M2 Technical Topics > Suspension | Brakes | Chassis > Front adjustable endlink setup question
      03-01-2024, 07:03 AM   #1
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
Been looking into how to correctly setup end links but have a question.
If I set both end links with the car jacked, have em at the same length. Then drop the car so there is no preload on the sway bar leaving one disconnected. Now adjust the disconnected end link so it is effortless to connect to sway bar.
My question is, would then 1 of the end links be a different length than the other one? Would this matter or should one try to get both end links to be the exact same?
      03-01-2024, 09:20 AM   #2
OG Shark
OG Shark's Avatar
4693
Drives: Angry
I would adjust both loaded. I cannot envision how this wouldn't create a pretty uneven setup that would not have clearance problems. They don't have to be the exact same but the way you describe would likely be very uneven.
If it is a matter of access might look at a set of hub stands - they can really help here. Our alignment system uses them and I'm a big fan.
MooMooM21819.00
      03-01-2024, 09:35 AM   #3
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
I had to have my alignment shop properly adjust mine. I tried. Couldn't understand where all the clanking was coming from. Thought it was springs and camber plates. Nope, poorly adjusted endlinks slapping against the LCA.
MooMooM21819.00
      03-01-2024, 09:50 AM   #4
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
yeah this makes more sense to me but from every thing I read and videos where people are just leaving 1 unbolted and then adjust that one only and like you say this sounds like it would create an uneven end link (could be just a bit or could be a lot).
      03-01-2024, 09:53 AM   #5
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
yeah one of those things, hard to see in there when car is loaded, even on ramps. I guess that is when OGs recommendation of hub stands really make sense.
I might cheat and use my jacks to mimic the front being loaded and then adjust them that way since I have way too many jacks but no hub stands.
      03-01-2024, 12:22 PM   #6
medphysdave
That's a good idea. I should have measured the hub center to fender distance. Then lowered the car onto jack stands to compress the suspension until the hub fender measurement was replicated.
      03-01-2024, 12:27 PM   #7
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
I read it in the comments of a Farkle video lol so can't take credit but its indeed a good idea, will not be as accurate as other methods but I think will be good enough.
