:04 PM | #19 | |||
Rep 13,090
part #4: (source: here)
SeanWRT3179.00 |
11-09-2017, 02:04 PM | #20 |
Rep 1,608
Here's a pic of the child seat latch.. Youre looking at the latch cover which is the resonator. Underneath is a U bolt that the child seat hooks onto. I didnt want to open the cover which just pops up because the 'fix' I employed is tenuous at best and didnt want to disturb it til I come up with something more permanent.. However all I did was stuff a bunch of foam in there to keep the lid from rattling. The 'trick' if there is one is to stuff enough junk in there to remove the play but not so much it doesnt close. The driver side one doesnt have this problem on mine because theres much less play in it. I think the proper fix would be for the dealer to replace the lid, and if thats not a separate part, replace the whole assy.
Boostm3
05-19-2018, 02:59 PM | #21 |
Rep 1,608
Update..... Back to square f'in 1 Im afraid.. I thought I had it nailed; sure it was either the cover of the rear child seat lock pass. side, or the cover of the rear pass. side C pillar, or a combo of both, as both tended to be loose and have play in them such that when you tapped them with a finger you can feel it.. So, I shimmed both, and it was silent for months.. Last night, it came back
So I repadded the child seat latch cover such that there was zero play in it, and was tight as a drum but the resonance was still there. So I removed it completely, and not sure yet if even that took care of it. It seemed to, however Ive been bitten before my false solutions.. Seems it may be affected by temperature or humidity or both, as it keeps coming back after going away for periods of time. Chasing resonances is certainly a mixed blessing until the cause is finally found and removed. Cant even have the dealer look at it since its so sporadic.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 05-19-2018 at 03:19 PM.. |
05-19-2018, 03:09 PM | #22 |
Rep 6,634
Yes I had this and used felt tape to solve it. I also have a rattle near the rear view mirror on certain bad roads, and also one driver side seat belt pillar area. I can only solve the mirror one but not sure about the pillar.
