BMW M2 Forum > M2 Photos, Videos and Builds > My 2020 BMW M2 Competition
      04-01-2020, 05:13 PM   #1
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Figured I might as well start a thread about my car, so here goes
My first BMW was an E30 M3 I purchased off the showroom floor at Competition & Sports Cars Limited in Greenwich, CT in 1989
My latest BMW is a F87 M2 Competition I purchased off the lot at BMW of Pembroke Pines in Pembroke Pines, FL in 2019
Here are the basic specs
2020 BMW M2 Competition Coupe
Hockenheim Silver - C33
Manual Transmission - ZMT
Executive Package - ZEC
Blue Stitching - MBD2
Carbon Fiber Trim - 4MC
Black 788M Wheels - 29U
ASAP10161.00
fullstack337.50
      04-01-2020, 05:14 PM   #2
2020M2Competition
429
Drives: Yes
The car was built on November 8, 2019
When I found out online that it was at a local dealership I knew I had to take a look
It has every factory option I would have chosen had I decided to order my own M2C
When I arrived at the dealership on December 30th it had only 11 miles on the odometer and looked great both inside and out
By the time I finished my test drive it had 41 miles
Thankfully, I had a very friendly, helpful and knowledgeable salesperson
I took delivery the following day (New Year's Eve)
I have very much enjoyed the first three months that I have had with this car
As of today (April 1, 2020) it has around 3600 miles on the odometer including 2 track days Homestead Miami Speedway and 2 track days at Sebring International Raceway
The car strikes a wonderful balance between performance and practicality
Of course, there is always room for improvement...
Last edited by 2020M2Competition; 04-01-2020 at 09:10 PM.. Reason: Updated with Pics
      04-01-2020, 05:15 PM   #3
2020M2Competition
429
Drives: Yes
Current Additions/Changes/Upgrades/Modifications/Accessories
Burger Motorsports Oil Catch Can
Akrapovic Titanium Evolution Link Pipe and Rear Slip On Exhaust System With Sound Kit
Autosolutions Short Shifter Kit - Stock Height - 20% Reduction - 80a+ Bushings
Rogue Engineering Transmission Mounts
BMW E90 Clutch Slave Cylinder
Ultimate Clutch Pedal
Sullivan Racing Products Aluminum Gas, Brake, Clutch and Dead Pedals
Goodridge Stainless Steel Brake Lines
Pagid RSL29 Brake Pads
Optimum Performance Titanium Brake Pad Shims
Castrol SRF Brake Fluid
BMW M Performance 763M Matte Black Wheels
Michelin Pilot Sport Cup 2 Tires - 245/35/19 Front and 265/35/19 Rear (BMW M2 Star Spec)
Rallyflapz Kaylan Front Mudflaps
Turner Motorsports Aluminum Oil Cooler Skid Plate With Custom Aluminum Grill
Zunsport Front Grill Set - Made to Order Without Logo
Prestige Maxxion Windshield Protection Film
XPEL Ultimate Paint Protection Film on Headlights and Rear Fenders
Modesta BC-08 Neosillica Matrix Coating
Modesta BC-06 Heat Resistant Hard Glass Coating on Wheels and Calipers
Prestige Ceraluxe Quantum Ceramic IRD CLX33 Window Film on Side and Rear Glass
Prestige Ceraluxe Quantum Ceramic IRD CLX70 Window Film on Windshield
Future Classic Slimline Aluminum License Plate Frame - Black
Technic PNP ASD Bypass Harness
BMW M Performance Matte Carbon Fiber Steering Wheel Trim
Auto Tecknic Matte Blue M1 Button
Auto Tecknic Matte Red M2 Button
BMW M Performance Drive Analyser
Fall Line Motorsports Halon Fire Extinguisher and Mounting Bracket
BMW M Performance Floor Mats
BMW All Weather Floor Mats
BMW All Weather Cargo Mat
BMW X5M Compact Aluminum Spare Wheel
Bimmerzone Aluminum Hub Centering Ring
Kumho Compact Spare Tire - T130/70-19
BMW Tool Carrier
BMW Jack
BMW Jack Crank
BMW Lug Wrench
BMW Spare Tire Case
BMW Luggage Compartment Floor Net
BMW Luggage Compartment Tie Down Straps
BMW UV Sunshade
BMW Glasses Case
BMW OEM Adapter Cable Kit
BMW First Aid Kit
BMW M Performance Tire Bags
BMW M Performance Indoor Car Cover
BMW M Performance Outdoor Car Cover
      04-01-2020, 05:16 PM   #4
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
Absolutely love this color on the M2C.
