M2 Technical Topics > Suspension | Brakes | Chassis > M2 Jacking ?
      02-29-2024, 09:40 AM   #1
Andrew2
Scotland
180
Drives: M2 OG DCT
M2 Jacking ?
Is it safe to jack - support the front - engine using the `dome` in the structural reinforcing plate ?
Included pictures found whilst searching the Forum ... E39 - E90 - M240iX
2017 M2
2000 B5 S4 Avant
1982 Mk1 Golf GTI
      02-29-2024, 10:27 PM   #2
Fred Conoway
Fred Conoway's Avatar
Drives: 2021 F87 M2 Competition
Yes. As you can see from the row of bolts on either side of the dome, the dome is right overtop of the front cradle/subframe crossmember which supports the entire front half of the vehicle. The dome is specifically designed as a jacking point.
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family)
F87source7251.50
Andrew2180.00
      02-29-2024, 11:21 PM   #3
F87source
F87source's Avatar
Drives: Bmw M2
+1
Andrew2180.00
      02-29-2024, 11:24 PM   #4
Swank
Drives: 2017 M2
I’ve used that dome to get the front up a few times. Don’t want to hijack but what are folks using for the rear jacking point?
Andrew2180.00
      03-01-2024, 12:05 AM   #5
F87source
F87source's Avatar
Drives: Bmw M2
The rear subframe as outlined here:https://f80.bimmerpost.com/forums/sh....php?t=1629416
Make sure you use a robber pad so the paint on the rear subframe ain't scratched, because if it is you now will have a corrosion risk.
Andrew2180.00
      03-01-2024, 02:57 AM   #6
Andrew2
Scotland
180
Drives: M2 OG DCT
Thank you for the prompt replies
Are people OK using the rear diff`, as noted for the M240iX ?
2017 M2
2000 B5 S4 Avant
1982 Mk1 Golf GTI
      03-01-2024, 03:18 AM   #7
F87source
F87source's Avatar
Drives: Bmw M2
No, the m2 diff cover is aluminum and has fins on it, it's also a bolted on cover not a solid part of the diff. This soft aluminum and protruding fin construction is easily damaged so do not jack from the diff. The m240i has a solid steel diff case so it's stronger and can be used as a jacking point.
      03-01-2024, 03:22 AM   #8
Andrew2
Scotland
180
Drives: M2 OG DCT
Oops ... missed that fact, I must get new glasses
Thank you
2017 M2
2000 B5 S4 Avant
1982 Mk1 Golf GTI
