09-25-2016, 06:27 AM | #1 |
Rep 624
Need more rear camber!!
I drive a lot of trackdays and autoX. I run on Michelin Pilot Sport Cup 2.
With the original front camber of 1,3 degrees I got some nasty wear on the front tires outer shoulders. I bought camber plates, set wheels to 3 degrees and this shoulder wear was gone. The front tires now wear down nice and evenly. BUT... I still get this nasty tire shoulder wear at the rear. We've set camber to max what is possible which is just over 2 degrees. I'm pretty sure swapping to Kumho V70 would solve it, they have a totally different carcass but I have the MPSC2 on and can't justify just throwing them out. Anyone else having similar problems with the rear? |
09-25-2016, 08:04 AM | #3 |
Rep 278
That would explain this post on page 48 of the what did you do to your M2 today thread...
M3 Adjuster7904.50 |
09-25-2016, 08:53 AM | #4 |
Rep 2,560
Drives: Rapidly from A to B
Not seeing what you are. I'm at Road America right now. This is drivers rear. 3 track days plus 4500. Will be 4 track days after today.
09-25-2016, 10:18 AM | #5 |
Rep 624
Those are MPSS or MPSC2? What hot pressure do you run?
09-25-2016, 10:41 AM | #6 |
Rep 2,560
MPSS. Hot at 36 all around. Cold was around 28, 29, 30, 30 for lf, rf, lr, rr.
09-26-2016, 10:23 PM | #7 |
3814
Rep 54,307
Drives: F80 M3
How much more camber do you need? OEM adjustments should allow more than -2. Reduce body roll will help roll induced camber changes.
09-27-2016, 04:31 AM | #8 | |
Rep 624
The Öhlin Road and Track kit which is on the car has AFAIK stiffer springs than OEM which should already help with body roll. At least a bit. Seems I need some hardware to extend adjustable camber range or swap to other tire model. |
09-27-2016, 11:52 AM | #9 | |
3814
Rep 54,307
Drives: F80 M3
09-27-2016, 12:35 PM | #10 | |
Rep 624
Where can I find adjustable upper links? |
09-27-2016, 02:30 PM | #11 |
3814
Rep 54,307
Drives: F80 M3
09-29-2016, 05:37 AM | #12 | |
Not-So-New Member
103
Rep 61
Current: 2016 BMW ///M2 Black Sapphire Metallic / 6MT
SOLD: 2002 BMW ///M3 Matte Grey Metallic / SMG Core of WrongFitmentCocks |
10-10-2016, 02:18 PM | #14 | |
Rep 624
"Please note that the camber shim kit does not increase the amount of available camber adjustability, but rather rigidly fixes the camber adjustment you make" http://ind-distribution.com/ind/bran...amber-shim-kit |
10-10-2016, 02:22 PM | #15 |
Rep 2,342
What that means is you cannot set the camber to your choosing. So if you needed a specific -2.4 you may or may not not get it. The shims set a specific range of negative camber. If you use the 4mm shim the camber you get is the camber you get, plus the range of the factory.
04-21-2017, 05:40 AM | #16 |
Rep 665
Same problem. Stock suspension, stock setting, the outer wears a lot more and shoulder wear problem too, the inner look hella new...
Upper link adjustable kit anyone? recommendation? |
04-21-2017, 08:24 AM | #17 |
Rep 185
Well, the answer isn't just continually adding more camber, its increasing roll stiffness and caster. Do in this order: Increase positive caster at the front if possible, and run stiffer sway bars and stiffer lowering springs. Its a bit surprising that this car requires so much camber - about the same as a 70's Japanese car. I would have thought the design would be a bit more sophisticated these days like some other brands multi-links with virtual roll centers.
04-21-2017, 11:18 AM | #19 | |
Rep 3,714