      04-01-2020, 05:16 PM   #5
2020M2Competition
429
Drives: Yes
So far the S55 engine has performed exceptionally well both on the road and at the track
It is basically stock at the moment due primarily to concerns about losing the factory warranty
Nevertheless, the temptation to tune is very strong so it will be interesting to see how long I can resist
The only upgrades at the moment are a BMS Oil Catch Can and a complete Akrapovic Titanium Evolution Link Pipe and Rear Slip On Exhaust System
      04-01-2020, 05:17 PM   #6
2020M2Competition
429
Drives: Yes
Transmission
I had an E90 Clutch Slave Cylinder (21526785964) installed in order to remove the clutch delay valve (CDV) that is present in the stock clutch slave cylinder
It made the clutch engagement point easier to feel and more predictable which I liked
However, it also made the clutch pedal feel a little softer which I did not
As a result, I had an Ultimate Clutch Pedal (UCP) installed
It is currently setup with both of the original clutch pedal springs in the middle position of the pedal and with two washers removed from the UCP supplied clutch stop
This firmed things up nicely
The UCP rests a little lower than stock which makes it easier to reach and the clutch now engages closer to the floor which I also find helpful
The lower panel below the steering column did need to be trimmed slightly to insure there was no interference with the UCP on my car
Next up was an Auto Solutions Short Shift Kit (stock height, 20% shift reduction and 80a+ bronze polyurethane front bushings)
I also had some Rogue Engineering Transmission Mounts installed at the same time as the stock mounts are very soft
The transformation in shifts are truly remarkable
The shifter feels much tighter, more stable and more precise
      04-01-2020, 05:18 PM   #7
2020M2Competition
429
Drives: Yes
Brakes
The 2NH brakes are probably the best factory brakes I've ever had on track
Upgrades include Pagid RSL29 brake pads, Optimum Performance Titanium Brake Pad Shims, Goodridge Stainless Steel Brake Lines and Castrol SRF Fluid
The pads for the 6 piston front and 4 piston rear calipers are simply massive both in terms of area and volume.
The front RSL29s had a pad thickness of 19.5 mm when new and there was still room for a 1 mm titanium shim when installed
The rear pad thickness was 18 mm when new and also had room for a 1 mm shim when installed
The pedal is now very firm providing strong initial bite with good modulation and fade resistance (although I do still experience occasional pad knock back)
Pad wear appears to be excellent so far after 4 track days with plenty of material remaining
      04-01-2020, 05:18 PM   #8
2020M2Competition
429
Drives: Yes
Suspension - TBD
Currently stock
      04-01-2020, 05:19 PM   #9
2020M2Competition
429
Drives: Yes
Wheels and Tires
BMW M Performance Matte Black 763M Wheels
9x19 ET 29 Front
10x19 ET40 Rear
245/35/19 Front
265/35/19 Rear
I will likely upsize to 255/35/19 front and 275/35/19 rear tires in the near future
      04-01-2020, 05:20 PM   #10
2020M2Competition
429
Drives: Yes
Interior
      04-01-2020, 05:21 PM   #11
2020M2Competition
429
Drives: Yes
Exterior
Modesta BC-08 Ceramic Coating
Modesta BC-06 Heat Resistant Ceramic Coating on Wheels and Calipers
      04-01-2020, 05:22 PM   #12
2020M2Competition
429
Drives: Yes
Miscellaneous / Other
I have an emergency spare setup that clears the 2NH brakes
You can read more about here
https://f87.bimmerpost.com/forums/sh....php?t=1689647
BMW Tool Carrier
BMW Jack
BMW Jack Crank
BMW Lug Wrench
BMW Spare Tire Case
BMW UV Sunshade
BMW Glasses Case
BMW First Aid Kit
      04-02-2020, 12:40 AM   #13
2020M2Competition
429
Drives: Yes
A very cool color indeed
Thanks for the kind words
      04-06-2020, 11:21 AM   #14
mike@x-ph.com
mike@x-ph.com's Avatar
Nice
https://x-ph.com/sale/
Phone number 702-494-9435
      04-07-2020, 05:32 PM   #15
2020M2Competition
429
Drives: Yes
Originally Posted by mike@x-ph.com View Post
Nice
Thanks Mike
I just updated the thread with more pictures and information
      04-08-2020, 09:54 AM   #16
adobeee
adobeee's Avatar
Drives: '23 X6 M50i
Did you manage to get a discount? I imagine given the economy the dealerships are likely very empty
      04-08-2020, 01:13 PM   #17
2020M2Competition
429
Drives: Yes
I bought my car at the end of December 2019 which was before the whole coronavirus thing exploded
The dealerships around here in South Florida usually have very high prices as well as very high fees
Just a few months earlier many were trying to sell these cars at or even above MSRP
The discount I worked out was 5% off MSRP for the car and 15% off all parts and accessories
At the time I thought it was a fairly good deal
