10-08-2023, 11:07 AM | #1783 |
Rep 114
Just a few ring Pictures from the green Hell weekend just passed.
She has to ruin every god dam picture |
Kevin_The_Clean13341.50 Kikuchiyo123.50 Peter77BA16.50 Sadd1613.50 vrooooom326.00 Distinct150.00 IcewaterPete2188.50 |
10-09-2023, 07:59 PM | #1784 |
Rep 23
M performance hood ✅
IG: f87young |
Kevin_The_Clean13341.50 Markyc66165.00 |
10-12-2023, 02:23 PM | #1785 |
Rep 7
Hi just wanted to share a few photos of my 2017 LBB M2 in manual. The car gives me such joy.
10-12-2023, 02:54 PM | #1786 |
Rep 50
10-14-2023, 05:04 PM | #1788 |
Rep 50
10-25-2023, 03:51 PM | #1789 |
The Seeker
13963
Rep 3,353
vrooooom326.00 IcewaterPete2188.50 |
10-26-2023, 09:46 AM | #1790 |
New BMW owner
326
Rep 844
^ My vote for the most reflective car out there.
///MPhatic13963.00 |
10-26-2023, 11:32 AM | #1792 |
New BMW owner
326
Rep 844
LBB
///MPhatic13963.00 Stylin.M2298.00 |
10-26-2023, 09:58 PM | #1794 |
The Seeker
13963
Rep 3,353
10-26-2023, 11:24 PM | #1795 |
New BMW owner
326
Rep 844
I'm sorry no. I used to use photobucket years ago but not even sure about them now. I can post some photos here. U want to see if they stick out of the fender? It doesn't. Yes original tires. I'll take some photos from the rear to see the "stretch".
10-27-2023, 09:00 AM | #1796 |
New BMW owner
326
Rep 844
10-27-2023, 11:20 AM | #1797 |
The Seeker
13963
Rep 3,353
Or you could send them to my email, or phone if it's easier. Love the look of the Anthracite on LBB, and I'm thinking of putting my PSS on the wider 9.5/10.5, and that's what you did, right? Looks good to me.
10-27-2023, 11:42 AM | #1798 |
Rep 967
No, stock size cup2...they came with the 763m wheels...10mm future classics spacers
What are you running?
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD Last edited by m2ss; 10-27-2023 at 11:52 AM.. |
10-27-2023, 07:24 PM | #1799 |
New BMW owner
326
Rep 844
My apologies for the dirty car. I realize many would cringe to see that. 😬 but in haste, here it is. Apex BMW standard size or stock pilot super sport (I can’t wait to finish) tires. No spacers. They are 19x9 & 19x10 ET40.
10-27-2023, 07:57 PM | #1800 |
New BMW owner
326
Rep 844
Tried to copy the same angle as m2ss. I like his position better. Looks like mine would need 10mm spacer to make it similar.
10-27-2023, 09:16 PM | #1801 |
The Seeker
13963
Rep 3,353
10-28-2023, 07:13 AM | #1802 | |
Rep 967
My wife has 12mm on rear and they poke too much for my taste. Preferred route would be no spacers wider wheels.
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD |
10-28-2023, 07:24 AM | #1803 |
New BMW owner
326
Rep 844
If I had gone with 10.5, would that have resulted to it being more flush to the fender? I just didn’t understand the whole width and ET40 stuff all too well. So went with the 100% sure.
M2SS, you’re on 10mm all around? You said future so I thought you’re just planning it.
10-28-2023, 08:15 AM | #1804 | |
The Seeker
13963
Rep 3,353
For example, stock wheel specs are: 19 x 9 +29 19 x 10 +40 Lowered to BMW's recommended 595/600 (vs 620/620 stock) and running stock tires people have determined that 12mm spacers in the front, and 10mm in the rear gets them acceptably-flush. So now we effectively have: 19 x 9 +17 19 x 10 +30 Now it comes to the tires, and if you're keeping the same overall diameter (which you should, and most people do), then it's all about tread width because tw is where the shoulder of the tire sits. Looking at the stock PSS star spec tires you get the following tread widths: 8.8 front 9.4 rear Looking at those numbers, and calculating from other tires, you will see that the front PSS 245 star spec is .4" too wide, which is why many people modifying their OE wheel specs have rubbing in the front, and not in the rear. 8.4 & 9.4 would have been perfect. In any case, once you have those numbers you can extrapolate from there. 19 x 9 + 17 with a 8.4 tw 19 x 10 +30 with a 9.4 tw Then you just use a calculator like willtheyfit.com to translate to whatever width of wheel you want. To get the same fitment as above with 9.5 & 10.5 it looks like this: 19 x 9.5 + 24 with an 8.4 tw tire 19 x 10.5 +37 with an 9.4 tw tire However, this results in even more stretch to the tire sidewall than stock, which is where people get in trouble with trying to do standard calculations on tire sizes without taking the specific tire tread widths into account. The difference between a 245 and 255 should be 10mm, but it's not. In fact, I can find you many 245's that are WIDER than other 255's, so you MUST take into account the specific tire you're looking for and its tread widths. We have tirerack to thank for providing this information on most tires. All of that is to say that generally, you can use... 9.5 + 22/23/24/25/26/27/28 10.5 +35/36/37/38/39/40/41/42/43/44/45 All will fit, depending on the specific tire/drop/suspension/camber you choose. Any modification to any of those parameters will result in you having to tailor your wheel offset. And now you see the rabbit hole. |
