08-24-2016, 09:13 PM | #1 |
Rep 169
Which suspension pieces would you get from Fall Line Motorsports or Rogue Engineering
Fall Line have many suspension parts...
Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Race Fall Line Motorsports F8X M2/M3/M4 Rear Camber Shim Kit Fall Line Motorsports F8X M2/M3/M4 Front Mono Ball Conversion Kit Fall Line Motorsports F8X M2/M3/M4 Rear Upper Control Arm Bearing Kit Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Standard Fall Line Motorsports F8X M2/M3/M4 Front Sway Bar End Link Kit Fall Line Motorsports F8X M2/M3/M4 Rear Sway Bar End Link Kit All fits Rogue Engineering have these? Please fill me in on parts I miss listed... ROGUE ENGINEERING FRONT TENSION ARM BUSHING (E9X, E60, E39, E82, F8X) (which part is the same in Fall Line?) ROGUE ENGINEERING MONOBALL FRONT TENSION ARM BUSHING (E9X, E82, F8X, F2X, F3X) (which part is the same in Fall Line?) ROGUE ENGINEERING ADJUSTABLE SWAYBAR LINKS (Front found, have rears?)) ROGUE ENGINEERING E82/E9X ADJUSTABLE REAR CAMBER LINK SET I just want decent handling for mostly street driving for now and local track in the future, thanks... |
08-25-2016, 09:29 PM | #2 |
Rep 169
Decided on
Fall Line Motorsports F8X M2/M3/M4 Front Sway Bar End Link Kit Fall Line Motorsports F8X M2/M3/M4 Rear Sway Bar End Link Kit Goodridge S.S. brake lines first... |
09-10-2016, 05:02 PM | #3 |
3843
Rep 54,362
Drives: F80 M3
I say none to start unless you want lots of noise down the road.
09-11-2016, 09:13 AM | #4 | |
Rep 169
Goodridge S.S. brake lines a must Fall Line Motorsports F8X M2/M3/M4 Front Sway Bar End Link Kit Fall Line Motorsports F8X M2/M3/M4 Rear Sway Bar End Link Kit Not necessary but factory pieces look cheap... |
09-11-2016, 11:31 AM | #5 |
3843
Rep 54,362
Drives: F80 M3
OEM pieces perform just fine. If you can tolerate the noisy links down the road, get them. You will benefit so much more from a set of camber plates, tires or quality coilovers.
SS lines is a good upgrade for track duty for abrasion resistance. |
srironman91156.00 |
09-11-2016, 11:50 AM | #6 | |
Rep 169
05-02-2017, 12:38 PM | #8 |
3843
Rep 54,362
Drives: F80 M3
