04-21-2017, 12:00 AM | #45 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Your random throttle blips while coasting to a light were probably the stick being close to other gates (were you wiggling it around with your left foot down?), which would be the revmatch trying to blip for downshifts that you weren't actually making.
04-21-2017, 07:56 AM | #46 | ||
Rep 85
I agree that being able to rev the car to redline and still get appreciable power throughout the RPM range is great; I drove a high revving 4-banger in my earlier days... But I'm not fond of the half second hesitation that the N55 seems to suffer between pedal input and turbo response. If the N54 I also drive wasn't appreciably more responsive, I wouldn't have any qualms.... But being able to drive them side-by-side.... Well, once you see it, you can't unsee it. Hoping that my perception changes after break-in. |
04-21-2017, 08:17 AM | #47 | |
Rep 790
Throttle response is not the same as turbo lag. Throttle response is how quickly the engine responds to throttle input. Turbo lag is the delay between engine response and the power boost from the turbo kicking in. If you are using Sport+ setting that is strange you see that delay in throttle response. Last edited by Bluenose-2er; 04-21-2017 at 11:35 AM.. |
ZPrime611.50 |
04-21-2017, 08:28 AM | #48 | ||
Rep 85
And I agree with the definition regarding throttle response and turbo lag. Throttle response isn't the problem with this car (especially in Sport+). |
04-21-2017, 11:32 AM | #49 | ||
Rep 252
Does it blip as you start to lift the clutch? |
04-21-2017, 03:22 PM | #50 |
I INDIC8
612
Rep 1,286
The only way to fully defeat revmatch is to fully disable traction control, which requires long-holding the DSC button for 5-10 seconds until the light comes on in the dash.
Sport+ puts the traction into "M Dynamic Mode" (MDM), where it is still on but a bit more permissive than usual. AFAIK, you get the exact same thing by just short-pressing the DSC button without using Sport+. (I don't actually own a BMW yet to test all of this firsthand, just going off of what I've read.) This whole "MDM" thing is so damn confusing - Audi just calls it "Sport" traction control and it's invoked the same way (short press of the traction control button). Audi also changes nothing else when you push traction control... the manual from BWM implies that throttle response is also altered when you're in MDM / "sport DSC"... I'm not exactly sure why they do this. This thread elsewhere on the forum (thanks Artemis!) is very informative as far as the traction control/DSC modes go along with the "Driving Dynamics Control" (DDC / "drive program") are concerned. The revmatching presumably uses hall-effect sensors (magnetic) mounted in the gearbox or on the shift lever somewhere so it knows what gear you are about to get into, just before you actually fully slot the lever there. That's when the blip happens on downshifts - as the stick is moving, and ideally before you let the clutch out. If you keep your foot on the clutch too long and screw around, it "cancels" the revmatch and will let RPMs drop to idle like a normal car.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 04-21-2017 at 03:30 PM.. |
04-21-2017, 04:35 PM | #51 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
^Tapping the DSC button puts it into MDM (traction) mode. It also nueters throttle response the same as comfort/DSC completely off. Sports+ is the way to go for me.
06-05-2017, 09:03 AM | #52 |
Rep 93
I notice the lag too after shifts. I assume that since you go from full throttle to idle during a upshift, the blowoff valve lets all the pressurized air out and once you go back to full throttle it has to start over and build boost again. I haven't driven one with a dct but I assume it wouldn't be as noticable if at all. I would also assume a sport downpipe would help but due to the nature of a turbo motor, I don't think it can be eliminated.
I however am not a BMW engineer though!
2024 GLS
2016 X5 |
06-05-2017, 10:13 AM | #53 | |
Rep 4,253
///M Power
06-05-2017, 10:49 AM | #54 |
Rep 7,594
Drives: '19 M2C
I agree. With the DCT in Sport - I don't feel any lag.
www.ReTuneTheDeTune.com
