04-03-2017, 09:37 AM | #23 |
Long Time Admirer, First Time Owner
17998
Rep 9,378
The source gas and venting requirements are why I still have 50 gallons of water on the side of my house. My current 3/4 gas line comes from the neighbor's yard, under the house, and over to the heater side. GasCo would have to run a whole new line from the street to get me to 1.5" The current vent would need to increase to something like a 4" hole in the roof, about double the current size. I just have a hard time with cutting holes in the roof.
But, in the likely event of earthquake, I have 50 gallons before I have to drink out of the toilet. . . |
04-24-2017, 09:52 AM | #24 | |
Rep 1,268
My research found that it is a good idea to put in a recirculating systems for long runs for hot water, what it does it circulates back the cold water until it is up to temp then it opens a value and let the hot water flow, it does two thing, help save water, it also helps saving a little heating energy since it does not have to spend as much time heating up cold water. I was going to retro my current house with a tankless system, had two teenagers who loved long showers, but after finding out all the venting requirements and other things need to make it work correct I did not bother. Also higher end dishwasher have their own heater. My dishwasher take my normal 140F hot water and heats it to 185F. |
04-24-2017, 10:36 AM | #25 | |
Rep 4,107
Yes, you can do the re-circulating but our house is only 2,600 sq ft so the distance the hot water has to travel is never that great. This is why we did not install the re-circulating option. As for venting, the original tankless was installed before we purchased the house. When we upgraded we found the venting was not up to code so we did have to correct that but I did not find a major issue. And yes, modern, high-end dishwashers can heat water though I am not well versed on how efficient they are relative to the tankless heater. Just out of habit I let the hot water run until it is hot at the kitchen sink before starting the dishwasher...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 Last edited by kscarrol; 04-24-2017 at 10:42 AM.. |
04-26-2017, 06:12 AM | #26 |
dances with roads
4722
Rep 4,096
Dishwashers use electric heating elements. Cost compared to central water heater will be "it depends" but my bet would be that you're spending more by letting the water run until it's hot than you would by letting the dishwasher handle it.
04-26-2017, 08:38 AM | #27 |
Rep 4,107
^ I have no data to dispute this but it sounds like you're going on a hunch as well. I have to think my tankless gas heater is more efficient at heating water than an electric heating element in my dishwasher. The offset of course is running the hot water for 30 seconds before starting the dishwasher! Ultimately the dishwasher is connected to the hot water line and is going to demand hot water, activating the tankless anyway so I imagine any cost difference is quite small...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
04-26-2017, 01:19 PM | #28 |
Rep 388
I have 2 tankless water heaters at my house. One for the upstairs and one for downstairs.
I also added buttons to turn on the water heaters in advance in the kitchen, master bath, and guest rooms. You push the little button, wait one or two minutes and you have piping hot water. No need to wait. The newer models are much better and more efficient then the models of even 5 years ago. I would highly recommend it.
21' Bentley Bentayga SPEED
21' BMW Alpina XB7 22' Cadillac Escalade ESV 22' Porsche Cayenne Turbo 24' Porsche GT4RS on order |
04-26-2017, 01:46 PM | #29 | |
"Salud"
13837
Rep 4,675
Drives: F01 & F15 / Mineral White
04-26-2017, 02:02 PM | #30 |
Rep 3,006
Forget if I have a A or S series?
http://us.navien.com/Product/Category-NPE-A%20series/ http://us.navien.com/Product/Category-NPE-S%20series/ |
04-26-2017, 02:51 PM | #31 |
Rep 623
I was watching 'This old house' On PBS and they were talking about a hybrid system that has a 5 gallon tank on a Tankless Design. It sound like just what I need, not sure if it is ten times the cost as most items are from that show.
Steve |
04-26-2017, 04:17 PM | #32 |
Rep 591
My house have a navien tankless unit.
Good things as other have already said, endless hot water, no / low risk of leak, etc. But for my particular unit sometimes it take a while to run the hot water for it to start heating up (in some extreme cases can take couple of minutes, but most of the time heat water would start coming out in less than 30s). Never quite figured out why there is such a big variance of heatup time. Had couple of plumber took a look they have no good explanation neither. That brings to my biggest gripe about these heaters - they're complicated machines. Most of the plumber really don't know very deep about them. They can install them, but if something goes wrong with them, in my experience it's hard to find people knowledgeable enough to give good diagnosis on them... |
04-26-2017, 09:49 PM | #33 | |
Rep 755
04-26-2017, 10:38 PM | #34 | |
Rep 591
i feel like if anything seriously goes wrong with these heater, it would probably be time to get a new one instead of trying to repair them... |
04-27-2017, 08:39 AM | #35 | |
Rep 755
04-27-2017, 08:51 AM | #36 | |
Rep 3,006
Just knowing I have endless hot water overcomes any downsides for me. |
04-27-2017, 08:52 AM | #37 | |
Rep 3,006
05-02-2017, 10:16 AM | #38 | |
Rep 1,268
05-02-2017, 02:11 PM | #39 | |
dances with roads
4722
Rep 4,096
I had an out-of-the-box issue with mine, fixed it with help directly from the Bosch folks. We diagnosed it over the phone, they overnighted the part, two spring clips and a wire connector, bada-bing. Plumber was thrilled to let me do it, he was out of his depth. On the other hand he did a first rate installation job and knew all the building code foo plus tricks learned from other installs. Just don't ask him to fix it. |
05-02-2017, 09:19 PM | #41 |
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
That's what most European houses have had for years.
AIRPOWER
05-05-2017, 04:40 PM | #42 |
Rep 2,665
I also put a gas tankless in recently. It had a couple of issues with it and Westinghouse sent me the parts. Replaced a mixing valve, it wasn't the problem, sent me a whole new electronics board for it. Even when broken I was able to turn it off and then back on and it would work for a while. Now 4 months later I am happy with it.
I did half of the install, mounted it to the wall and ran the exhaust and inlet outside. Decent hassle but if it ever has to get replaced again it will be far simpler. Takes a little longer to get hot water but it cuts down the flow some until it gets there. So when taking a shower I turn it on earlier than I used to and not seeing a big issue with it. I would do it again.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
08-11-2017, 07:26 PM | #43 |
Rep 4,821
So 4 months later...
This isn't happening. Major electrical work required to get an electric tankless heater. Alternatively we could go with a gas tankless heater if we bury a propane tank in the yard (above ground not allowed where I live). So, the end result is skipping the tub in the bathroom remodel because it would cost $10K - $15K for tub / heater / electric or gas. (There is a tub in another bathroom.) We are just gonna stick with a new tank for the shower and sinks and leave it at that. Unbelievable how much time it took to reach this conclusion.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
