BIMMERPOST Universal Forums > Off-Topic Discussions Board > Back to summers ?
      04-10-2017, 10:34 AM   #1
jaye944
Drives: a
Back to summers ?
SO here in Toronto, the weather is anything but consistent.
Which brings me to changing back to summers.
The day time weather is into the teens at times, but night time lows are still below 7.
I've attached some screenshots. SO this is WHAT I generally do
WINTERS = when temps are 7 or below (over a 5 day period) that is night time or lowest
SUMMERS = when temps are 7 or above (over a 5 day period) again judging by the night time
however day times are all over the place...
I'm worried about safety and tire wear
your thoughts
      04-10-2017, 11:02 AM   #2
overcoil
Drives: M235i 6spd
Probably just wait till May first.
I'd run my Michelin summers through two mid-atlactic winters, the cold weather itself never caused chunking like I read described on some Pirelli and Goodyear tires. Cold rain not an issue for me, but 1/4 inch of snow or freezing rain coating road surface just not worth the hassle on hills or braking
      04-10-2017, 11:34 AM   #3
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Can be a little sketchy with full summers yet.
At least in the early morning, if melt water has frozen on the road.
jaye9441014.00
      04-10-2017, 11:42 AM   #4
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
your thoughts
As someone who lives in Quebec, I would say hold off until the first week of May and then swap to summers if the temperatures are stable.
Last year I did that, and it still snowed in may but I had all seasons on, and there was less than 2cm of snow on the ground and the temperature was around -2C. It disappeared the next day and was at a stable 10-12C for the next few weeks.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
jaye9441014.00
      04-10-2017, 01:23 PM   #5
TomHudson
Drives: 2011 E90 M3
Got the BBS CH R's on Saturday.
Have to careful if it's cold; but otherwise taking advantage of every single warm day this country gives me....
      04-10-2017, 01:45 PM   #6
Joekerr
7929
Drives: 2017 Audi S6
I'm waiting a bit longer. Sometime in May. Plus, this is the last season I think I'll use these snows, so I don't really care if they get chewed up a little in the warmer temps.
jaye9441014.00
      04-10-2017, 02:35 PM   #7
Maynard
Drives: 228iX & M2C
I would bias it towards being later putting on summers, rather than earlier. Before trading in my last car I ran it all summer on the winter tires, b/c I knew I was turning it in on them (Conti Wintercontacts). I was expecting it to just burn them right down, but they hardly showed wear. So now I wait a little longer, until confident it is above 40 (5 to you metrics) - the summer tires do chunk and crack if it is too cold, and real problems if you get caught out in a late snow, even if only a little dusting. I found a doctor who can induce one of those propofol comas for the next 2 weeks, that helps me with my impatience to get onto the summers .
jaye9441014.00
      04-10-2017, 06:44 PM   #8
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
Put them back on a month ago with no regrets.
With how useless our winters have been lately, I'm debating even switching back in the fall.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
jaye9441014.00
      04-10-2017, 07:05 PM   #9
Eau_Rouge111
Eau_Rouge111's Avatar
356
Drives: 2009 128i and 2007 Z4M Coupe
I live in Mississauga and put mine on last week...
jaye9441014.00
      04-10-2017, 07:06 PM   #10
Eau_Rouge111
356
Just need to wash it REALLY BAD
      04-10-2017, 07:12 PM   #11
jaye944
Drives: a
txs all,
I'm being a bit wussy, so yes I'll wait I think
it's the day time temps that give me the itches.
but I start early morning (out on the road at 430-5am) so I'm driving at the lowest part of the day...
      04-10-2017, 07:17 PM   #12
Eau_Rouge111
356
txs all,
This whole 7 degrees stuff is a bit much unless you are absolutely pushing the car to the limit...you won't notice a difference. For the last 15 years...I change to winters literally the day it snows...so many days of below 7 degrees before that...and switch at the earliest day I can back to summers as I hate soft sidewall tires...again...never had an issue.
But it's comfort thing so if you feel like you need to wait a bit longer than definitely wait a bit til you are comfortable switching back to summers. Cheers, Rui.
Maynard3848.00
      04-11-2017, 11:11 AM   #13
Alfisti
Drives: 2008 Saab 9-3 Combi
I changed already but to all seasons, summers made no sense when shopping as there is limited selection at a very high price and I hardly drive a sports car.
      04-22-2017, 10:53 AM   #14
jaye944
Drives: a
txs all,
when I got into the car the other day and I thought, "phew it's hot in here"
I knew then
booked my car in for next week, as they guys fully booked this week LOLZ
      04-22-2017, 12:01 PM   #15
bosstones
Drives: o_0
Oh, you metric system folks... j/k
In general, it seems that the Spring season is fairly short. Here in Chicago, the weather has fluctuated quite a bit. As someone who likes it cold, though, I don't mind. I still have snows on my X1 but will probably take them off since I still have the stock A/S RF's on my other set of wheels. Around here, I always expect one more snow once the weather is warmed for a while and the ground thawed. We had that last ditch effort by Old Man Winter already so we should be good to go.
      04-22-2017, 01:14 PM   #16
Maynard
Drives: 228iX & M2C
Are you running Michelin MPSS or Conti Extremes? If not, what (especially is it all-season or summer performance)? I'm interested, as I try to avoid the sub-7c out of fear I'll tear the hell out of the tread (they warn of chunking/cracks), would love to know I don't have to be so careful. Mine go back on Thursday - forgot to call ahead far enough and they were booked this weekend, so I'm washing her instead.
      04-22-2017, 01:21 PM   #17
Eau_Rouge111
356
If you r referring to my 1 series?? Tires are Toyo T1 proxies...great tires...zero issues.
if you r referring to my Z4M Coupe...Michelin PSS...again...great tire and zero issues
On both cars...they get pushed hard too. You can't go wrong with either tire.
My father has Conti tires on his 335 and on his Z4M...I've never heard him complain about Conti tires either.
And again...both my father and myself wait til the day it snows to switch to snows and switch back at the earliest day in the spring...doing it this way for 15 years...ZERO issues
Hope this helps!
      04-22-2017, 03:22 PM   #18
Eau_Rouge111
356
Hope this helps!
Maynard3848.00
      04-22-2017, 04:29 PM   #19
Maynard
Drives: 228iX & M2C
Good to hear. The last month has been tough to wait out, next year I'll switch earlier.
      04-24-2017, 06:20 PM   #20
cmyx6go
cmyx6go's Avatar
15761
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Nothing wussy about being safe. And I can feel the difference with summer tires on dry cold roads. I'll probably make the switch this week. Id rather eat up my winters than slip on my summers.
jaye9441014.00
      05-02-2017, 02:09 PM   #21
catcher22
Drives: 2008 335xi Coupe
I generally switch to winters just before Thanksgiving (US Thanksgiving, the end of November ) and put summers back on in late March. But I'm down in Virginia so it's a bit warmer than Toronto lol
Another general rule is once there is no chance for overnight frost, the season is warm enough to put summers on. But I just made that up a couple years ago lol
      05-02-2017, 03:20 PM   #22
MightyMouseTech
4338
Just saw in the weather forecast for Ottawa, could get snow next week. :lol
Meh, won't drive the summer car that day.
