03-24-2019, 10:36 PM | #26 | |
Rep 1,316
03-25-2019, 10:22 AM | #27 |
Rep 2,956
There is a bit of Darwinism with this mod. It sounds like a great idea until that one time where you least expect (these things always tend to happen in the worst place after all), your key fob fails, battery dies, and you can't get into the car because you did a modification that removes the key hole.
04-11-2019, 06:24 PM | #30 |
Rep 462
A fair amount - as others gave mentioned, putting the key in, turning and pulling helps.
Very stressful for such a simple mod.
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
06-06-2019, 04:40 AM | #31 | ||||||
Petrol Head
138
Rep 158
Drives: Current: F87 M2C, Jeep Wrangle
Lagom...
"not too little, not too much" |
06-06-2019, 04:53 PM | #32 | |
Rep 385
Awesome write up just did it easy with the step by step! |
06-07-2019, 03:46 AM | #33 | ||
Petrol Head
138
Rep 158
Lagom...
06-09-2019, 08:14 PM | #34 |
Rep 385
09-21-2019, 11:17 AM | #35 |
Rep 758
Thanks for the DIY instructions, all in all, pretty easy...I thought it was being held by something on the left hand side but I just need to pull harder on the key. The hardest part was shaving down the black clips to hold it on. Be careful to take off just enough material as these clips are what keep the cover on tight. I test fitted it a few times on the lock cylinder mechanism and it turn out perfect.
Word to the wise - don't pull the door handle with the cover/lock cylinder mechanism removed! It will slip right off the opening mechanism. It wasn't too difficult to rectify but it did cause a moment of panic!
'17 M2 DCT Long Beach Blue
09-21-2019, 11:26 PM | #36 | |
Rep 385
04-15-2021, 07:25 AM | #37 |
Rep 1,418
Excuse the bump.
My lock cylinder was not re-installed when the iND painted keyhole was swapped in. I believe there’s a blank in its place. I’m screwed if something were to happen so I want to remove and re-install the lock. How challenging will the painted keyhole cover be to remove without a car key after I loosen the 4mm screw to wiggle it out? I gave it a test run but didn’t want to unscrew all the way so I decided to wait and ask here first. I’m scared of the screw falling into the door! Thanks! |
04-15-2021, 01:42 PM | #39 |
17698
Rep 8,494
The cover is easier to remove than install
I'm not concerned with getting in my car without a key I can open the door with my app and my battery is kept in perfect condition by being plugged in when not driven
04-17-2021, 02:48 PM | #40 | |
Rep 1,418
I don’t think I shaved enough of the clips because of how it sits on the door despite the screw being tightened the best I could. Ya think this will cause an issue with water seeping into the mechanism? |
08-14-2021, 03:58 PM | #41 |
Rep 569
I lost my screw inside the door doing this. Anyone have a link to buy a new screw?
2020 M2 CS | Black Saphire Metallic | DCT / CCB
SOLD: 2012 135i | Le Mans | 6MT 1986 535i | Cirrus Blue Metallic | 5MT |
08-14-2021, 10:59 PM | #42 | |
Petrol Head
138
Rep 158
You can refer to the diagram here to double check: https://bimmercat.com/bmw/en/search/...on/USA/51_8406 Link to buy: https://www.turnermotorsport.com/p-8...uine-bmw-part/
Lagom...
01-11-2022, 07:58 PM | #43 |
Rep 9
