02-11-2017, 01:17 PM | #155 | |
Rep 399
Drives: 2017 BMW M2 6MT
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
02-11-2017, 01:30 PM | #156 | |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
App is great, by the way. Thanks.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-11-2017, 02:02 PM | #157 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
Welcome! Amazing work on the app! Just emailed you on getting video in motion and miracast working for ID5. Thanks for the great support Stephen!
02-11-2017, 03:56 PM | #158 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
Awesome, welcome Stephan. You just replied to my email a couple of hours ago. I was coming here to post about it.
I asked him about future vehicle support, iDrive 6 interface and passenger seatbelt warning. Got this reply (although I guess now he can tell you himself): "I am working on the F10 ECUs at the moment, but others will follow ;-) I am also looking into the iDrive Interface coding, which seem to be not possible at the moment, because some of the values are missing. So this will be possible, but depends on the head unit. Seatbelt chimes are not codable at the moment, since the ACSM module seems a bit more tricky to code, but I will keep working on it." |
02-11-2017, 04:40 PM | #159 |
Rep 123
02-11-2017, 07:08 PM | #160 | |
Rep 1,418
Maybe we could get a wish list going here so that Stephan sees what is 'priority' to us... Personally, 1. Ability to rename backups/permanent saves? 2. Seat belt chime 3. Video in motion/always on rear view camera (just because it would be neat to have ) 4. Id6 option |
BAN_M2C4185.00 |
02-11-2017, 07:25 PM | #161 |
Rep 616
02-11-2017, 07:32 PM | #162 | ||
Rep 197
02-12-2017, 12:34 AM | #163 |
Rep 19
Thanks for welcoming me, even I do not own a M2
The backups will not be overwritten, but if you delete the app, the backups are lost also. You will be able to rename and import/export backups soon. The ACSM (Seat belt chime coding) is a bit more tricky to code, but I am looking into get things working. Since this is a safety-critical ECU I do not want to risk messing things up. The missing values for HMI_ID_VERSION will be included in the next version also. I am also working on supporting more models. At the moment I am working on the F10 ECUs and after that the X models will follow. |
02-12-2017, 02:56 AM | #164 |
Rep 13
02-12-2017, 08:13 AM | #167 |
Rep 4
02-12-2017, 10:17 AM | #168 |
Rep 177
Hello,
Weird situation with my mirrors : - I activated the option to automatically rotate then when closing the car - no change in the car : when I lock it with the key the mirrors don't move - after a few days I discovered by coincidence that if I press the key a long time to lock the car they will actually rotate - now they still rotate with a long key press... but they don't rotate anymore when I drive the car in reverse (although I haven't changed these settings) Anyone has an idea ? I haven't connected the car again to return to the default mirror settings yet... Thx for your kind feedback & support ! Olivier |
02-12-2017, 10:46 AM | #169 |
Rep 1,418
Mine rotates immediately upon locking car with fob. (MY17).
Apologies but I forget now if I messed with the comfort access delay settings...may be the cause? Others on here will chime in I'm sure since they had similar issues. Re the reverse, there is a setting in there 'mirror tilt on reverse' is this what u mean by 'rotate'? If so, it should be set to 'active'. |
02-12-2017, 11:32 PM | #170 |
Rep 19
By default you have to press the button at least 1,5 seconds to make the mirrors fold. If you code the comfort closing delay to 0, then the mirrors will fold instantly. For the mirrors tilting when in reverse, please check, if the switch to choose between the mirrors is set to the left.
02-13-2017, 09:34 AM | #171 |
BMW DRIVER ///M
106
Rep 317
App works well I have been using it for a while now. !
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey 2004 E46 M3 White END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci |
02-15-2017, 11:51 AM | #173 |
Doc Brown
1176
Rep 2,174
So I just got the OBDII connector..... It says to download the app and that costs $9.99, is that the correct app? The pic looks correct but I am not sure.
02-15-2017, 12:01 PM | #174 |
Rep 148
02-15-2017, 12:09 PM | #175 |
Doc Brown
1176
Rep 2,174
No, I am talking about the OBDII connector app, not the bimmercode app. My in app purchase in the bimmercode app says $29.99.
02-15-2017, 12:12 PM | #176 |
484
Rep 821
Which OBD device did you buy? The Vgate iCar2 Wifi device is one of the best.
