11-28-2018, 03:34 PM | #1 |
4498
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 *** XDI Fuel Pump (HPFP) Support - Now Available!
Hey guys, over the past year we've worked with a number of customers and shops that chose the XDI's high flow pump as their HPFP upgrade. They have two versions available, the XDI-35 and the XDI-60, both of which outflow the OEM HPFP pump on the N55.
As of now any bootmod3 user looking to go with an XDI HPFP upgrade can go into any of their maps (custom or OTS), use the map configuration screen and choose the appropriate pump from a dropdown of options, screenshot attached. Note that simply installing one of these pumps and not making the changes will end up setting the car into limp mode (Drivetrain Malfunction) as well as throw various codes for fuel pressure so a map change is required to run them. For all questions related to the pumps please direct them at TTFS (TuningTechFS) who have done a great deal of work with XDI to make this upgrade happen when it comes to fitment and R&D and they're best to answer any questions. We're simply adding software support for the pumps to make the solution as Plug'n'Play as possible. We have seen a considerable improvement over the stock N55 pump on an M2 while tuning with TTFS end of last year and more recently on an N55 PWG car (both come with the same OEM HPFP pump). Here's a log of the N55-PWG car running the XDI-35 pump. As you can see there's no pressure drop at the HPFP XDI-35 HPFP on OTS 2H map, Pure Stage 2 turbo PWG car (no HPFP drop outside of traction loss event at around 3900rpm): http://www.bootmod3.net/log?id=5bcf486cd10b435a2d3651ce OEM HPFP on OTS 2H map, Pure Stage 2 turbo PWG car (400-500psi HPFP drop): http://services.bootmod3.net/log?id=...0b4365a7303ff0
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com Last edited by proTUNING Freaks; 11-28-2018 at 04:29 PM.. |
11-28-2018, 09:20 PM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Game Changer!
N55 guys will finally be able to make big power without external fueling mess or controllers
60-130mph 6.5s X4M #HCP
11-29-2018, 04:14 PM | #4 |
Rep 176
I have been running the 35 pump in my pure stage 2 (m235 xdrive) for several months. I'm local to TTFS who have been great. 20psi on 93 about 450 whp.
11-29-2018, 07:48 PM | #5 | |
Rep 2,577
Without meth, 20psi should require E50. Would be amazing to see a log.
Lemania 2320
11-29-2018, 08:32 PM | #6 | ||
Rep 176
I can go higher but I would need the 3.5 tmap sensor. There is also a torque limiter built in the trans. That's also a concern, I don't want to push that to it's limits. It's a daily driver. |
11-29-2018, 09:18 PM | #7 | |
Rep 2,577
Send/PM me a log please so I can provide my inputs and give you my log to compare as well. Thanks.
Lemania 2320
11-29-2018, 09:20 PM | #8 | ||
Rep 176
Believe it or not, that's fine. I don't come on here very often because I knew it would start with all this. |
booya_4586.50 |
11-29-2018, 09:34 PM | #9 | |
Rep 2,577
Good for you and I already was there or close half a year ago but eventually chose to back off, as M2 to me is the track and daily car. Below is a log this summer to show 19psi at top end under ~110F of IAT, stock fueling and 93OCT(98RON), zero ethanol zero meth. http://www.bootmod3.net/log?id=5b38d28fd10b437334792d1b I'm aware of what our car can do and just want to discuss more of it in this HPFP dedicated thread. Congrats.
Lemania 2320
11-29-2018, 09:38 PM | #10 | ||
Rep 176
I have got pretty much every conceivable modification......certainly been a work in progress. Sorry if I came over aggressive, but it just appeared to me you are calling bs. I have no reason to lie, if it was 16psi then great, couldn't care less I was just on here to give some insight as to what is possible, it's not a pissing competition. I'm off work early next week and will look for the usb drive. |
booya_4586.50 |
11-29-2018, 10:25 PM | #11 |
Rep 7,438
This is really awesome! Good job guys, it'll be more convenient to just tap a box and get support for the xdi pumps, rather than getting a calibration from ttfs and having to flash that before doing the final tune.
