12-28-2020, 07:04 PM | #1 |
Rep 2,412
Drives: E30 M3 Cecotto, F85, G05, G07,
PSA - Safely removing wheels with CCB
Put this montage together for ya'll.
Is it perfect? No. Does it work? Yes. Is it better than nothing? Yes. Here is the wheel dolly I used.
12-28-2020, 07:27 PM | #2 |
Rep 13,119
Though the video title was reassuring, I got a little nervous when looking at the work in progress.
Suggestion: ask someone (significant other, one of your kids or a friend) to assist you in simply holding the dolly stable while you're positioning the wheel. Now it looked as if the dolly could wobble, wiggle or slide away. And we all know that if, during one false move, the alloy violently kicks the brake disc, it's almost certainly mayhem. Kudos for courage, like an ibex on a dam:
///M is art ↔ Artemis
MadBimmeRad7121.50 |
12-28-2020, 07:33 PM | #3 |
Rep 2,819
Drives: e82 1M, f87 M2cs
I trust myself to remove a lightweight alloy wheel without bumping the rotor with significantly more confidence and safety than this method. I am surprised you would even share a video with that sound that happened at 2:07. This is not the way. (Anti-Madalorian)
Zuzu2816.00 |
12-28-2020, 07:39 PM | #4 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Nice work! Thanks for all of your vids, enjoying them. I'm days away from getting mine which is the same spec as yours!
When you were taking the wheel off part of the initial jerk was caused by the wheels of the dolly being perpendicular to the direction they needed to go. I'd suggest that if you could (either before or after loading pressure) turn the wheels of the dolly by hand so they are pointed the right direct it might alleviate the jerk into that backing shield that you hit. Though, after seeing how difficult and unnerving that was I'm definitely going to go with some 80mm studs https://ind-distribution.com/product...onversion-80mm
12-28-2020, 07:45 PM | #5 | |
Rep 4,679
12-28-2020, 08:01 PM | #6 |
Rep 632
I'm curious for those of you with CCB. Do you have this expectation that the technicians, that will inevitably work on your car one day, will show the same amount of care and caution when removing your wheels? Most places don't allow customers in the shop. It seems highly likely a small ding would happen here and there.
What's the best way to make sure they don't damage your $8k brakes. OP, I applaud you for your passion and care for your car. |
12-28-2020, 08:09 PM | #7 | |
1449
Rep 906
12-28-2020, 09:17 PM | #8 |
Rep 4,679
It is easy to over complicate things. At the end of the day you also have to make sure these brakes don't make you miserable worrying about them. I think a lot of the negatives are over hyped. Watching these videos seems to show that the back of the disc is well protected. I think it's unfortunate that you have to run a block off for the air duct for street use reduce probability of stone damage, but the cooling is likely unnecessary for daily duties. It would be really unfortunate to damage the wheel during removal. I would only get them serviced at bmw. No more tires at Costco.
12-28-2020, 09:41 PM | #9 | |
Rep 2,819
Keep it real, sure. "Here is what I tried....but it didn't work" is the take home message here. Don't try to load match your floor jack and your wheel dolly. It won't work.
12-28-2020, 10:20 PM | #10 | ||
1449
Rep 906
12-28-2020, 10:31 PM | #11 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
I've had multiple vehicles with CCB's and removed the wheels myself many times without issue. Pretty sure you have to be pretty careless to bang a wheel into your rotor hard enough to damage them. Even a little bit of caution and effort will make everything just fine.
12-29-2020, 05:28 AM | #12 |
Rep 2,412
I chose to post what I posted because it was less than perfect and it is the real world. The sound was indeed the wheel hitting the disc backing plate and the bottom of the caliper touching the wheel. Nothing happened, but it made a sound.
I do think a better solution would be to use very long wheel hangers but I have not found any that are super long.
DocEyes78.00 medphysdave4571.50 |
12-29-2020, 07:14 AM | #13 |
Rep 823
#2 on the list of reasons I didn't get CCB's! I've watch too many Porsche guys fidget with their "sensitive" brakes at the track.
I don't have the patience to handle all that just to change wheels from street to track(summer to winter, whatever).
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
12-29-2020, 03:01 PM | #14 |
Rep 7,637
OK... What am I missing here..
Why wouldn't he just use wheel stud hangers.. Last edited by Zuzu; 12-29-2020 at 03:08 PM.. |
IND-Distribution9591.00 |
Tags |
ccb, damage, remove, unmount, wheels |
