10-23-2022, 11:23 AM | #1 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
Front Strut Brace
Looking to stiffen up the suspension with a front strut brace. Looking to buy the OEM carbon brace off the M2C / M3 / M4 or a metal one
12-21-2022, 12:09 PM | #2 |
Rep 1,243
still looking, doesn’t have to be the OEM carbon one
12-21-2022, 04:00 PM | #3 |
Rep 7,543
The turner brace is a good choice imo, I have one for my own car.
Other options could be a simple strut brace, there are plenty of cheaper options out there too, such as: KC design, racing dynamics, ultra racing, AFE etc.
12-21-2022, 04:19 PM | #4 |
Rep 1,243
you have a pic and link of Tuner’s ? I didn’t see one available anywhere and didn’t even know they made one. I was eyeing the aFe control gunmetal one, it seems pretty solid
12-21-2022, 04:30 PM | #5 | |
Rep 7,543
Yeah the AFE one is a solid option! Only small issue is that to remove it you have to remove the single use strut tower bolts each time.
12-21-2022, 04:46 PM | #6 |
M///modifyer
2498
Rep 1,298
Unless you go for the oem M3 brace which is clearly the best option, I don’t that see that it matters which brand you go for as they all attach the same & are constructed pretty much the same (I would have liked one that captured all the strut top bolts but afaik no aftermarket version does that).
Thus I have the KC versions (pic below) as I wanted a matching brace for the rear, however imo the AFE is the pick of the aftermarket options.
www.targaperformance.com
Best Modified BMW - BMW Nationals 2022 Last edited by TargaM2; 12-21-2022 at 04:56 PM.. |
shaneguags1199.00 |
12-21-2022, 04:49 PM | #7 |
Rep 1,243
oh dang, that sounds like a pain in the ass
12-21-2022, 04:51 PM | #8 | |
Rep 1,243
12-21-2022, 05:01 PM | #9 |
Rep 7,543
Yeah, that's why I was looking for strut tower braces with a removeable center bar. But that being said the tubular design of the AFE strut tower brace is likely the best one on the market in terms of performance.
In terms of corner braces, I think the TMS ones are the best.
shaneguags1199.00 |
12-21-2022, 05:04 PM | #10 |
Rep 6,983
Drives: 2018 M2 AW DCT
I have the Racing Dynamics version. Easy install and works great.
shaneguags1199.00 |
12-21-2022, 05:06 PM | #11 | |
Rep 1,243
12-21-2022, 05:08 PM | #12 | |
Rep 1,243
12-21-2022, 05:08 PM | #13 | |
M///modifyer
2498
Rep 1,298
Yes painted them both myself (they come painted black). I upgraded the single use strut bolts so don’t have that issue. If I was just buying an aftermarket front brace I’d go for the AFE version.
Best Modified BMW - BMW Nationals 2022 |
12-21-2022, 05:12 PM | #14 | |
Rep 1,243
12-21-2022, 05:17 PM | #15 | |
Rep 7,543
So no they are not just for aesthetics, if you look at the engineering that went into these braces (especially compared to the flimsy stock braces) they are legit. But at the end of the day its your choice what you end up buying.
12-21-2022, 05:17 PM | #16 | |
M///modifyer
2498
Rep 1,298
Unless you get the oem M3 type, the pick is probably the racing dynamics as the centre bar is removable for convenience but I don’t like the polished finish. As for the rest, they may vary in design but will all do the same job (don’t expect a big improvement, it’s just a strut brace).
Best Modified BMW - BMW Nationals 2022 Last edited by TargaM2; 12-21-2022 at 05:45 PM.. |
12-21-2022, 05:19 PM | #17 | |
Rep 7,543
Next take a look at the end plates, the AFE one uses much thicker metal and it is double boxed in so there is more lateral support along the length of the bar vs. the kc design end plates which imo are extremely thin and single boxed. So in this aspect the AFE brace will be much more rigid and this be better at transfering load to the bar itself. Also look how it attaches to the main bar, its literally attached by the end of an extremely thin piece of metal and off center too. This means it will be subjected to massive sheer forces and I don't think the end plate with its thickness will be able to resist those forces effectively. Like I said before if the brace flexes at all it will not be able to transfer as much load as it can, and thus will not contribute as much to rigidity.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 12-21-2022 at 05:24 PM.. |
shaneguags1199.00 |
12-21-2022, 05:40 PM | #18 | |
Rep 1,243
12-21-2022, 05:53 PM | #19 | |
M///modifyer
2498
Rep 1,298
It depends what you want from your car & what you do with it, but imo always listen to experienced people that have actually DONE these mods & used them both on & off track, NOT to armchair experts. Then you can decide on what is best suited to what you do with your car.
shaneguags1199.00 |
12-21-2022, 05:56 PM | #20 | |
Rep 7,543
Plus the rear sway bars are a major pain to install, requiring the rear subframe to be dropped.
shaneguags1199.00 |
12-21-2022, 06:17 PM | #21 | |
Rep 1,243
12-21-2022, 06:18 PM | #22 |
Rep 1,243
yea I saw that in a YouTube video. I wanted to just do the front but think it’ll be weird to only do the front and not the rear. Would you agree with that ?
