08-04-2022, 11:12 AM | #1 |
Rep 263
M2 competition rear axle oil
Hello, I need to replace the rear differential oil on my M2 C.
I wanted to put "castrol transmax limited slip 70w140 or Motul Gear Compétition 75W 140 "I don't know why but these oils cannot be found in EUROPE at the moment. Can you tell me if "RAVENOL Transmission oil SLS SAE 75W-140 GL 5 LS" can fit and if it is as good as the other two. thank you |
08-04-2022, 12:42 PM | #3 |
Rep 263
In BELGIUM, BMW likes to scam people on oil (laughs), I asked for the price, it's almost 40€/L.
I'm not stingy but not crazy either. For example, engine oil at BMW 0w30 is 36€/L. I bought a 20L container of CASTROL 5w30 M for 8.5€/L. If I have no choice, I will take BMW. |
08-04-2022, 12:47 PM | #4 |
847
Rep 1,962
You can - apparently - buy the oil you're after from Italy on eBay. it will cost significantly more than 40€/L as it isn't engine oil.
But, why do you need to change it? Castrol themselves suggest a 90000 km/ 72 months service interval. HTH |
08-04-2022, 12:50 PM | #5 | |
Rep 7,340
F87source7359.50 |
08-04-2022, 01:37 PM | #6 |
Rep 263
my car is 4 years old and for the price it costs it would be stupid to deprive yourself of it. Maybe by chance, but I have always replaced my oils regularly and I have never had a problem.
08-04-2022, 01:57 PM | #7 |
Rep 263
on the CASTROL site, I cannot find the information if it is SAF-XJ but for the M2 C castrol recommends TRANSMAX (not SYNTRAX)
08-04-2022, 02:25 PM | #8 | |
847
Rep 1,962
You're still 2 years inside the recommended service interval, so relax and stick with the recommended (current) product when it's actually due. Unless you're a Drift racer. |
08-04-2022, 02:49 PM | #9 | |
Rep 7,340
I would still just use the BMW MSP/A or whatever is the latest recommendation. I believe it is 83222365988. Last edited by chris719; 08-04-2022 at 03:05 PM.. |
F87source7359.50 |
08-04-2022, 07:07 PM | #10 | |
Rep 7,536
The reason why I didn't buy Castrol syntrax limited slip gear oil was because it is also compatible with the E9X m3 which requires more friction modifiers to stay quiet and operate optimally. So if this gear oil works with the E9x m3 will it have too much friction modifiers for the F8x e-diff? I emailed castrol to ask about this and they could not dig up any more technical data or certifications from bmw, so it really didn't give me any extra confidence, so I would just stick with OEM fluids.
08-04-2022, 11:06 PM | #12 | |
Rep 7,536
In summary yes, don't take any risks with the diff, stick with OEM fluids you get at the dealership. With the transmission and engine oil you can experiment, with the diff don't mess around.
08-04-2022, 11:54 PM | #13 |
Rep 263
TRANSMAX is a limited slip differential oil or else they write lies on their website
https://www.castrol.com/fr_be/belgiu...f%C3%A9rentiel |
08-05-2022, 12:14 AM | #14 | |
Rep 7,340
08-05-2022, 12:51 AM | #15 |
Rep 263
not at all, following our discussions it is certain that I will take the oem oil as we are not on CASTROL oil or another brand.
If I was sure that castrol oil was good I will definitely take it, what pay more for the same thing, but that is not the case so I will take oem |
chris7197390.50 |
08-05-2022, 01:29 AM | #16 | |
Rep 7,536
Very interesting find, I think that's European only as I cannot find this in any north American shops. But here are a few concerns: 1) I can't check if it's bmw certified via ista because my ista is a few years out of date, so I can't verify it for you. But Castrol is unlikely to lie so bmw probably did approve it. 2) is it also e9x m3 and f8x compatible? Because that leads me to be worried there is too much FM, and we know the saf - xj + FM blows the f8x diffs, and witbout the extra FM the e9x diffs get loud and clunky. This is the same dibacle I had with syntrax which is listed in ista as compatible. If you can get Castrol to clear things up for you then that'll be more confidence inspiring that my thought experiment. Again, these diffs are pretty sensitive so imo I'd only go OEM fluids. There's a reason why bmw sells a different fluid for the e9x and f8x diffs, and it's not one size fits all. Real OEM: https://www.realoem.com/bmw/enUS/part?id=KG93-USA-06-2013-E92N-BMW-M3&mg=33&sg=05&diagId=33_1418&q=83222282583 This is the e9x diffs oil, notice it requires a booster. This is an ecs tuning link: https://www.ecstuning.com/b-genuine-bmw-parts/motorsport-rear-differential-fluid-saf-xjfm-5-liter/83222282583/ The booster is additional fm. |
08-05-2022, 01:33 AM | #17 | |
Rep 7,536
But in this case I couldn't quell my ocd knowing that bmw sells 2 different oils, and that if you mix it up the f8x diffs (which are know to be finnicky) will fail. So it was just better to stick with OEM imo, especially since these diffs have had their fair share of reliability issues.
08-05-2022, 01:49 AM | #18 |
Rep 263
the limited-slip differentials are so finicky on the f8x. I will contact CASTROL for more information. the technologies are so different between f8x and E9x that only FM does damage
08-05-2022, 02:13 AM | #19 | |
847
Rep 1,962
08-05-2022, 02:24 AM | #20 | |
Rep 7,536
But don't forget, all lsd's have FM (friction modifiers) it's the amount that makes the difference. The e9x diffs use diff oil with FM booster, and that extra booster damages the f8x e-diff. So it's not the FM that causes the damage, it's how much. Last edited by F87source; 08-05-2022 at 02:30 AM.. |
08-05-2022, 02:28 AM | #21 | |
Rep 7,536
Unfortunately we cannot determine a suitable product for your vehicle. This may be because we do not have a product that matches your vehicle�s specifications, or more information regarding your vehicle is needed. Please contact your local Castrol retailer for a specific product recommendation." Regardless I don't use a manufacturers website to look for product compatibility, that's how you end up using some product that "meets the oem's specifications" but was never actually approved. I go through the OEM and find actual approved fluids. |
