M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Euro MDM on US M2s = Awesome
      01-23-2017, 06:16 PM   #23
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
Originally Posted by 6734202 View Post
What are A/F/A+F values?
I also wonder what those things mean in sport?
And in he M2 is MDM the single press of DSC?
When in comfort or sport and you single press DSC then you switch to MDM mode in comfort... You can not get MDM in sport...when you select sport + you also have MDM active.
      02-03-2017, 07:08 AM   #24
Hossel19
62
Originally Posted by Pyrat 2 View Post
Slightly off topic but why would they have a different mode for Europe than the US? At first I thought some dot law but that doesn't make sense since that have a dsc off mode that disables it all.
BMW assumes European drivers are more skilled then on this side of the Atlantic so Euro MDM is more permissive (larger slip angle).... They are probably right.
      02-03-2017, 08:12 AM   #25
Lucho13
Peru
64
Drives: BMW M2 (F87)
So... I live in Peru, do I have a Latin-America setting of MDM mode? Is it more or less aggressive than the US version? How can I know?
      02-03-2017, 11:11 AM   #26
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Check FDL's
      02-03-2017, 02:35 PM   #27
David1
David1's Avatar
Drives: 09 E92 09 X5
My understanding is that traction mode is the MDM mode and you still need to activate it in sport plus and it will say "TRACTION" in the cluster. The owners manual is no fricking help on this topic.I don't think the chart on page one is 100% correct.
BAN_M2C4171.00
      02-03-2017, 05:35 PM   #28
Mint
Drives: 2016 M2 6MT
So I applied this change yesterday but didn't restart my car after coding the module. I drove around a little and honestly didn't notice much of a change. But it could be due to the lack of the restart.
I'll drive it around a bit more and report back with my own conclusion.
      04-05-2017, 06:02 PM   #29
Leduardol
Hey guys,
I coded my M2 by changing the one setting (c_laender...) to ECE. I can definitely tell the difference. I was showing what the car can do to a friend and, honestly, had completely forgotten I was on Euro MDM. I took a turn accelerating to try and get sideways (under normal MDM, you gotta be aggressive) and ended up spinning about 70 degrees.
The car is ok and of course we are ok, but just wanted to share this with the group. I was half expecting Euro MDM to be more restrictive than it seems to be, which is COMPLETELY fine I guess, but be careful, you can definitely get in trouble.
I have been reading up on the other settings that people mention, but I can't tell you with certainty whether they are needed. They may help tame Euro MDM, so still reading up. Will share my findings.
      04-05-2017, 08:19 PM   #30
Leduardol
I am now 99% sure we only need to change the C_Laender... value to ECE. Also, Euro MDM almost doesn't intervene if you are going less than 20 mph or so, which explains my spin.
Source: Reading the entire thread on the M4 site.
      04-06-2017, 01:50 AM   #31
DivideBYZero
DivideBYZero's Avatar
484
Drives: F87 M2<E92 M3<E46 M3
On my UK car the Sport+ mode is a restrictive bitch. Traction/"Hidden Exhaust" mode is much more permissive on both wheel slip and lateral slip, just like "real" MDM was on my E92 M3. My point being I don't believe that Sport+ is MDM, but Traction mode certainly is.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      04-06-2017, 05:23 PM   #32
Leduardol
It would be interesting to see what your values are coded to. In my experience, traction mode and Euro MDM are pretty close in terms of permissiveness.
      04-17-2017, 09:52 AM   #33
MZWIE
What module is C_leander in.
      04-17-2017, 01:20 PM   #34
Almaretto
Almaretto's Avatar
2374
DSC
      04-17-2017, 01:27 PM   #35
MZWIE
Using BIMMERCODE. DSC is not one of the modules listed. I would imagine that it might be FEM but can't locate there.
What is the actual full parameter designation.
      04-17-2017, 02:01 PM   #36
Almaretto
Almaretto's Avatar
2374
ICM?
      04-18-2017, 03:39 PM   #37
japanaltaf
Drives: 2019 AW X3 M40i
This is how I have it on my coding sheet -
DSC Module
Enable Euro MDM
3000 -> C_Laenderkennung
set to: ECE
      04-18-2017, 09:55 PM   #38
Leduardol
I don't believe Bimmercode supports coding the DSC module yet. You will have to use ESys.
      04-19-2017, 10:02 AM   #39
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
Correct. Coding of DSC module is not available yet. Stephan is working on it though, keep an eye out on the Bimmercode-specific thread, he's supposed to let us know when it's available.
      04-19-2017, 05:39 PM   #40
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
i tried taking a sharp left turn off a red light today (in Sport+ with Euro MDM coded in) and i got the traction light intervention. I couldn't have been going more than 20mph and the road was dry, so i really can't tell/don't feel much of a difference between US and Euro MDM to be honest.
      04-22-2017, 09:58 AM   #41
Mint
Drives: 2016 M2 6MT
I've noticed its very nonrestrictive in 1st gear but in 2nd gear i find it way too restrictive for my tastes.
Can you step your tail out in 2nd gear by mashing on the throttle during corn exits?
      04-22-2017, 10:01 AM   #42
Mint
Drives: 2016 M2 6MT
I have similar experiences to you.. In 1st gear I can step the tail out slightly, but in order to step it out a decent amount in 2nd gear, it needs to be on cold tires, a little damp or I need to aggressively throw the car into the turn.
I'm a little bummed out by it - I wish it was more permissive.
      04-22-2017, 10:41 PM   #43
Twt
Twt's Avatar
634
Drives: 2017 M2
This is my slide at Sebring with Euro MDM....
pretty descent angle.
      04-24-2017, 05:52 PM   #44
Leduardol
Did you save it or did it intervene?
