07-16-2022, 01:24 AM | #1 |
Rep 660
N55 PS2 Stage 2+ MM E30 "Wavy" AFR at the Top End
Hey all,
I'm trying to sort out one remaining issue before I go for a full custom tune on my PS2. https://www.bootmod3.net/log?id=62c8...0b43079f4be448 Looking at the log above, besides the timing correction on cylinder 1 (which I will try to fix by adding a bit more E), everything looks to be normal except the AFR between 5.5k-7k RPM. The boost targets are being hit and HPFP is performing okay. But for some reason the AFR is spiking up and down between ~12.5 on the low end and~13.5 on the high end. I do notice the STFT also jumping between 0.88 and 0.92 which seems to coincide with the AFR waves. So it seems to me the engine is actively compensating for something? I've been messaging BM3 regarding this behavior on the map and they think it could be related to the injectors (this is after I already replaced basically everything, from gapped NGK spark plugs to B58 coils). My impression was that if my injectors were bad I would know quite quickly with misfires and such. Is it possible for injectors to display intermittent issues at WOT at high boost? Potentially relevant - there is one thing that has been bothering me - after I installed my PS2 I got an annoying harmonic sound (almost like a kazoo that switched between 2 or 3 notes depending on load) coming from my cold air intake. I swapped back to the stock intake and the sound pretty much disappeared (it is very faint, but I hear it if I turn off the music and really listen) so I chalked it up to being the new turbo or turbosmart DV+ sounds. But now I'm not so sure, perhaps I have a boost leak? But I figure a boost leak wouldn't affect AFR if the boost is holding steady at the MAP sensor? Before I go and drop another stack of cash on new injectors and tools, is anyone else familiar with this sort of behavior? Is it normal? Or is it a sign there is an issue? My car has 43k miles on it so I would expect the injectors to have plenty of life still as it's really only been tuned for the last few thousand miles. If anyone else has logs of Stage 2+ MM E30 (with roughly E40-E50 in the tank), I'd be interested in comparing logs as well! For reference, here is my Stage 2 MM log without the wavy AFR issue on the top end: https://www.bootmod3.net/log?id=62a0...90c60b5219c05c TIA! |
07-16-2022, 07:44 AM | #2 |
Rep 3,699
I don’t have time to review your log right now, so the other guys will have to chime in, but here’s a recent Stg 2+ MM log I did where I map switched between pulls.
Stg 2+ E30 (Map 1) —> 93 (Map 3) —> Flat Torque (Map 4) —> E30 (Map 1): https://www.bootmod3.net/log?id=62ca...729b6f82862fa8 I’m TTE460, not PS2, but curious if you see any similarities or differences. Good luck! |
07-16-2022, 06:19 PM | #3 | |
Rep 660