Are you guys developing flex fuel? To me that's the most desired/game changing feature that could occur on this platform. Also are you guys planning to add one touch support for the precision racewerks coils? |
11-30-2018, 04:21 PM | #13 |
Rep 7,438
12-02-2018, 10:12 PM | #15 | |
Rep 7,438
1) more power 2) dct agressively downshift putting more torque on the hub. 3) they even pointed to having two pumps putting more strain on the crank hub because it's driven off of it. Plus the 65 variant of the xdi single pump can flow up to 700whp on e85 from what I've heard from ttfs. |
12-03-2018, 03:03 AM | #16 |
Rep 4,521
UK car with 35 HPFP upgrade [+ inlet and boost pipe upgrade & NGK 97506 plugs]
453/550 power/torque at the crank on UK 99 RON More info in this BB forum link https://www.babybmw.net/forum/viewto...15144#p1444734
Current '22 X3M LCI.. |
nothingman522.00 Raymondo123467.50 |
12-03-2018, 05:12 AM | #17 | |
Rep 7,438
Raymondo123467.50 |
12-03-2018, 10:41 PM | #18 | |
Rep 2,577
Raymondo, trust me. I was actually very happy to see enthusiasts like you who mod tastefully, rather than go cheap way for big power. I share the philosophy.
When this HPFP mod came out early this year, I was trying really hard convincing myself to bite that 2k for it. Because in my book, a proper DI solution has always been the way, as opposed to adding extra injection (PI), a compromise with N55 for many years. Out of 10k BM3 users globally at this point, few can beat me on this - Halim (huge thanks) made me LITERALLY 30~40 Custom maps since early 2017. And outside of Halim, there are 12 from Cary Jordan, 7 from Dzenan Becic and 3 from Joseph Wu. From these some 60 dedicated custom maps, Rich/Lean, high/mild boost and more/less timing have been all tried. That is tons of log testing, and a couple track days. But in my case, fueling has been always much less of a problem. I'll tell you that knowing the restriction isn't the fueling really pissed me off, because I cannot improve via upgrading fueling like many of others do. One more thing - If you open map editing file, you'd be probably surprised to see our DME actually compensates very little, load wise, for temp. From BMW's point of view, they leave a good amount of headroom to handle environment variance so their cars perform consistently enough to their spec across all conditions. But once you tune, you lost most if not all that headroom (up to the tuning approach), therefore you'd be very vulnerable and sensitive to temp and need ultra high octane to handle everything. There're many clean logs at 70F (of IAT), 80 or ~90. But very few are doing great at 110, let alone 120~130+ IAT which is the track condition. Tuner don't tune to that condition because number wouldn't be pretty, customer would be unhappy and go away. Appreciated if you give input from your personal experience tuning your N55. Sean Quote:
Lemania 2320
12-04-2018, 01:38 AM | #19 | |
Rep 7,438
I'm glad this hpfp is now available as it'll let us push the car further and harder. In regards to the tune that's why I have a tuner sit in my car with me and go lap a track and make adjustments to the tune right there on the track. It's created on the Dyno but dialed in on the track. Water injection and e85 also help with IAT's, and I don't like using water meth especially on a track incase of roll overs. |
12-04-2018, 10:40 AM | #20 |
Rep 115
These costs are tough to swallow. Really tough. Basically to really benefit you need a bigger turbo to justify the bigger fuel pump.
I feel like a safe 460-480whp would be a riot in a well setup 2 series. More so the M2 as it can fit a little bigger tire. Approaching 500whp would be icing on the cake. Unfortunately, it's quite the endeavor to get there. $2300 fuel pump, $2500 turbo, $600-ish in other install bits, plus whatever your labor is or a shop's labor is. $5500ish is a lot of money.
2014 M235i
12-18-2018, 02:09 PM | #22 |
Rep 7,438
Tags |
bm3, bootmod3 |
