02-12-2019, 11:58 PM | #47 | |
Rep 87
Drives: 2018 M2 LCI
09-26-2019, 09:59 PM | #48 |
Rep 521
09-27-2019, 04:17 PM | #49 |
Rep 78
dont forget about the cobra Nagaro, can be custom stitched when order is placed as well, along with leather/alcantara options to the brey krause mounts to retain power functions.
09-29-2019, 04:40 PM | #50 |
Rep 159
I have a pair of Nogaros on order (should be here in a week or two, so I'm told). Looks like it will require coding out the seat heaters (or getting replacements and putting them under the pads), as well as coding out the airbags and the seat occupancy sensor. Power sliders can be retained, or switch to manual sliders. Will post as comprehensive a write-up as I can once everything is ready.
Endeav388.50 |
09-30-2019, 11:47 AM | #51 | |
Rep 238
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
10-04-2019, 10:46 AM | #52 | |
Emperor
1614
Rep 2,753
I, too, have them mounted on OE BMW sliders with the BK mounts. The whole thing is about as factory/OE as an aftermarket seat can get, imo! And all without costing more than a "normal" generic setup (swiss cheese floor plate, crappy aftermarket slider, generic side mount, seat wrapped in generic color for all material).
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
10-12-2019, 06:20 PM | #53 |
Rep 159
Ok, seats are at HMS and are on their way to mine. Attached are the pictures HMS sent me. Their recommendation was to just buy new heaters and put them below the pads, and I'm likely going to buy third party ones (the F87 seat heaters are like $150/side and a very odd shape that's unlikely to fit well in the shell) and replace the plug with the BMW plug.
I'm actually attempting to build my own brackets (laser cut, bent, and powder coated 1/8" steel, similar to the M4 GTS brackets), so that's going to take a little bit of time. I need to test fit it before I make the remaining ones. |
10-13-2019, 06:37 AM | #54 | |
Emperor
1614
Rep 2,753
What are you hoping to gain making your own mounts? If you got nogaros, the BK option is seat specific and car specific. Pretty unusual perk to the nogaro! Your pictures aren’t loading for me. |
10-13-2019, 12:30 PM | #55 |
Rep 427
Do the Nogaros have a lower pass through for a 6 point harness? The MFR description talks about the shoulder strap pass throughs for a 4 point harness, but it isn’t clear whether they’ve gone all the way with the “Circuit" version and also added a pass through for the sub straps.
I found a few photos showing 6 points installed, but I’m curious if folks are modifying the seats to accommodate the sub-straps, or if they’re designed to be compatible. Also, what’s the fit like on these seats? Room for a larger/heavier driver? Shoulder pass through holes high enough for a tall driver? I’m 6’2" and 40" waist. Most of my height is in my torso. We don’t have a local stocking seller anymore that I can find, so I’d have to order blind if I went with them. For reference, my other half just put Recaro Sportsters, 1/2 cage, 6 point harnesses in her 718 Cayman. I’ll probably go that route at some point if the Nogaros aren’t suitable. I find the Sportsters comfortable, and have Sparco REVII for my other car where 3 point compatibility isn’t a consideration. |
10-13-2019, 12:52 PM | #56 | |
Emperor
1614
Rep 2,753
I’m 6’4 and the harness holes align properly for me. 38 waist and fit comfortably. |
10-13-2019, 01:21 PM | #57 |
Rep 385
10-13-2019, 09:54 PM | #58 |
Rep 427
10-30-2019, 06:13 PM | #59 | |
Rep 159
The annoying thing is that I'll need to bring the seat module along as well (not necessary for seat motion). The enjoyment of making them (learning CAD, laser cutting, sheet metal bending). I went pretty far down the road but chatted with some folks who basically said the bends I wanted to do were going to be nearly impossible without CNC tools, and the quote I got from a local shop was close enough in cost to the BK mounts that I ended up buying the BK ones. |
12-04-2019, 07:32 PM | #60 |
Rep 159
Seats are finally installed:
Full thread for more info: https://f87.bimmerpost.com/forums/sh...7#post25535027 Last edited by asciimike; 12-04-2019 at 11:00 PM.. |
Yellowflash21369.50 |
06-15-2022, 12:39 PM | #61 |
Rep 345
Im planning to get sportster cs seats for my og m2 only on driver side. Any inputs or parts I need besides coding some things off?
TIA! |
08-11-2022, 03:24 AM | #62 |
Rep 31
Could someone educate me on runners/mounts?
I have an M2C with electric adjustable/heated and want to replace with Recaro CS manual adjust. The aftermarket runners I have seen say "cant replace electric". Am I missing something? Please help, what do I need to make them fit |
10-18-2022, 02:52 PM | #63 |
Rep 35
Drives: LSB E46 M3, AW F87 M2, Model 3
I recently completed the installation of a pair of black leather Sportster CS in my OG M2.
Here's my parts list: 1 Recaro Sportster CS (Driver side) 1 Recaro Sportster CS (Passenger side) 2 Recaro sliders 7227671 1 Planted Seat Bracket (driver) SB141DR (for E90 M3) 1 Planted Seat Bracket (passenger) SB141PA (for E90 M3) Bolts/hardware: 8 M10x25mm Hex screw bolts 8 M10 flat washers Passive restraint integration (optional): 1 BMW Left pretensioner seat belt latch for F-series pn. 72117259387 1 BMW Right pretensioner seat belt latch for F-series pn. 72117259388 2 M10x22 Filister-head screws pn. 07146960536 2 M10 hex nuts They are drop in/direct fit, no metal work or wire splicing needed. Coding will be required to fix the airbag warning error. Overall, a very solid seat mod. I must say.
I have a white f87 m2 and a blue e46 m3
4
10-18-2022, 07:12 PM | #64 | |
@lbb_kev
494
Rep 515
10-19-2022, 09:57 AM | #65 |
Rep 35
It is lower but not much. It's hardly noticeable.
You can feel you are sitting in and not on the seat.
Sundinisagod107.00 |
11-04-2022, 03:39 PM | #66 |
Rep 224
Can you please elaborate on the seat belt restraint? Can you not use the one from the oem seats? Why did you order the items below?
Thank you! Passive restraint integration (optional): 1 BMW Left pretensioner seat belt latch for F-series pn. 72117259387 1 BMW Right pretensioner seat belt latch for F-series pn. 72117259388 2 M10x22 Filister-head screws pn. 07146960536 2 M10 hex nuts |
